Sent you an email, Billy - interested in trying an experimental flash if possible
Pioneer BDR-XD08B
Re: Pioneer BDR-XD08B
I too am stuck with a BDR-XD08B on 1.02 firmware. Didn't do my research before buying
blackphoenix
I just picked up one off of ebay and seems to be the original firmware version too. Is there an option for libre on this?
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-XD08
Revision: 1.00
Serial number: BIDL000218UC
Firmware date: 2022-04-03
Revision: 1.00
PM sent.blackphoenix wrote: Mon Oct 13, 2025 9:01 pm I just picked up one off of ebay and seems to be the original firmware version too. Is there an option for libre on this?
Revision: 1.00
blackngold75
I only have one UHD disc so far. However, I'd like to be able to rip that and future discs. Here's the drive info - how do I rip on MacOS?
OS device name: /dev/rdisk4
Revision: 1.02
Serial number:
Firmware date: 2022-12-27
Highest AACS version: 61
Drive platform: Pioneer RS9330
Firmware version: GENE
Revision: 1.02
Serial number:
This drive is not UHD compatible and cannot currently be flashed. The firmware is post 11/2022 so you must wait for future support.blackngold75 wrote: Tue Oct 14, 2025 4:45 pm I only have one UHD disc so far. However, I'd like to be able to rip that and future discs. Here's the drive info - how do I rip on MacOS?
Revision: 1.02
Serial number:
PomeloAccurate8915
I bought one of these a while ago and was wondering if it can be crossflashed for UHD discs.
Revision: 1.00
Serial number: ..
Highest AACS version: 81
PM sent.PomeloAccurate8915 wrote: Wed Nov 12, 2025 3:10 am I bought one of these a while ago and was wondering if it can be crossflashed for UHD discs.
Drive Information OS device name: /dev/sr0 Manufacturer: PIONEER Product: BD-RW BDR-XD08 Revision: 1.00 Serial number: .. Firmware date: 2022-04-03 Bus encryption flags: 1B Highest AACS version: 81 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS9330 Firmware version: GENE
PressedRat
Can mine be flashed to read UHD discs?
OS device name: F:
Revision: 1.02
Serial number:
Highest AACS version: 82
Drive platform: RS9330
Firmware name: PIONEER BDR-BDS8
Firmware version: 1.02
Unrestricted read speed: YesRe: Pioneer BDR-XD08B
No. Firmware is too new and encrypted.PressedRat wrote: Sun Nov 16, 2025 3:33 pm Can mine be flashed to read UHD discs?
Drive Information OS device name: F: Manufacturer: PIONEER Product: BD-RW BDR-XD08 Revision: 1.02 Serial number: Firmware date: 2022-12-27 Bus encryption flags: 1B Highest AACS version: 82 LibreDrive Information Status: Enabled Drive platform: RS9330 Firmware name: PIONEER BDR-BDS8 Firmware type: Original (unpatched) Firmware version: 1.02 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Good Day Everyone.
I just bought one of these as well, after having trouble with both my LG drives, and am hoping someone may help me in cross-flashing this to support UHD Discs.
Here's my Info:
Here's my Info:
Revision: 1.02
Serial number: DIDL014594UC
Sorry! The firmware is too new. You have to wait if Mike comes up with a solution.MothMan wrote: Fri Mar 06, 2026 12:30 am Good Day Everyone.
Here's my Info:
Drive Information OS device name: D: Manufacturer: PIONEER Product: BD-RW BDR-XD08 Revision: 1.02 Serial number: DIDL014594UC Firmware date: 2022-12-27 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS9330 Firmware name: PIONEER BDR-BDS8 Firmware type: Original (unpatched) Firmware version: 1.02 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
I can flash this for youMothMan wrote: Fri Mar 06, 2026 12:30 am Good Day Everyone.
Here's my Info:
Sure email me that drive info section see below for email
For all others there is no need to post your makemkv drive info section publicly just email it to me directly
Hi I was researching how to get my drive to read UHD disks and was wondering what I can do to make this happen, thank you. Here is my drive info on makemkv:
Sure email me that drive info section see below for emailmunch13s wrote: Sun Mar 08, 2026 4:24 pm Hi I was researching how to get my drive to read UHD disks and was wondering what I can do to make this happen, thank you. Here is my drive info on makemkv:
Thank you Billy for the help, you are a gentlemen and a scholar!
I am ripping my very 1st UHD disk, very happy!
