Pioneer bdr 209 and Pioneer bdr 209m
Re: Want to crossflash my BDR-209M with S11 FW
#106 Post by MartyMcNuts » Tue Oct 14, 2025 10:42 pm
Piranha26 wrote: Tue Oct 14, 2025 9:01 pm Hi guys,
I'm a DVDFab user.
I want to crossflash my existing Pioneer BDR-209M to a BDR-S11JBK to make it UHD capable/friendly. I found a post where someone of you said he would own 4 drives and all of them have been crossflashed to a BDR-S11 successfully. My question is how to do that? I can't find the neccessary bin file anywhere on the internet. Could someone please help or provide the neccessary file to me?
My drive is Libre enabled (please check the attached Info file of my drive)
Is it possible to flash with SDFtool flasher or do I need BDR flash?
Someone here says one would need 2 files. A kernel file and another one...
https://forum.cdrinfo.pl/showpost.php?p ... tcount=780
So I'm a bit confused. Can someone please assist?
Thank you in advance
Piranha26
1. DVDFab isn't UHD compatible with Pioneer drives.
2. The Pioneer flasher isn't public but you can email Billycar11 the MakeMKV drive info/libredrive info sections and purchase a flasher from him.
#107 Post by Billycar11 » Wed Oct 15, 2025 3:45 pm
I'm a DVDFab user.
Piranha26
Yes as Marty said pioneers don't work with dvdfab for UHD
But I can flash your drive for you see below
Piranha26
Re: Pioneer BDR-209M crossflashing
#108 Post by Piranha26 » Wed Oct 15, 2025 10:57 pm
Thanks Billycar,
I just wrote you an e-mail.
BR
Piranha26
FullDrive
Re: Pioneer bdr 209 and Pioneer bdr 209m
#109 Post by FullDrive » Mon Oct 20, 2025 3:20 am
Coopervid wrote: Fri Aug 15, 2025 9:02 am PM sent.
Hello! Would it be possible to get the firmware to flash Gen 1 and Gen 2 S11JBKs? I was able to get the respective 211M firmwares from the other forum and flashed my S11s, but if at all possible I'd like to have S11 firmware on my S11s, and if I could flash my S09 XLBs to be S11s, the firmware to do those as well.
Thank you for your time, and all that you do for the community!
#110 Post by Coopervid » Mon Oct 20, 2025 9:02 am
FullDrive wrote: Mon Oct 20, 2025 3:20 am
You need to post your Makemkv info for the drives you want to flash.
FullDrive
#111 Post by FullDrive » Mon Oct 20, 2025 11:43 pm
Coopervid wrote: Mon Oct 20, 2025 9:02 am You need to post your Makemkv info for the drives you want to flash.
MakeMKV information for the drives as follows, and thanks again!
BDR-S11JBK #1
OS device name: H:
Manufacturer: PIONEER
Product: BD-RW BDR-S11
Revision: 1.50
Serial number: CENSORED (Can provide later if needed)
Firmware date: 2017-12-21
Highest AACS version: 78
Drive platform: Pioneer RS8801
Firmware version: ID43
BDR-S11JBK #2
Revision: 1.02
Firmware date: 2017-02-23
Drive platform: RS8800
Firmware name: PIONEER BDR-211
Firmware version: 1.02/ID43
BDR-S09XLB #1
OS device name: H:
Product: BD-RW BDR-S09
Revision: 1.31
Firmware date: 2015-05-25
Drive platform: RS8600
Firmware version: 1.31/ID43
#112 Post by Coopervid » Tue Oct 21, 2025 4:01 pm
FullDrive wrote: Mon Oct 20, 2025 11:43 pm
BDR-S11JBK #1
OS device name: H:
Revision: 1.50
BDR-S11JBK #2
Revision: 1.02
BDR-S09XLB #1
OS device name: H:
Revision: 1.31
PM sent.
rez83
#113 Post by rez83 » Thu Oct 23, 2025 5:01 am
Hello! Please send me a message for my drive as seen below:
OS device name: G:
Product: BD-RW BDR-209M
Revision: 1.33
Serial number:
Firmware date: 2015-12-09
Highest AACS version: 82
Firmware version: 1.33
Thanks in advance.
#114 Post by Coopervid » Thu Oct 23, 2025 8:59 am
rez83 wrote: Thu Oct 23, 2025 5:01 am Hello! Please send me a message for my drive as seen below:
OS device name: G:
Revision: 1.33
Serial number:
Thanks in advance.
PM sent.
Waderr7
#115 Post by Waderr7 » Thu Oct 23, 2025 2:04 pm
Can you please send me a firmware that unlocks this?
Thank you very much.
OS device name: F:
Manufacturer ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Firmware date: 2020-07-21
Firmware version: ID76
Brak płyty w napędzie
#116 Post by Coopervid » Thu Oct 23, 2025 2:19 pm
Waderr7 wrote: Thu Oct 23, 2025 2:04 pm Can you please send me a firmware that unlocks this?
Informacje o napędzie
Nazwa systemowa: F:
Aktualny profil: BD-R SRM
Producent: ASUS
Produkt: BW-16D1X-U
Wersja: E113
Numer seryjny:
Data firmware: 2020-07-21
Flagi szyfrowania bus: 1B
PM is coming.
Waderr7
#117 Post by Waderr7 » Thu Oct 23, 2025 9:19 pm
Coopervid wrote: Thu Oct 23, 2025 2:19 pm
Nazwa systemowa: F:
Producent: ASUS
Produkt: BW-16D1X-U
Wersja: E113
Numer seryjny:
PM is coming.
Thanks for the reply.
I have a question. My drive platform is Pioneer RS8F00, and in the folder I got Hardware Version: SAT 8F01.
Can I flash it safely?
#118 Post by Coopervid » Fri Oct 24, 2025 8:06 am
Yes.
rez83
#119 Post by rez83 » Fri Oct 24, 2025 4:29 pm
Coopervid wrote: Thu Oct 23, 2025 8:59 am
OS device name: G:
Revision: 1.33
Serial number:
Thanks in advance.
PM sent.
Big thanks to Cooper, works great
Treguard
#120 Post by Treguard » Wed Nov 12, 2025 12:31 pm
Hi
Please could you tell me if it's possible with mine so that I can play UHD discs on it?
OS device name: F:
Revision: 1.20
Serial number: NFDL015878WL
Firmware date: 2014-04-08
Bus encryption flags: 13
Highest AACS version: 42
Firmware version: 1.20/ID60
The drive is still working...of a fashion. You have to press the eject button quite a few times to get the door to open.
