StarForce
#1441
Post
by StarForce » Sat Oct 11, 2025 6:38 am
MartyMcNuts wrote: Sat Oct 11, 2025 6:10 amThey are pretty poor quality drives. These ASUS models are essentially just rebadged LG WH16NS40's with ASUS firmware on them.
Anyhoo, since the drive is having trouble reading the disc, the first thing to do is clean the disc. Most UHD discs need to be cleaned before they can be read as they usually contain an invisible film on them from the manufacturing process.
How are the drives connected? If externally via USB, ensure all plugs are connected to ports direct on the motherboard (not case ports) and ensure your enclosure or adapter is getting enough constant AC power.
It's connected via SATA directly to the motherboard. The problem is that right now it doesn't recognize any discs. It tries to read them and finally says "No disc inserted." I'm completely lost. It won't even play the UHD disc of "The Boy and the Heron" or the regular Blu-rays I ripped a few hours ago. It's crazy. Can I reinstall the firmware I had before? I made a dump with the "READ Firmware" option. Can I load it with the "RECOVER Drive" option?
Right now my drive has "Region 1" as Region selected but I live in Spain, "Region 2". Maybe this has changed or all regions are unlocked and I get this new "Region 1" but it's not relevant. Changed to "Region 2" and nothing change. Drive can't recognize any disc. I've really had bad luck
When I choose "RECOVER Drive" it doesn't find any firmware inside "Firmware_Dumps" but I have a dump on it.
#1442
Post
by MartyMcNuts » Sat Oct 11, 2025 9:20 am
StarForce wrote: Sat Oct 11, 2025 6:38 am
No, that dump file only contains the calibartion data for the drive, not the fulll firmware.
Those drives sometimes get confused and won't see any disc at all. Cut power to the drive for a couple of minutes so it can reset itself. Just turn off the PC for a few minutes and make yourself a cuppa. Come back, restart the PC and the drive should have reset itself.
No, the region isn't important as MakeMKV doesn't care about any region coding. You should not try to play a UHD disc as they are different to regular blu-ray discs and can only be played using unofficial players such as VLC when integrated with MakeMKV to decrypt on-the-fly.
StarForce
#1443
Post
by StarForce » Sat Oct 11, 2025 7:28 pm
I don't understand anything. Hours ago I turned off the computer completely disappointed because my ASUS BW-16D1HT drive with the firmware downgrade to version 3.10 MK was not able to recognize any BluRay neither normal nor Ultra HD. A couple of hours ago I turned the computer on, I realized that I had forgotten inside the drive a normal BluRay animation movie for kids (Mia and Me: The Hero of Centopia), I checked that the reader detected it, I decided to open MakeMKV to rip it and it did it!! I extracted the movie and introduced "The Boy and The Heron" in Ultra HD, I checked that MakeMKV detected it, I tried to rip it and it did it too!!... Insane. I can't find any explanation but I can confirm that it worked. Well, now I feel very luck and very very grateful. Thanks a lot.
#1444
Post
by Billycar11 » Sat Oct 11, 2025 10:37 pm
StarForce wrote: Sat Oct 11, 2025 7:28 pm
Yes this is very common to happen to LG/Asus media tech drives
Mr_Orange
#1445
Post
by Mr_Orange » Mon Oct 13, 2025 12:45 am
I just tried running the latest version and it errored out with "MakeMKV installation not found. Please install MakeMKV".
MakeMKV is installed, albeit in the non-default location, however I have copied SDFtool Flasher.exe to the MakeMKV directory and run it from there and it still doesn't work.
I haven't had this issue before because MakeMKV has been installed in the same directory for years and I have run SDFtool Flasher before.
Any ideas please?
#1446
Post
by MartyMcNuts » Mon Oct 13, 2025 1:37 am
Mr_Orange wrote: Mon Oct 13, 2025 12:45 am
Any ideas please?
Install MakeMKV in the default location.
Mr_Orange
#1447
Post
by Mr_Orange » Mon Oct 13, 2025 1:45 am
MartyMcNuts wrote: Mon Oct 13, 2025 1:37 am
Any ideas please?
I haven't had to before. Why wouldn't SDFtool Flasher look for MakeMKV in the same directory as it is running from?
#1448
Post
by MartyMcNuts » Mon Oct 13, 2025 1:47 am
Mr_Orange wrote: Mon Oct 13, 2025 1:45 am
Any ideas please?
There was a c# change a while ago then the code that it used to use to search for it no longer worked and was removed. It now only looks for it in the default location.
Once we have an update on the Pioneer firmware situation, I may update SDFtool Flasher then.
Mr_Orange
#1449
Post
by Mr_Orange » Mon Oct 13, 2025 1:55 am
MartyMcNuts wrote: Mon Oct 13, 2025 1:47 am
OK, thank you. I ran the command line tool instead to reflash my LG, but it looks as though it has given up the ghost. Even after being fully powered down (i.e. power cord removed from the PC PSU) for 10-15 minutes, it isn't recognising any discs.
#1450
Post
by MartyMcNuts » Mon Oct 13, 2025 2:01 am
Mr_Orange wrote: Mon Oct 13, 2025 1:55 am
Could be a dead laser. Did you try cleaning the lasers?
Mr_Orange
#1451
Post
by Mr_Orange » Mon Oct 13, 2025 2:18 am
MartyMcNuts wrote: Mon Oct 13, 2025 2:01 am
No and, TBH, I wouldn't know how to. It is a 5.25" internal BH16NS55 (flashed to WH16NS60 1.02MK).
#1452
Post
by MartyMcNuts » Mon Oct 13, 2025 2:41 am
Mr_Orange wrote: Mon Oct 13, 2025 2:18 am
There are a couple of posts on the forum somewhere explaining how. You might have to do a bit of searching.
Mr_Orange
#1453
Post
by Mr_Orange » Mon Oct 13, 2025 2:46 am
MartyMcNuts wrote: Mon Oct 13, 2025 2:41 am
OK, will have a look around. I have an external Pioneer (Verbatim 43888) drive too, so I'm not completely out of action.
#1454
Post
by Coopervid » Mon Oct 13, 2025 9:24 am
Mr_Orange wrote: Mon Oct 13, 2025 2:46 am
Buy a CD cleaning disc for your 5,25" drive.
Mr_Orange
#1455
Post
by Mr_Orange » Mon Oct 13, 2025 10:00 am
Coopervid wrote: Mon Oct 13, 2025 9:24 am
Well I never! I did not know that was a thing. I'll try one, thanks for the tip.
