All Pioneer drives will be LibreDrive supported
Dromeosaurid
Re: All Pioneer drives will be LibreDrive supported
Post by Dromeosaurid » Sat Aug 23, 2025 12:58 am
This is great news!
MovieNut
Post by MovieNut » Sat Aug 23, 2025 6:59 am
Looking forward to this as well. I will have several Pioneer drives waiting. :wink:
VA1DER
Post by VA1DER » Sat Aug 23, 2025 9:42 pm
MartyMcNuts wrote: Tue Aug 19, 2025 10:58 pm Yeah, but they most likely will be supported in the near future.
"Near" is open to interpretation. :roll:
That said...
MartyMcNuts wrote: Tue Aug 19, 2025 10:58 pmAlso, since Pioneer ceased manufacturing optical drives several months ago, the worlds supply is dwindling rather quickly!
The slimlne XS08 and even the UD04 you can still sort of get UHD-patchable versions of now are good drives, but actual S series 5. 25" drives are the best there are. I don't know how long before S12/S13 (or X12/X13) drives made after Dec 2022 will be libre drive patchable, but the consensus is they definitely will be. And when they are, what little stock there is of those drives now will turn into genuine unobtanium.
Now is the time to spring for one, or forever hold your peace.
cheeseballs
Post by cheeseballs » Sat Aug 23, 2025 11:13 pm
This is probably a stupid question but will ask anyway-
Recently bought a random external drive on Amazon and it turned out to be a Pioneer BDR-206. I know Mike said 'all' Pioneer drives will be supported but I saw some older posts saying that only 208 or higher are UHD compatible. I'm still within my return window so wondering if I should return or hold onto it?
Post by MartyMcNuts » Sat Aug 23, 2025 11:36 pm
cheeseballs wrote: Sat Aug 23, 2025 11:13 pm This is probably a stupid question but will ask anyway-
If you want to rip UHD, return it. Even if it does get libredrive enabled, it still won't read UHD discs.
Mr_Orange
Post by Mr_Orange » Sat Aug 23, 2025 11:45 pm
Where does the BDR-212DBK sit in the pecking order? Will this ever be UHD Libredrive?
Post by MartyMcNuts » Sat Aug 23, 2025 11:49 pm
Mr_Orange wrote: Sat Aug 23, 2025 11:45 pm Where does the BDR-212DBK sit in the pecking order? Will this ever be UHD Libredrive?
It's the base model, almost the same as the 212V. It can be cross-flashed for UHD redability.
bruce_ld
Post by bruce_ld » Thu Sep 25, 2025 9:03 pm
I realize that the project of reverse engineering and bypassing the locked firmware must be extremely complex. However, I was wondering if there had been any updates on the timeline recently?
Thanks so much, mike!
-Bruce
pronouns: she/he
socdaemon
Post by socdaemon » Fri Sep 26, 2025 1:41 am
+1, just here to share my appreciation for this effort! I'm patiently waiting for a way to unlock my BDR-XD08B for UHD :D
Thank you!!
DarkFiber
Post by DarkFiber » Sat Oct 04, 2025 2:46 pm
Same here. I'm under no illusions that this will be a trivial hack, but it's almost exactly 5 months now, without any sort of update.
Is this still underway? Thanks! :)
Voxelium
Post by Voxelium » Sun Oct 05, 2025 11:12 am
I stumbled across the following thread:
https://www.reddit.com/r/makemkv/commen ... t/nhi6gvh/
According to Billy, it looks like the wait is almost over. Fingers crossed my XS07S is compatible!
• LG WH16NS60 (x2)
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• PANASONIC SW-9576-C
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
ttubbs
Post by ttubbs » Sat Oct 11, 2025 4:30 am
Any more news on this? I already have an Asus BW-16D1HT and an LG slim. I would love to add a Pioneer to the lot.
Voxelium
Post by Voxelium » Sun Oct 12, 2025 2:23 pm
ttubbs wrote: Sat Oct 11, 2025 4:30 am Any more news on this? I already have an Asus BW-16D1HT and an LG slim. I would love to add a Pioneer to the lot.
Check that Reddit thread in the reply I made above yours.
• LG WH16NS60 (x2)
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
ChameleonScales
Post by ChameleonScales » Sun Oct 12, 2025 6:34 pm
Thank you so much for doing God's work.
I have a noob question : will this lift some hardware restrictions that some drives have? Specifically, I have a BDR-XS07UHD which requires specific Intel CPU and GPU tech but my PC has an AMD Ryzen 9 CPU + Nvidia 4090.
Post by MartyMcNuts » Mon Oct 13, 2025 1:42 am
ChameleonScales wrote: Sun Oct 12, 2025 6:34 pm Hi,
Hardware restrictions for what? If you are talking about UHD disc playback, although direct UHD disc playback is not recommended, it can be done on any decent spec PC (including yours) using any UHD compatible libredrive enabled drive via an unofficial player such as VLC, MPC_HC, Jriver, etc once integrated with MakeMKV.
