Pioneer c 43889
ianson51
Pioneer c 43889
Post by ianson51 »
Hi,I have this drive,is this crossflashashed or do you use a decrypted version of the drives firmware version
Re: Pioneer c 43889
Insufficient information.
Did you try searching for "pioneer 43889", and looking at the dozens of messages about that drive already on the board?
ianson51
Re: Pioneer c 43889
Post by ianson51 »
My drive is a pioneer c43889 UD03 1.14,with what ive read i do believe this needs cross flashed with a UD04 firmware of which i strugle to find to be able to read and rip 4k uhd.but cant find this files anywhere,nor the procedure to do such a flashing process please could you help.
Re: Pioneer c 43889
ianson51 wrote: Mon Oct 20, 2025 2:17 pm My drive is a pioneer c43889 UD03 1.14,with what ive read i do believe this needs cross flashed with a UD04 firmware of which i strugle to find to be able to read and rip 4k uhd.but cant find this files anywhere,nor the procedure to do such a flashing process please could you help.
I think you mean it's a Verbatim 43889 that contains a Pioneer BDR-UD03 inside. Yes, it needs to be cross-flashed to BDR-UD04 firmware for UHD comaptibility. Contact Billycar11 and provide the MakeMKV drive info & libredrive info sections.
Re: Pioneer c 43889
Just posting my info thanks Marty
cricketgla
Re: Pioneer c 43889
Post by cricketgla »
Hi Billycar11,
I wonder if I could also trouble you for this please? I have a Verbatim 43889 that contains a Pioneer BDR-UD03. Drive spec from MakeMKV below. Many thanks
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
Re: Pioneer c 43889
cricketgla wrote: Mon Nov 03, 2025 12:19 pm Hi Billycar11,
OS device name: E:
Revision: 1.14
PM sent.
cricketgla
Re: Pioneer c 43889
Received PM. Many thanks - much appreciated.
