Pioneer BDR-UD03 UHD possibility
Rychotech
Re: Pioneer BDR-UD03 UHD possibility
I am in the same boat with this drive. Got all my standard BluRays ripping OOB, but UHD doesn't read (as expected). Based on the rest of the forum, I think this should be able to be updated, but needing a bit of guidance on that. Not sure which forum rabbit hole I should be in since it is already LibreDrive compatible, but doesn't support UHD OOB.
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Highest AACS version: 50
Drive platform: RS8511
Firmware version: 1.14
Revision: 1.14
Serial number:
PM sent.Rychotech wrote: Sun Oct 12, 2025 8:29 pm I am in the same boat with this drive. Got all my standard BluRays ripping OOB, but UHD doesn't read (as expected). Based on the rest of the forum, I think this should be able to be updated, but needing a bit of guidance on that. Not sure which forum rabbit hole I should be in since it is already LibreDrive compatible, but doesn't support UHD OOB.
Revision: 1.14
Serial number:
PLE04
I just discovered this thread here while looking for why my external Verbatim Blu-ray drive can't read 4K UHD discs. It is also a Pioneer BDR-UD03 drive.
Here is the drive info:
OS device name: /dev/sr0
Revision: 1.14
Serial number: ALDL44xxxxxx
Highest AACS version: 81
Unrestricted read speed: Yes-
PM is coming.PLE04 wrote: Mon Oct 13, 2025 12:41 pm I just discovered this thread here while looking for why my external Verbatim Blu-ray drive can't read 4K UHD discs. It is also a Pioneer BDR-UD03 drive.
Drive Information OS device name: /dev/sr0 Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: ALDL44xxxxxx Firmware date: 2020-06-15 Bus encryption flags: 1B Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
PLE04
Thanks. I will try it tomorrow on my Windows box.
potus
CooperVid,
In need of your assistance, having this verbatim external drive; Eagerly awaiting your PM. Thanks in advance!
-POTUS
-POTUS
gartaga1998
Здравстуйте можно ли как-то помочь? чтобы можно было читать UHD BLUE RAY
OS device name: E:
Revision: 1.05
Serial number: QEDL054237WL
Firmware date: 2015-11-24
Drive platform: RS8510
Firmware version: 1.05
OS device name: E:
Revision: 1.05
x10bulls
Good day, I also need assistance in my BDR-UD03FAL to read ultraHD - anyone can help please?
You need to post your Makemkv info.potus wrote: Tue Oct 14, 2025 4:50 am CooperVid,
-POTUS
Post your Makemkv info.x10bulls wrote: Tue Oct 14, 2025 8:54 am Good day, I also need assistance in my BDR-UD03FAL to read ultraHD - anyone can help please?
KC3577
I also have the drive and need support
Laufwerksinformation
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.11
Seriennummer: SEDLXXXXXXXXX
Firmware-Datum: 2018-11-28
Makierungen der Bus-Verschlüsselung: 1B
Firmware version: 1.11
WonderMage
Hi Coopervid, I have a Pioneer BDR-UD03 from a Verbatim 43890 and would love to flash it for UHD rips. Thank you and the crew here that helps us out. Here are the specs ...
OS device name: E:
Revision: 1.14
Serial number: ...
Highest AACS version: 68
OS device name: E:
Revision: 1.14
Serial number: ...
PM sent.gartaga1998 wrote: Tue Oct 14, 2025 6:55 am Здравстуйте можно ли как-то помочь? чтобы можно было читать UHD BLUE RAY
OS device name: E:
Revision: 1.05
PM sent.KC3577 wrote: Tue Oct 14, 2025 2:19 pm Hi,
Laufwerksinformation OS-Gerätename: D: Produzent: PIONEER Produkt: BD-RW BDR-UD03 Revision: 1.11 Seriennummer: SEDLXXXXXXXXX Firmware-Datum: 2018-11-28 Makierungen der Bus-Verschlüsselung: 1B Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.11 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
PM sent.WonderMage wrote: Wed Oct 15, 2025 5:15 am Hi Coopervid, I have a Pioneer BDR-UD03 from a Verbatim 43890 and would love to flash it for UHD rips. Thank you and the crew here that helps us out. Here are the specs ...
OS device name: E:
Revision: 1.14
Serial number: ...
