AACS v82 submission - Touché Turtle and Dum Dum (Hanna-Barbera)
mickhyperion
Re: AACS v82 submission - Touché Turtle and Dum Dum (Hanna-Barbera)
Post by mickhyperion » Sun Oct 12, 2025 6:54 pm
The only additional thing I did to get the discs to work was change the name of the downloaded .cfg file from keydb.cfg to KEYDB.cfg since it was mentioned in the instructions that the naming for Mac is probably case-sensitive. Good luck!
Corey B
Post by Corey B » Sun Oct 12, 2025 8:48 pm
Thanks I'll give that a try
Corey B
Post by Corey B » Mon Oct 13, 2025 5:19 am
Thank you so very much for your time and patience in helping me out. I really appreciate you guys very much.
What I had to do to get this to work was in fact to change the name of the cfg from keybd.cfg to KEYDB.cfg as suggested and it worked wonderfully.
Thanks again
Corey B
Post by Corey B » Mon Oct 13, 2025 2:42 pm
Thank you MrPenguin I appreciate your time and help.
