marcellobuddy
#3196 Post by marcellobuddy » Fri Oct 10, 2025 8:50 am
This is an extremely helpful guide. Thanks Billy. I’m new to this hobby, so to clarify and make sure im understanding correctly—it seems possible to flash an LG Drive on MacOS, but that requires terminal commands, while on the other hand, doing so on Windows is a bit more straightforward, using the SDF Flasher program? I ask only because i have both a PC and a Mac, and I am deciding which is best to flash with. Also, if i flash the LG Drive on my PC, will i still be able to use the drive with makeMKV on my Mac? Thanks again for your time and help :)
#3197 Post by dcoke22 » Fri Oct 10, 2025 1:45 pm
marcellobuddy wrote: Fri Oct 10, 2025 8:50 am This is an extremely helpful guide. Thanks Billy. I’m new to this hobby, so to clarify and make sure im understanding correctly—it seems possible to flash an LG Drive on MacOS, but that requires terminal commands, while on the other hand, doing so on Windows is a bit more straightforward, using the SDF Flasher program? I ask only because i have both a PC and a Mac, and I am deciding which is best to flash with. Also, if i flash the LG Drive on my PC, will i still be able to use the drive with makeMKV on my Mac? Thanks again for your time and help :)
Yes, terminal commands on Mac but you can use the SDFtool GUI on Windows. Once the drive is flashed, it'll work on Mac or Windows.
StarForce
#3198 Post by StarForce » Fri Oct 10, 2025 11:58 pm
Hello everyone. I have two ASUS BW-16D1HT drives. One in a computer running Windows 7 64-bit and the other in a fully updated Windows 11 computer. The first time I used one of my drives, I updated it without realizing it was a mistake because it sabotaged the ability to copy UltraHD Blu-ray discs, so I didn't update the second drive. With both, I've been able to back up some of my Blu-ray movies thanks to MakeMKV. Yesterday, I tried to copy UltraHD Blu-ray discs for the first time, and neither drive was even able to read them.
These are the drive details:
In Windows 7 64-bit:
https://i.ibb.co/vx0j0nMr/ASUS-BW-16-D1-HT-on-W7.png
In Windows 11:
https://i.ibb.co/jvq4wBTW/ASUS-BW-16-D1-HT-on-W11.png
Today I was determined to use the method described here, so I've been reading several posts and I'm scared. I don't know if I'll be able to do it correctly. I'm afraid of rendering my drives unusable. From what I understand, each of my drives seems to require a different method. It's driving me crazy. If someone would be so kind as to give me some specific instructions, please do. Thank you very much.
#3199 Post by MartyMcNuts » Sat Oct 11, 2025 1:13 am
StarForce wrote: Fri Oct 10, 2025 11:58 pm Hello everyone. I have two ASUS BW-16D1HT drives. One in a computer running Windows 7 64-bit and the other in a fully updated Windows 11 computer. The first time I used one of my drives, I updated it without realizing it was a mistake because it sabotaged the ability to copy UltraHD Blu-ray discs, so I didn't update the second drive. With both, I've been able to back up some of my Blu-ray movies thanks to MakeMKV. Yesterday, I tried to copy UltraHD Blu-ray discs for the first time, and neither drive was even able to read them.
In Windows 11:
You need to flash both of your drives to enable UHD readability. Just use the SDFtool Flasher on your Windows 11 64 bit PC. The method is exactly the same and you can flash both of them to BW-16D1HT 3.10-MK. viewtopic.php?f=16&t=22896
ElJaard
#3200 Post by ElJaard » Sun Oct 12, 2025 10:32 am
Does flashing UHD friendly firmware to a new drive void its warranty? Or does that depend on the drive manufacturer? I have an Asus drive. Am I able to flash the original firmware back if I read it with the flashing software before writing any other firmware and write it back later on before sending the unit to warranty repair if required in the future?
#3201 Post by Billycar11 » Sun Oct 12, 2025 1:57 pm
ElJaard wrote: Sun Oct 12, 2025 10:32 am Does flashing UHD friendly firmware to a new drive void its warranty? Or does that depend on the drive manufacturer? I have an Asus drive. Am I able to flash the original firmware back if I read it with the flashing software before writing any other firmware and write it back later on before sending the unit to warranty repair if required in the future?
If you in the USA no they would have to prove the flashing caused damage.
Other parts of the world idk
Either way you can just flash it back to stock before you send it in and they won't know
rs1984
#3202 Post by rs1984 » Mon Oct 13, 2025 7:47 pm
Hello, I'm new here and would like to flash my drive LG drive to this firmware BU40N 1.03MK but i can not find the firmware
#3203 Post by d00zah » Mon Oct 13, 2025 10:06 pm
rs1984 wrote: Mon Oct 13, 2025 7:47 pm Hello, I'm new here and would like to flash my drive LG drive to this firmware BU40N 1.03MK but i can not find the firmware
Welcome! It's helpful to provide the output from MakeMKV's Drive Info/LibreDrive Info sections to avoid mistakes.
That said, from the 1st post of this topic...
The only flasher anyone should be using now is Martys SDF GUI it now has built in safety's still check out the requirements and follow the recommending firmware but it shouldn't let you brick an old drive and should detect if the firmware is encrypted automatically
New! The all you need firmware pack: https://drive.google.com/file/d/1HRnbXi ... sp=sharing
New! GUI SDF tool: viewtopic.php?f=16&t=18933
By: MartyMcNuts
sixsunn_
#3204 Post by sixsunn_ » Tue Oct 14, 2025 10:25 am
Hey ! Also new here, there's a lot of information around and I'm still having doubts about whether or not my drive is checking all the boxes to be flashed. I keep finding posts about kinda-similar-but-not-quite-the-same-drive-specs so I was wondering if anyone would be able to tell me for sure.
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E412
Firmware date: 2019-03-07
Highest AACS version: 81
Firmware version: ID44
Also, thank you for all the work, this software rules and it's mindblowing seeing a forum this active nowadays !
Cheers !
#3205 Post by Billycar11 » Tue Oct 14, 2025 2:27 pm
sixsunn_ wrote: Tue Oct 14, 2025 10:25 am Hey ! Also new here, there's a lot of information around and I'm still having doubts about whether or not my drive is checking all the boxes to be flashed. I keep finding posts about kinda-similar-but-not-quite-the-same-drive-specs so I was wondering if anyone would be able to tell me for sure.
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E412
Cheers !
Yes it can do uhd email me that drive info section
See below for contact info
marcellobuddy
#3206 Post by marcellobuddy » Wed Oct 15, 2025 3:10 am
dcoke22 wrote: Fri Oct 10, 2025 1:45 pm
ChickenFarmerMA
#3207 Post by ChickenFarmerMA » Wed Oct 15, 2025 7:57 pm
Just wanted to offer advice in case you're having issues with your drive not reading discs suddenly. My LG WH16NS60 stopped reading after some read/opening errors on a with one disc and then wouldn't open a disc I was just using. A power cycle didn't rectify so figured I'd try using the SDF Tool to recover the drive using the firmware provided (from here). That worked perfectly.
Last edited by ChickenFarmerMA on Wed Oct 15, 2025 10:32 pm, edited 1 time in total.
Mr_Orange
#3208 Post by Mr_Orange » Wed Oct 15, 2025 9:42 pm
ChickenFarmerMA wrote: Wed Oct 15, 2025 7:57 pm Just wanted to offer advice in case you're having issues with your drive not reading discs suddenly. My LG WH16NS60 stopped reading after some read/opening errors on a with one disc and then wouldn't open a disc I was just using. A power cycle didn't rectify so figured I'd try using the SDK Tool to recover the drive using the firmware provided. That worked perfectly.
Are you referring to the SDF Flasher Tool from this site or an official LG tool?
ChickenFarmerMA
#3209 Post by ChickenFarmerMA » Wed Oct 15, 2025 10:32 pm
whoops, typo on the name, but the stuff from here.
Mr_Orange
#3210 Post by Mr_Orange » Thu Oct 16, 2025 12:19 am
ChickenFarmerMA wrote: Wed Oct 15, 2025 10:32 pm whoops, typo on the name, but the stuff from here.
Thanks for confirming.
I'll try this with my LG BH16NS55 which is cross flashed to the WH16NS60 1.02MK firmware.
