Unable to rip Fantastic Swords & Furious Warriors UK Blu-ray
TK421
Post by TK421 »
Hi
I am unable to rip this Blu-ray and have emailed the file dump already.
This is what I am getting:
MakeMKV v1.18.2 win(x64-release) started
Using LibreDrive mode (v06.3 id=866A98CB9C4E)
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?Bp5OeilJOqw2FA...
Saved AACS dump file as .MakeMKV/MKB_v82_FURIOUS_SWORDS_D1_AB5A.tgz
This is my Info:
Product: BD-RE BU40N
Revision: 1.03
Serial number: XXXXX
Highest AACS version: 82
Firmware version: 1.03
Disc Information
Label: FURIOUS SWORDS D1
Timestamp: 2025-08-20 20:28:49
Protection: AACS v82
Data capacity: 44.33 Gb
Disc type: BD-ROM
Number of layers: 2
Thanks for your help!
Re: Unable to rip Fantastic Swords & Furious Warriors UK Blu-ray
TK421 wrote: Sun Oct 12, 2025 10:30 am Hi
This is my Info:
Revision: 1.03
Disc Information
Disc type: BD-ROM
Number of layers: 2
The standard process is the first point below:
  • Email the generated tgz dump file to svq@makemkv.com so that MakeMKV can derive the key and add it to their internal hashed keys.
  • So now that you have emailed the dump, if you also would like to help the community, first download the latest public KeyDB zip file and extract it to the MakeMKV data directory (where the dumps are locted). After doing this, restart MakeMKV. If you still cannot rip the disc, make a post providing:
    • the full name of the dump file.
    • a download link for the dump file after you have hosted it somewhere.
TK421
Post by TK421 »
MartyMcNuts wrote: Mon Oct 13, 2025 10:04 am
This is my Info:
Revision: 1.03
Disc Information
Disc type: BD-ROM
Number of layers: 2
Great! All working now! :D Thanks for that.
