Flashed LG WP50NB40 (NB52) but get "No disc inserted" with UHD
lesty
#1 Post by lesty » Sun Oct 12, 2025 1:32 am
Hello, I recently got this drive and tried my best to follow the tutorial on the site to flash my drive. I used the SDFtoolflasher to flash BP50NB40-NB50-1.03MK then flashed BP50NB40-NB50-1.03MK with bootloader box checked and then BP60NB10 1.00_HBD (from Marty). Unfortunately my drive can't seem to read the UHD disc I have. It reads normal Blu-rays fine. it seems to just be a problem with UHD discs. I just bought this disc and tested it in my PS5 and it seems to work fine unfortunately it's the only disk i have to test at the moment. I'm not sure if I flashed the drive wrong so i've included the MakeMKV info i get when the disc is inserted. Any help or suggestions would be much appreciated.
OS device name: H:
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: SIM22213K5359
Highest AACS version: 23
Firmware version: 1.03
Re: Flashed LG WP50NB40 (NB52) but get "No disc inserted" with UHD
#2 Post by Billycar11 » Sun Oct 12, 2025 1:58 pm
lesty wrote: Sun Oct 12, 2025 1:32 am Hello, I recently got this drive and tried my best to follow the tutorial on the site to flash my drive. I used the SDFtoolflasher to flash BP50NB40-NB50-1.03MK then flashed BP50NB40-NB50-1.03MK with bootloader box checked and then BP60NB10 1.00_HBD (from Marty). Unfortunately my drive can't seem to read the UHD disc I have. It reads normal Blu-rays fine. it seems to just be a problem with UHD discs. I just bought this disc and tested it in my PS5 and it seems to work fine unfortunately it's the only disk i have to test at the moment. I'm not sure if I flashed the drive wrong so i've included the MakeMKV info i get when the disc is inserted. Any help or suggestions would be much appreciated.
OS device name: H:
Revision: 1.03
Because it's not flashed right
Follow the guide again
lesty
#3 Post by lesty » Sun Oct 12, 2025 11:47 pm
I got it working with MartyMcNuts's guide:
viewtopic.php?f=16&t=22896
I forgot to use recover mode 🤦
Thanks Marty!
