Hello Makemkv team,
As mentioned above, I'm having trouble reading the discs.
It seems to be because of v82. What can I do to read them?
I need help, please.
F1, 28 Years Later, Jurassic World Rebirth
Re: F1, 28 Years Later, Jurassic World Rebirth
New blu-rays using the most recent version of encryption, AACS v82, are a little different than older blu-rays. For now, when MakeMKV encounters an AACS v82 disc for which it does not have a decryption key, it produces a dump file (just like when you try to rip a 4K UHD disc for which there is not a decryption key). You should email the dump file to svq@makemkv.com. A decryption key will eventually be created and MakeMKV will download it when necessary.
Additionally, you can configure MakeMKV to use a different source of decryption keys, the keydb. Public KeyDB Disc Submissions
If the necessary keys for your discs are not in the keydb, host the dumps MakeMKV produces online somewhere (Google Drive, One Drive, etc.) and post a link to them. The folks running the keydb will use the dumps to produce a decryption key assuming your optical drive creates compatible dumps (The Pioneer UD04 produces the least compatible dumps).
Re: F1, 28 Jahre später, Jurassic World Rebirth
Hello, I have already extracted key dB into the folder. But unfortunately has no success either. I don't have one drive or anything like that. Can I choose another way to post the dump files?
there are many free hosting sites. Mediafire is a good one.
JurassicBerk
Jurassic Park Rebirth
https://www.mediafire.com/file/k0ofe3lw ... E.tgz/file
ASUS BW-16D1HT drive, latest keydb.cfg
mazterjedi
So, the tgz file...what do you do with it?
If you know how to extract a key from it, you can do that. Otherwise, like me, you ignore it and let those who CAN generate keys do so. Typically, there are only 3 or 4 people who will download the TGZ file and work to update the master key files at keydb...So, the tgz file...what do you do with it?
