Buffalo BRXL-PT6U2VB firmware options
woekitten1701
Based on recommendations in another thread I decided to get a Buffalo BRXL-PT6U2VB as a secondary UHD drive, as my primary WH16NS40 (flashed to WH16NS60 1.02MK per the flashing guide) very rarely has a problem with some UHD discs and hash errors and I wanted a drive of substantially different construction to handle those edge cases.
I first flashed it with HL-DT-ST-BD-RE_BU40N-BN12-0M01001-211905141415.bin from the BU40N-B-Japan-Buffalo folder in the mk-firmware-pack-20200720.zip archive, as the model I received was BN12 with the matching stock 211905141415 firmware, and I wasn't sure if I first needed to do that before flashing to other firmwares. I would appreciate knowing if this step was even necessary. Since it didn't require encrypted firmware I'm thinking it might not have been. As others have indicated in other threads, with that firmware, it did not detect UHD discs ("No disc"), so I then flashed to the latest HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin in the BU40N-N-Main folder. At this point UHD detection and reading worked fine.
However, I saw that the flashing guide recommends BU40N be flashed to 1.03MK, which per "The all you need firmware pack" means HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin, which is located in the "old" folder in the mk-firmware-pack-20200720.zip archive. Furthermore, I saw some posts in some threads where people recommend flashing the 1.00 "DE" firmware, which I understand to be original unpatched firmware. I found "DE_LG_BU40N_1.00.bin" and flashed that, and that also detects UHDs and reads them fine. This is what I'm using now.
So, I'm just trying to wrap my head around which firmware is "best", or even how one determines that. Why would I pick 1.03MK over 1.04MK? Why would I pick 1.00 "DE" over either of those?
(As an aside, while neither B&H nor Amazon's listings for the BRXL-PT6U2VB list UltraHD compatibility, the actual product box I received prominently advertises UltraHD capability on the front of the box. I did confirm that the model number is correct and I didn't accidentally get a different model. Makes me wonder why the patched BN12 firmware that matched my model didn't even see UHD. I neglected to try reading any UHD discs with the stock firmware, as I didn't expect it to work, and didn't notice the box details until later.)
Re: Buffalo BRXL-PT6U2VB firmware options
1. Stock 1.04 is an encrypted firmware. 1.04 MK removes the encryption but it is still a rubbish firmware and not recommended.woekitten1701 wrote: ↑Sun Jun 20, 2021 2:03 amBased on recommendations in another thread I decided to get a Buffalo BRXL-PT6U2VB as a secondary UHD drive, as my primary WH16NS40 (flashed to WH16NS60 1.02MK per the flashing guide) very rarely has a problem with some UHD discs and hash errors and I wanted a drive of substantially different construction to handle those edge cases.
2. It really depends on what software you use and whether or not you want a patched firmware. 1.03 MK works fine with MakeMKV but DE 1.00 also works fine with MakeMKV plus other software such as DVDFab.
I would stick with DE 1.00. (This is the firmware I install on all BU40N drives)
Thank you so much for sharing your experience. It was helpful for me to know which firmware to flash in order to burn BD-R XL (100 GB) discs.
I respectively a friend have an issue with a BRXL-PT6U2VB.
It's declared as a UHD 4K Drive and I wanted to flash it for him to 1.03MK but the flasher says it's no MT1959 and MakeMKV shows this:
Laufwerksinformation
OS-Gerätename: F:
Produzent: BUFFALO
Produkt: Optical Drive
Revision: 1.00
Serienummer: WR51 724971
Highest AACS version: 82
No Libre Drive information!
And no 4K disk is recognized with the Windows Explorer. DVD and BD no problem, lenses are cleaned.
The serial number of the drive and the package is the same. How can a non MT1959 be declared as a 4K drive?
OS-Gerätename: F:
Produzent: BUFFALO
Revision: 1.00
No one have an idea?zittrig wrote: ↑Thu Oct 09, 2025 7:06 pmI respectively a friend have an issue with a BRXL-PT6U2VB.
OS-Gerätename: F:
Produzent: BUFFALO
Revision: 1.00
BDXL doesn't mean UHD compatible. Where does it say UHD compatible?zittrig wrote: ↑Sat Oct 11, 2025 3:15 amNo one have an idea?zittrig wrote: ↑Thu Oct 09, 2025 7:06 pmI respectively a friend have an issue with a BRXL-PT6U2VB.
OS-Gerätename: F:
Produzent: BUFFALO
Revision: 1.00
It has the regular Red-White-Package with "Buffalo Blu-ray Burner UltraHD 4K & 3D Media Playback" on it.Coopervid wrote: ↑Sat Oct 11, 2025 10:08 amBDXL doesn't mean UHD compatible. Where does it say UHD compatible?zittrig wrote: ↑Sat Oct 11, 2025 3:15 amNo one have an idea?zittrig wrote: ↑Thu Oct 09, 2025 7:06 pmI respectively a friend have an issue with a BRXL-PT6U2VB.
OS-Gerätename: F:
Produzent: BUFFALO
Revision: 1.00
Have you checked another USB port or another PC with this drive. Maybe it will then display the drive patform MT1959. If not then they most likely chave changed the chip and kept the old packaging showing now incorrect info.
Naah, I think I have found the problem. The SN which is shown with MakeMKV is another like on the drive / on the package.
Could I have noticed earlier...
Bad luck, I think.
Could it be that the former owner had made flashing games?!
Bad luck, I think.
If it's a used one he has used the package of another drive.
No, I don't think so, the SN off the drive is the same like on the package.
I've informed my friend, he have to communicate this with the seller.
Thanks at this point, Coopervid!
