Dump Submitted - MKB20_v82_Jurassic_World_Rebirth_3F4A (Australia)
gibbon
Post by gibbon »
Sadly doesn't seem to be in keydb.cfg either (I get [MakeMKV SUPPORTED]: FALSE in KeyDB Helper)
gibbon
Re: Dump Submitted - MKB20_v82_Jurassic_World_Rebirth_3F4A (Australia)
Post by gibbon »
Sorry, I should have mentioned also that I only have Pioneer drives, so I think that means I can't submit it for KeyDB either, unfortunately.
Dump file is here if anyone wants to have a crack
https://drive.google.com/file/d/1Omvlug ... sp=sharing
Drive is a Pioneer BDR-S12U
keydb_helper
Post by keydb_helper »
gibbon wrote: Thu Oct 09, 2025 12:06 pm Sorry, I should have mentioned also that I only have Pioneer drives, so I think that means I can't submit it for KeyDB either, unfortunately.
Hey gibbon, the 3F4A variant of Jurassic World Rebirth has been added to the public keydb. You were lucky as a user with an LG BH16NS55 was able to provide a suitable disc dump.
You are correct that your S12U cannot be used to generate an entirely new record for the keydb. But disc dumps created with your drive can be used to create a new record if and only if the corresponding media key is already in the keydb. This can occur due to media key reuse between different regions or retail variants.
Public KeyDB Disc Submissions
KeyDB Download
gibbon
Post by gibbon »
Oh, perfect! Many thanks. Thanks also for the info, much appreciated.
