No Dash icon in Gnome/Debian 13
fawtytoo
#1 Post by fawtytoo » Sat Oct 04, 2025 8:30 pm
Debian 13 is using Wayland rather than XWayland, so only a default icon is showing in the Gnome Shell panel. MakeMKV doesn't appear to have a WMClass so editing the .desktop file doesn't work.
16442496
Re: No panel icon in Gnome/Debian 13
#2 Post by 16442496 » Mon Oct 06, 2025 6:05 am
You can't put any icons on Gnome's top panel.
You can drag & drop to Dash.
Debian
MakeMKV 1.17.6 (Registered)
DVD to MKV only.
fawtytoo
#3 Post by fawtytoo » Mon Oct 06, 2025 9:23 am
Sorry. I'm using an extension. D'oh!
But the same applies to the App/Window switcher. Only a default icon.
16442496
#4 Post by 16442496 » Thu Oct 09, 2025 10:11 am
Just on idea. Have you try to update icon cache?
I tested MakeMKV 1.18.2 on Debian 13 Gnome (Vanilla)
And there wasn't makemkv icon. Just some weird gear logo with MakeMKV text under it.
I update icon cache and icon appears.
gtk-update-icon-cache /usr/share/icons/hicolor
Debian
DVD to MKV only.
fawtytoo
#5 Post by fawtytoo » Thu Oct 09, 2025 10:23 am
Ok, I tried that but no change. Oddly too is that the App switcher shows "Unknown" as the name.
The icon and name does show correctly in the Apps grid but no running app dot (when running of course).
16442496
#6 Post by 16442496 » Thu Oct 09, 2025 11:36 am
Debian
DVD to MKV only.
fawtytoo
#7 Post by fawtytoo » Thu Oct 09, 2025 11:47 am
No, it's Rocket Bar. But disabling extensions completely makes no difference.
The problem exists in Gnome's App switcher and in the Dash. The same issue applies to Transmission. I fixed Transmission by adding:
StartupWMClass=com.transmissionbt.transmission_66307_40115421
... but MakeMKV doesn't seem to have a WMClass. At least, using Looking Glass (LG) reports "null".
With Debian 13, Wayland requirements for this type of thing need to be done differently compared to Debian 12 as Wayland no longer supports X (or something like that).
16442496
Re: No Dash icon in Gnome/Debian 13
#8 Post by 16442496 » Thu Oct 09, 2025 1:13 pm
I think i see it now. :)
I installed that "Rocket Bar" extension. Looks nice.
It shows right away icons that i have on DASH. MakeMKV too.
But Transmission logo. It acting weird on Rocket bar and DASH.
When i open Transmission. RB and DASH shows that gear icon with a dot.
When i log out and change from Wayland to X11, all icons, bars dashes etc... works as they should.
I don't know how to fix it. Maybe someone on Debian User Forums knows.
Bug in Debian/Gnome/Wayland, don't know.
Debian
DVD to MKV only.
