Strange issues
Bsmooth
Strange issues
Post by Bsmooth »
I got an announcement that there was a new version of Make MKV. As soon as I saw that my drive can't seem to read Blu-rays any longer. I tried several different ones and none of them work. they seem to be reading , but the drive never seems to stop, sometime reading chapters equalling 35 GB, sometimes only 169 MB.
It worked fine a few days ago, I don't understand whats going on.
BTW I bought the drive through a member from here, and its been working great.
Could it be Make MKV, or do you think the drive is suspect? I've only had the drive since Feb of this year, it couldn't have worn out already could it?
Bsmooth
Re: Strange issues
Post by Bsmooth »
Updated to latest version and still can't do a thing. Program seems to react different everytime. This is the last message I got when I tried to use MakeMKV: Now this was running fine two days ago.
MakeMKV v1.18.2 win(x64-release) started
Error 'OS error - The I/O device reported an I/O error' occurred while issuing SCSI command A30..00200540200520..09A401B6DD3CA9FAF38EA78723360558A60 to device 'SPTI:\Device\CdRom0'
File 00007.mpls was added as title #0
Title #00008.mpls has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '1505280'
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '1585152'
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '1861632'
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '3280896'
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '3416064'
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '3600384'
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '4503552'
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '4552704'
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '4804608'
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '4853760'
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '6291456'
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '6322176'
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '6973440'
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8976384'
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '9080832'
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '9172992'
Failed to decode audio/video data for title #1 - invalid mux or internal error, title skipped.
Title #00100.mpls was skipped
File 00013.m2ts was added as title #1
Title #00999.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00024.m2ts' at offset '884736'
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00024.m2ts' at offset '6094848'
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00024.m2ts' at offset '6291456'
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00024.m2ts' at offset '6395904'
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00024.m2ts' at offset '6488064'
File 00024.m2ts was added as title #2
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '2230272'
Failed to decode audio/video data for title #3 - invalid mux or internal error, title skipped.
Title #00001.m2ts was skipped
Title #00901.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00900.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00022.m2ts was added as title #3
File 00021.m2ts was added as title #4
File 00020.m2ts was added as title #5
Title #00008.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00019.m2ts was added as title #6
Re: Strange issues
Does the drive not work even for discs you've already ripped?
Hopefully you didn't change the firmware on your drive.
Did you install any Windows updates at the same time?
Bsmooth
Re: Strange issues
Post by Bsmooth »
Basically I found with some help from a member here, that the lasers might have been dirty. So after a little disassembly and a little alcohol and q-tips I cleaned them. Now it works fine, I just don't know for how long. After a little research online it appears the laser may need to be cleaned about every 6 months to 2 years. Your mileage may vary. I have to say visually it didn't look that dirty.
The drive would not work on any disc. Didn't change the firmware, and no window updates.
So If your drive starts acting up, it appears for no reason at all, the lasers just possibly may be dirty.
PaulloingGO
Re: Strange issues
Post by PaulloingGO »
Thanks for sharing! Surprising how often a laser clean fixes issues. Mine looked fine too, but I’ll consider cleaning before panicking about firmware. Was it easy to access without risking damage?
Bsmooth
Re: Strange issues, lasers are dirty
Post by Bsmooth »
These are the instructions I got, please add or comment If incorrect.
Pioneer Blu-Ray Drive Laser Cleaning
1.) eject tray.
2.) unplug drive with tray out.
3.) pop off front bezel clips on sides and bottom with plastic tool.
4.) undo screws from bottom will be under stickers if you have an s13, 213 does not have stickers.( Mine is BDR-213 )
5.) flip back over and remove top cover.
6.) clean lasers with a lint free cloth or Qtip and 91%-99% alcohol and dry with another do this 2 times and do not let it air dry you must remove the residue with a dry one!
