PepoAviles
Re: SDFtool Flasher
Post by PepoAviles »
Am I able to flash my new Drive?
Re: SDFtool Flasher
PepoAviles wrote: Tue Sep 30, 2025 7:21 am Am I able to flash my new Drive?
It is a BU40N. Follow the instructions in the Ultimate UHD Drives Flashing Guide.
Bravo5
Re: SDFtool Flasher
Post by Bravo5 »
It was well known that it was possible to flash a DVD-ROM for copies of a popular console,
but I didn't know how to flash a Blu-ray burner to make copies and remuxes of a UHD. :D
I flashed my Asus in less than a minute with this fantastic tool, using DE_ASUS_BW-16D1HT_3.10_MK.bin
You guys are the next level, The Next.
I'll buy a license soon, it's the least I can do.
Thank you for your work.
Re: SDFtool Flasher
Bravo5 wrote: Sun Oct 05, 2025 8:50 pm It was well known that it was possible to flash a DVD-ROM for copies of a popular console,
You are welcome! :D
mattwest715
Re: SDFtool Flasher
Post by mattwest715 »
I'm having some issues with the BU40N download. No hyperlinks appear to be working for me except the "All you need firmware pack" that mentions the slim. is that the firmware to use? i'm on MacOS if that helps
aceland07
Re: SDFtool Flasher
Post by aceland07 »
I am attempting to flash my disc drive. When I press the start button, nothing happens.
sn0wleo
Re: SDFtool Flasher
Post by sn0wleo »
I just Got a BD-RE BU40N drive revision 1.05 libe drive information says Status: Possible noot yet enabled drive platform: MT1959. Can i flash this drive with one of the firmware provided here and which one should i flash ?
Re: SDFtool Flasher
sn0wleo wrote: Tue Oct 07, 2025 7:31 pm I just Got a BD-RE BU40N drive revision 1.05 libe drive information says Status: Possible noot yet enabled drive platform: MT1959. Can i flash this drive with one of the firmware provided here and which one should i flash ?
Just follow the instructions in the Ultimate UHD Drives Flashing Guide.
Re: SDFtool Flasher
aceland07 wrote: Tue Oct 07, 2025 2:52 am Hi,
Is it an Archgon? If so, you should take the drive out of the enclosure and use an adapter to flash it as the new enclosure won't allow flashing.
IShallRiseAgain
Re: SDFtool Flasher
Post by IShallRiseAgain »
So, I'm confused, I appear to have flashed my LG slim BP50NB40-NB50 correctly, but it still can't read 4K UHD disks. It can still read blu-ray discs so it doesn't appear that I used the wrong firmware.
Here is drive information from MakeMKV
Product: BD-RE BP50NB40
Revision: 1.03
Serial number:
Highest AACS version: 78
Firmware version: 1.03
I used the firmware in "LG slim BP50NB40-NB50" in the all you need firmware pack. Am I missing a step in the process or something?
Oh and here is the original firmware that I dumped before flashing HL-DT-ST_BD-RE_BP50NB40_1.03_212005070917_SIM0121C52144
Re: SDFtool Flasher
IShallRiseAgain wrote: Thu Oct 09, 2025 1:35 pm So, I'm confused, I appear to have flashed my LG slim BP50NB40-NB50 correctly, but it still can't read 4K UHD disks. It can still read blu-ray discs so it doesn't appear that I used the wrong firmware.
Revision: 1.03
Serial number:
Follow the instructions in the first post. There's also a gif showing what to do.
IShallRiseAgain
Re: SDFtool Flasher
Oh thanks, I missed that step. Now it works fine.
StarForce
Re: SDFtool Flasher
Post by StarForce »
I was really worried about not doing it right, but I just used SDFtool Flasher v1.3.6 on my ASUS BW-16D1HT (v3.11 Firmware) on a Windows 11 computer and it is much easier than I thought. After choosing my drive, I first created a firmware dump of my drive with the "READ Firmware" option (which I imagine will be used for the "RECOVER Drive" option), then "WRITE Firmware" was activated, I chose "DE_ASUS_BW-16D1HT_3.10_MK.bin", clicked "START" and, finally, it can read my first Ultra HD Blu-ray, the Spanish version of "The Boy and The Heron". Thank you so much for all this knowledge and for this very useful tool. Now I will try to rip this disc and create my backup copy. Thanks again.
EDIT 1: Unfortunately, the drive was unable to read the disk, displaying a multitude of SCSI errors and a "Copy complete" message. The folder where the dump was created was only 256 KB. Any suggestions?
MakeMKV v1.18.2 win(x64-release) comenzado
Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
Haciendo backup del disco en la carpeta "D:/_ANIMACIÓN/EL CHICO Y LA GARZA"
Descargando el/los último(s) HK en C:\Users\*****/.MakeMKV ...
Error 'Error de SCSI - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' leyendo 'BD-RE ASUS BW-16D1HT 3.10 KL9N4CJ0226' en la posición '1048576'
Error 'Error de SCSI - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' leyendo 'BD-RE ASUS BW-16D1HT 3.10 KL9N4CJ0226' en la posición '1445330944'
Error 'Error de SCSI - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' leyendo 'BD-RE ASUS BW-16D1HT 3.10 KL9N4CJ0226' en la posición '1445349376'
Falló la carga del contenido de la tabla hash, no es posible verificar la integridad de los archivos M2TS.
Error 'Error de SCSI - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' leyendo 'BD-RE ASUS BW-16D1HT 3.10 KL9N4CJ0226' en la posición '655360'
Error 'Error de SCSI - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' leyendo 'BD-RE ASUS BW-16D1HT 3.10 KL9N4CJ0226' en la posición '657408'
udf: node fe/efe failed!
File "/BDMV/index.bdmv" was skipped
File "/BDMV/MovieObject.bdmv" was skipped
File "/BDMV/PLAYLIST/00009.mpls" was skipped
File "/BDMV/PLAYLIST/00008.mpls" was skipped
File "/BDMV/PLAYLIST/00007.mpls" was skipped
File "/BDMV/PLAYLIST/00006.mpls" was skipped
File "/BDMV/PLAYLIST/00005.mpls" was skipped
File "/BDMV/PLAYLIST/00004.mpls" was skipped
File "/BDMV/PLAYLIST/00001.mpls" was skipped
File "/BDMV/PLAYLIST/00003.mpls" was skipped
File "/BDMV/PLAYLIST/00002.mpls" was skipped
File "/BDMV/PLAYLIST/00000.mpls" was skipped
File "/BDMV/PLAYLIST/00014.mpls" was skipped
File "/BDMV/PLAYLIST/00013.mpls" was skipped
File "/BDMV/PLAYLIST/00011.mpls" was skipped
File "/BDMV/PLAYLIST/00015.mpls" was skipped
File "/BDMV/PLAYLIST/00010.mpls" was skipped
File "/BDMV/PLAYLIST/00012.mpls" was skipped
File "/BDMV/CLIPINF/00013.clpi" was skipped
File "/BDMV/CLIPINF/00012.clpi" was skipped
File "/BDMV/CLIPINF/00011.clpi" was skipped
File "/BDMV/CLIPINF/00015.clpi" was skipped
File "/BDMV/CLIPINF/00016.clpi" was skipped
File "/BDMV/CLIPINF/00010.clpi" was skipped
File "/BDMV/CLIPINF/00009.clpi" was skipped
File "/BDMV/CLIPINF/00008.clpi" was skipped
File "/BDMV/CLIPINF/00007.clpi" was skipped
File "/BDMV/CLIPINF/00006.clpi" was skipped
File "/BDMV/CLIPINF/00005.clpi" was skipped
File "/BDMV/CLIPINF/00004.clpi" was skipped
File "/BDMV/CLIPINF/00003.clpi" was skipped
File "/BDMV/CLIPINF/00002.clpi" was skipped
File "/BDMV/CLIPINF/00017.clpi" was skipped
File "/BDMV/CLIPINF/00001.clpi" was skipped
File "/BDMV/CLIPINF/00000.clpi" was skipped
File "/BDMV/CLIPINF/00014.clpi" was skipped
File "/BDMV/STREAM/00014.m2ts" was skipped
File "/BDMV/STREAM/00013.m2ts" was skipped
File "/BDMV/STREAM/00012.m2ts" was skipped
File "/BDMV/STREAM/00011.m2ts" was skipped
File "/BDMV/STREAM/00015.m2ts" was skipped
File "/BDMV/STREAM/00016.m2ts" was skipped
File "/BDMV/STREAM/00010.m2ts" was skipped
File "/BDMV/STREAM/00009.m2ts" was skipped
File "/BDMV/STREAM/00008.m2ts" was skipped
File "/BDMV/STREAM/00007.m2ts" was skipped
File "/BDMV/STREAM/00006.m2ts" was skipped
File "/BDMV/STREAM/00005.m2ts" was skipped
File "/BDMV/STREAM/00004.m2ts" was skipped
File "/BDMV/STREAM/00003.m2ts" was skipped
File "/BDMV/STREAM/00002.m2ts" was skipped
File "/BDMV/STREAM/00001.m2ts" was skipped
File "/BDMV/STREAM/00000.m2ts" was skipped
File "/BDMV/STREAM/00017.m2ts" was skipped
File "/BDMV/BACKUP/index.bdmv" was skipped
File "/BDMV/BACKUP/MovieObject.bdmv" was skipped
File "/BDMV/BACKUP/PLAYLIST/00010.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00012.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00009.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00008.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00007.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00006.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00005.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00004.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00003.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00002.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00000.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00014.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00013.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00011.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00015.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00001.mpls" was skipped
File "/BDMV/BACKUP/CLIPINF/00013.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00012.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00011.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00015.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00016.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00010.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00009.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00008.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00007.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00006.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00005.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00004.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00003.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00002.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00017.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00001.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00000.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00014.clpi" was skipped
File "/CERTIFICATE/id.bdmv" was skipped
File "/CERTIFICATE/BACKUP/id.bdmv" was skipped
File "/MAKEMKV/AACS/Content002.cer" was skipped
File "/MAKEMKV/AACS/Content001.cer" was skipped
File "/MAKEMKV/AACS/Content000.cer" was skipped
File "/MAKEMKV/AACS/DH_Pairing_Server.cer" was skipped
File "/MAKEMKV/AACS/MKB_RO.inf" was skipped
File "/MAKEMKV/AACS/Unit_Key_RO.inf" was skipped
File "/MAKEMKV/AACS/CPSUnit00001.cci" was skipped
File "/MAKEMKV/AACS/ContentRevocation.lst" was skipped
File "/MAKEMKV/AACS/ContentHash002.tbl" was skipped
File "/MAKEMKV/AACS/ContentHash001.tbl" was skipped
File "/MAKEMKV/AACS/ContentHash000.tbl" was skipped
File "/MAKEMKV/AACS/DUPLICATE/Content002.cer" was skipped
File "/MAKEMKV/AACS/DUPLICATE/Content001.cer" was skipped
File "/MAKEMKV/AACS/DUPLICATE/Content000.cer" was skipped
File "/MAKEMKV/AACS/DUPLICATE/DH_Pairing_Server.cer" was skipped
File "/MAKEMKV/AACS/DUPLICATE/MKB_RO.inf" was skipped
File "/MAKEMKV/AACS/DUPLICATE/Unit_Key_RO.inf" was skipped
File "/MAKEMKV/AACS/DUPLICATE/CPSUnit00001.cci" was skipped
File "/MAKEMKV/AACS/DUPLICATE/ContentRevocation.lst" was skipped
File "/MAKEMKV/AACS/DUPLICATE/ContentHash002.tbl" was skipped
File "/MAKEMKV/AACS/DUPLICATE/ContentHash001.tbl" was skipped
File "/MAKEMKV/AACS/DUPLICATE/ContentHash000.tbl" was skipped
Backup completado
Registro de depuración habilitado. El registro se guardará en C:\Users\angel/MakeMKV_log.txt
DEBUG: Code 100864261 at _worNE:(,lg'T'0g]I:121263429
DEBUG: Code 100864261 at _worNE:(,lg'T'0g]I:121262302
Error 'Error de SCSI - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' leyendo 'BD-RE ASUS BW-16D1HT 3.10 KL9N4CJ0226' en la posición '524288'
Error 'Error de SCSI - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' leyendo 'BD-RE ASUS BW-16D1HT 3.10 KL9N4CJ0226' en la posición '32768'
DEBUG: Code 0 at KDtw+</(q{cQg@?RYz;:121261773
EDIT 2: Now I'm really scared. This is getting worse. Now it can't even recognize regular Blu-ray discs. Worst. Right now it's unable to recognize Ultra HD discs. Inserted "One Piece Film Red UHD" and nothing. Reinserted "The Boy and The Heron UHD" and nothing :shock:
Re: SDFtool Flasher
StarForce wrote: Sat Oct 11, 2025 4:24 am I was really worried about not doing it right, but I just used SDFtool Flasher v1.3.6 on my ASUS BW-16D1HT (v3.11 Firmware) on a Windows 11 computer and it is much easier than I thought. After choosing my drive, I first created a firmware dump of my drive with the "READ Firmware" option (which I imagine will be used for the "RECOVER Drive" option), then "WRITE Firmware" was activated, I chose "DE_ASUS_BW-16D1HT_3.10_MK.bin", clicked "START" and, finally, it can read my first Ultra HD Blu-ray, the Spanish version of "The Boy and The Heron". Thank you so much for all this knowledge and for this very useful tool. Now I will try to rip this disc and create my backup copy. Thanks again.
Backup completado
They are pretty poor quality drives. These ASUS models are essentially just rebadged LG WH16NS40's with ASUS firmware on them.
Anyhoo, since the drive is having trouble reading the disc, the first thing to do is clean the disc. Most UHD discs need to be cleaned before they can be read as they usually contain an invisible film on them from the manufacturing process.
How are the drives connected? If externally via USB, ensure all plugs are connected to ports direct on the motherboard (not case ports) and ensure your enclosure or adapter is getting enough constant AC power.
StarForce
Re: SDFtool Flasher
Post by StarForce »
MartyMcNuts wrote: Sat Oct 11, 2025 6:10 amThey are pretty poor quality drives. These ASUS models are essentially just rebadged LG WH16NS40's with ASUS firmware on them.
It's connected via SATA directly to the motherboard. The problem is that right now it doesn't recognize any discs. It tries to read them and finally says "No disc inserted." I'm completely lost. It won't even play the UHD disc of "The Boy and the Heron" or the regular Blu-rays I ripped a few hours ago. It's crazy. Can I reinstall the firmware I had before? I made a dump with the "READ Firmware" option. Can I load it with the "RECOVER Drive" option?
Right now my drive has "Region 1" as Region selected but I live in Spain, "Region 2". Maybe this has changed or all regions are unlocked and I get this new "Region 1" but it's not relevant. Changed to "Region 2" and nothing change. Drive can't recognize any disc. I've really had bad luck :(
When I choose "RECOVER Drive" it doesn't find any firmware inside "Firmware_Dumps" but I have a dump on it.
