ezulllllll
Re: SDFtool Flasher
#1426 Post by ezulllllll » Tue Sep 30, 2025 1:39 am
unfortunately yes :( thank you for sharing the resource. going to return this product now. any suggestions for a replacement? thanks!
PepoAviles
Re: SDFtool Flasher
#1427 Post by PepoAviles » Tue Sep 30, 2025 7:21 am
Am I able to flash my new Drive?
Re: SDFtool Flasher
#1428 Post by dcoke22 » Tue Sep 30, 2025 1:38 pm
PepoAviles wrote: Tue Sep 30, 2025 7:21 am Am I able to flash my new Drive?
It is a BU40N. Follow the instructions in the Ultimate UHD Drives Flashing Guide.
Bravo5
Re: SDFtool Flasher
#1429 Post by Bravo5 » Sun Oct 05, 2025 8:50 pm
It was well known that it was possible to flash a DVD-ROM for copies of a popular console,
but I didn't know how to flash a Blu-ray burner to make copies and remuxes of a UHD. :D
I flashed my Asus in less than a minute with this fantastic tool, using DE_ASUS_BW-16D1HT_3.10_MK.bin
You guys are the next level, The Next.
I'll buy a license soon, it's the least I can do.
Thank you for your work.
Re: SDFtool Flasher
#1430 Post by MartyMcNuts » Sun Oct 05, 2025 11:34 pm
Bravo5 wrote: Sun Oct 05, 2025 8:50 pm It was well known that it was possible to flash a DVD-ROM for copies of a popular console,
You are welcome! :D
mattwest715
Re: SDFtool Flasher
#1431 Post by mattwest715 » Mon Oct 06, 2025 10:35 pm
I'm having some issues with the BU40N download. No hyperlinks appear to be working for me except the "All you need firmware pack" that mentions the slim. is that the firmware to use? i'm on MacOS if that helps
aceland07
Re: SDFtool Flasher
#1432 Post by aceland07 » Tue Oct 07, 2025 2:52 am
I am attempting to flash my disc drive. When I press the start button, nothing happens.
sn0wleo
Re: SDFtool Flasher
#1433 Post by sn0wleo » Tue Oct 07, 2025 7:31 pm
I just Got a BD-RE BU40N drive revision 1.05 libe drive information says Status: Possible noot yet enabled drive platform: MT1959. Can i flash this drive with one of the firmware provided here and which one should i flash ?
Re: SDFtool Flasher
#1434 Post by dcoke22 » Tue Oct 07, 2025 8:16 pm
sn0wleo wrote: Tue Oct 07, 2025 7:31 pm I just Got a BD-RE BU40N drive revision 1.05 libe drive information says Status: Possible noot yet enabled drive platform: MT1959. Can i flash this drive with one of the firmware provided here and which one should i flash ?
Just follow the instructions in the Ultimate UHD Drives Flashing Guide.
Re: SDFtool Flasher
#1435 Post by MartyMcNuts » Tue Oct 07, 2025 11:06 pm
aceland07 wrote: Tue Oct 07, 2025 2:52 am Hi,
Is it an Archgon? If so, you should take the drive out of the enclosure and use an adapter to flash it as the new enclosure won't allow flashing.
IShallRiseAgain
Re: SDFtool Flasher
#1436 Post by IShallRiseAgain » Thu Oct 09, 2025 1:35 pm
So, I'm confused, I appear to have flashed my LG slim BP50NB40-NB50 correctly, but it still can't read 4K UHD disks. It can still read blu-ray discs so it doesn't appear that I used the wrong firmware.
Here is drive information from MakeMKV
Product: BD-RE BP50NB40
Revision: 1.03
Serial number:
Highest AACS version: 78
Firmware version: 1.03
I used the firmware in "LG slim BP50NB40-NB50" in the all you need firmware pack. Am I missing a step in the process or something?
Oh and here is the original firmware that I dumped before flashing HL-DT-ST_BD-RE_BP50NB40_1.03_212005070917_SIM0121C52144
Re: SDFtool Flasher
#1437 Post by MartyMcNuts » Thu Oct 09, 2025 11:49 pm
IShallRiseAgain wrote: Thu Oct 09, 2025 1:35 pm So, I'm confused, I appear to have flashed my LG slim BP50NB40-NB50 correctly, but it still can't read 4K UHD disks. It can still read blu-ray discs so it doesn't appear that I used the wrong firmware.
Revision: 1.03
Serial number:
Follow the instructions in the first post. There's also a gif showing what to do.
IShallRiseAgain
Re: SDFtool Flasher
#1438 Post by IShallRiseAgain » Fri Oct 10, 2025 12:47 am
Oh thanks, I missed that step. Now it works fine.
StarForce
Re: SDFtool Flasher
#1439 Post by StarForce » Sat Oct 11, 2025 4:24 am
I was really worried about not doing it right, but I just used SDFtool Flasher v1.3.6 on my ASUS BW-16D1HT (v3.11 Firmware) on a Windows 11 computer and it is much easier than I thought. After choosing my drive, I first created a firmware dump of my drive with the "READ Firmware" option (which I imagine will be used for the "RECOVER Drive" option), then "WRITE Firmware" was activated, I chose "DE_ASUS_BW-16D1HT_3.10_MK.bin", clicked "START" and, finally, it can read my first Ultra HD Blu-ray, the Spanish version of "The Boy and The Heron". Thank you so much for all this knowledge and for this very useful tool. Now I will try to rip this disc and create my backup copy. Thanks again.
EDIT 1: Unfortunately, the drive was unable to read the disk, displaying a multitude of SCSI errors and a "Copy complete" message. The folder where the dump was created was only 256 KB. Any suggestions?
MakeMKV v1.18.2 win(x64-release) comenzado
Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
Haciendo backup del disco en la carpeta "D:/_ANIMACIÓN/EL CHICO Y LA GARZA"
Descargando el/los último(s) HK en C:\Users\*****/.MakeMKV ...
Error 'Error de SCSI - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' leyendo 'BD-RE ASUS BW-16D1HT 3.10 KL9N4CJ0226' en la posición '1048576'
Error 'Error de SCSI - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' leyendo 'BD-RE ASUS BW-16D1HT 3.10 KL9N4CJ0226' en la posición '1445330944'
Error 'Error de SCSI - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' leyendo 'BD-RE ASUS BW-16D1HT 3.10 KL9N4CJ0226' en la posición '1445349376'
Falló la carga del contenido de la tabla hash, no es posible verificar la integridad de los archivos M2TS.
Error 'Error de SCSI - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' leyendo 'BD-RE ASUS BW-16D1HT 3.10 KL9N4CJ0226' en la posición '655360'
Error 'Error de SCSI - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' leyendo 'BD-RE ASUS BW-16D1HT 3.10 KL9N4CJ0226' en la posición '657408'
udf: node fe/efe failed!
File "/BDMV/index.bdmv" was skipped
File "/BDMV/MovieObject.bdmv" was skipped
File "/BDMV/PLAYLIST/00009.mpls" was skipped
File "/BDMV/PLAYLIST/00008.mpls" was skipped
File "/BDMV/PLAYLIST/00007.mpls" was skipped
File "/BDMV/PLAYLIST/00006.mpls" was skipped
File "/BDMV/PLAYLIST/00005.mpls" was skipped
File "/BDMV/PLAYLIST/00004.mpls" was skipped
File "/BDMV/PLAYLIST/00001.mpls" was skipped
File "/BDMV/PLAYLIST/00003.mpls" was skipped
File "/BDMV/PLAYLIST/00002.mpls" was skipped
File "/BDMV/PLAYLIST/00000.mpls" was skipped
File "/BDMV/PLAYLIST/00014.mpls" was skipped
File "/BDMV/PLAYLIST/00013.mpls" was skipped
File "/BDMV/PLAYLIST/00011.mpls" was skipped
File "/BDMV/PLAYLIST/00015.mpls" was skipped
File "/BDMV/PLAYLIST/00010.mpls" was skipped
File "/BDMV/PLAYLIST/00012.mpls" was skipped
File "/BDMV/CLIPINF/00013.clpi" was skipped
File "/BDMV/CLIPINF/00012.clpi" was skipped
File "/BDMV/CLIPINF/00011.clpi" was skipped
File "/BDMV/CLIPINF/00015.clpi" was skipped
File "/BDMV/CLIPINF/00016.clpi" was skipped
File "/BDMV/CLIPINF/00010.clpi" was skipped
File "/BDMV/CLIPINF/00009.clpi" was skipped
File "/BDMV/CLIPINF/00008.clpi" was skipped
File "/BDMV/CLIPINF/00007.clpi" was skipped
File "/BDMV/CLIPINF/00006.clpi" was skipped
File "/BDMV/CLIPINF/00005.clpi" was skipped
File "/BDMV/CLIPINF/00004.clpi" was skipped
File "/BDMV/CLIPINF/00003.clpi" was skipped
File "/BDMV/CLIPINF/00002.clpi" was skipped
File "/BDMV/CLIPINF/00017.clpi" was skipped
File "/BDMV/CLIPINF/00001.clpi" was skipped
File "/BDMV/CLIPINF/00000.clpi" was skipped
File "/BDMV/CLIPINF/00014.clpi" was skipped
File "/BDMV/STREAM/00014.m2ts" was skipped
File "/BDMV/STREAM/00013.m2ts" was skipped
File "/BDMV/STREAM/00012.m2ts" was skipped
File "/BDMV/STREAM/00011.m2ts" was skipped
File "/BDMV/STREAM/00015.m2ts" was skipped
File "/BDMV/STREAM/00016.m2ts" was skipped
File "/BDMV/STREAM/00010.m2ts" was skipped
File "/BDMV/STREAM/00009.m2ts" was skipped
File "/BDMV/STREAM/00008.m2ts" was skipped
File "/BDMV/STREAM/00007.m2ts" was skipped
File "/BDMV/STREAM/00006.m2ts" was skipped
File "/BDMV/STREAM/00005.m2ts" was skipped
File "/BDMV/STREAM/00004.m2ts" was skipped
File "/BDMV/STREAM/00003.m2ts" was skipped
File "/BDMV/STREAM/00002.m2ts" was skipped
File "/BDMV/STREAM/00001.m2ts" was skipped
File "/BDMV/STREAM/00000.m2ts" was skipped
File "/BDMV/STREAM/00017.m2ts" was skipped
File "/BDMV/BACKUP/index.bdmv" was skipped
File "/BDMV/BACKUP/MovieObject.bdmv" was skipped
File "/BDMV/BACKUP/PLAYLIST/00010.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00012.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00009.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00008.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00007.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00006.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00005.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00004.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00003.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00002.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00000.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00014.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00013.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00011.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00015.mpls" was skipped
File "/BDMV/BACKUP/PLAYLIST/00001.mpls" was skipped
File "/BDMV/BACKUP/CLIPINF/00013.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00012.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00011.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00015.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00016.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00010.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00009.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00008.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00007.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00006.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00005.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00004.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00003.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00002.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00017.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00001.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00000.clpi" was skipped
File "/BDMV/BACKUP/CLIPINF/00014.clpi" was skipped
File "/CERTIFICATE/id.bdmv" was skipped
File "/CERTIFICATE/BACKUP/id.bdmv" was skipped
File "/MAKEMKV/AACS/Content002.cer" was skipped
File "/MAKEMKV/AACS/Content001.cer" was skipped
File "/MAKEMKV/AACS/Content000.cer" was skipped
File "/MAKEMKV/AACS/DH_Pairing_Server.cer" was skipped
File "/MAKEMKV/AACS/MKB_RO.inf" was skipped
File "/MAKEMKV/AACS/Unit_Key_RO.inf" was skipped
File "/MAKEMKV/AACS/CPSUnit00001.cci" was skipped
File "/MAKEMKV/AACS/ContentRevocation.lst" was skipped
File "/MAKEMKV/AACS/ContentHash002.tbl" was skipped
File "/MAKEMKV/AACS/ContentHash001.tbl" was skipped
File "/MAKEMKV/AACS/ContentHash000.tbl" was skipped
File "/MAKEMKV/AACS/DUPLICATE/Content002.cer" was skipped
File "/MAKEMKV/AACS/DUPLICATE/Content001.cer" was skipped
File "/MAKEMKV/AACS/DUPLICATE/Content000.cer" was skipped
File "/MAKEMKV/AACS/DUPLICATE/DH_Pairing_Server.cer" was skipped
File "/MAKEMKV/AACS/DUPLICATE/MKB_RO.inf" was skipped
File "/MAKEMKV/AACS/DUPLICATE/Unit_Key_RO.inf" was skipped
File "/MAKEMKV/AACS/DUPLICATE/CPSUnit00001.cci" was skipped
File "/MAKEMKV/AACS/DUPLICATE/ContentRevocation.lst" was skipped
File "/MAKEMKV/AACS/DUPLICATE/ContentHash002.tbl" was skipped
File "/MAKEMKV/AACS/DUPLICATE/ContentHash001.tbl" was skipped
File "/MAKEMKV/AACS/DUPLICATE/ContentHash000.tbl" was skipped
Backup completado
Registro de depuración habilitado. El registro se guardará en C:\Users\angel/MakeMKV_log.txt
DEBUG: Code 100864261 at _worNE:(,lg'T'0g]I:121263429
DEBUG: Code 100864261 at _worNE:(,lg'T'0g]I:121262302
Error 'Error de SCSI - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' leyendo 'BD-RE ASUS BW-16D1HT 3.10 KL9N4CJ0226' en la posición '524288'
Error 'Error de SCSI - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' leyendo 'BD-RE ASUS BW-16D1HT 3.10 KL9N4CJ0226' en la posición '32768'
DEBUG: Code 0 at KDtw+</(q{cQg@?RYz;:121261773
EDIT 2: Now I'm really scared. This is getting worse. Now it can't even recognize regular Blu-ray discs. Worst. Right now it's unable to recognize Ultra HD discs. Inserted "One Piece Film Red UHD" and nothing. Reinserted "The Boy and The Heron UHD" and nothing :shock:
Re: SDFtool Flasher
#1440 Post by MartyMcNuts » Sat Oct 11, 2025 6:10 am
StarForce wrote: Sat Oct 11, 2025 4:24 am I was really worried about not doing it right, but I just used SDFtool Flasher v1.3.6 on my ASUS BW-16D1HT (v3.11 Firmware) on a Windows 11 computer and it is much easier than I thought. After choosing my drive, I first created a firmware dump of my drive with the "READ Firmware" option (which I imagine will be used for the "RECOVER Drive" option), then "WRITE Firmware" was activated, I chose "DE_ASUS_BW-16D1HT_3.10_MK.bin", clicked "START" and, finally, it can read my first Ultra HD Blu-ray, the Spanish version of "The Boy and The Heron". Thank you so much for all this knowledge and for this very useful tool. Now I will try to rip this disc and create my backup copy. Thanks again.
Backup completado
They are pretty poor quality drives. These ASUS models are essentially just rebadged LG WH16NS40's with ASUS firmware on them.
Anyhoo, since the drive is having trouble reading the disc, the first thing to do is clean the disc. Most UHD discs need to be cleaned before they can be read as they usually contain an invisible film on them from the manufacturing process.
How are the drives connected? If externally via USB, ensure all plugs are connected to ports direct on the motherboard (not case ports) and ensure your enclosure or adapter is getting enough constant AC power.
