Get UHD Access From the E116 Version of ASUS BW-16D1H-U?
Re: Get UHD Access From the E116 Version of ASUS BW-16D1H-U?
#16 Post by Coopervid » Thu Sep 25, 2025 8:34 am
sugi1 wrote: Wed Sep 24, 2025 9:04 pm I seem to have the same problem. Any help is appreciated.
Drive info:
Loaded SDF.bin version 0x98
SDF.bin version: 0x0098
Drive Tool SDF present
Drive Specific SDF present
[Drive Specific SDF] Embedded Info Strings:
8000:LibreDrive Information
8013:Status
8105:Enabled
8001:Drive platform
:RS8F00
8015:Firmware name
:PIONEER BDR-212T
8002:Firmware type
8106:Original (unpatched)
8003:Firmware version
:E116/ID71
8005:DVD all regions
8100:Yes
8006:BD raw data read
8100:Yes
8007:BD raw metadata read
8100:Yes
8009:Unrestricted read speed
8100:Yes
[Drive Specific SDF] Embedded Status Message:
8099:Using LibreDrive mode (v%1 id=%2)
:01.0
:D0CE65A7F569
Identification SDF present
8013:Status
8001:Drive platform
:Pioneer RS8F00
:ID71
pioneer:SAT :8F00:ID71:    :ASUS    :BW-16D1H-U      E116: 20/07/21  :-
PM sent.
WALTunne
#17 Post by WALTunne » Wed Oct 01, 2025 9:06 pm
Hello guys, i don't know which firmware i have to write. Can someone help me ?
Drive info :
Informations lecteur
Nom du lecteur SE : F:
Fabricant : ASUS
Produit : BW-16D1H-U
Révision : E116
Numéro de série : DIDL120081WL
Date micrologiciel : 2020-07-21
Marqueurs d'encryptage bus : 1B
Drive platform: RS8F00
Firmware version: E116/ID71
#18 Post by Coopervid » Thu Oct 02, 2025 11:32 am
WALTunne wrote: Wed Oct 01, 2025 9:06 pm Hello guys, i don't know which firmware i have to write. Can someone help me ?
Drive info :
Fabricant : ASUS
Révision : E116
PM is comimng. The forum is terribly slow and I have a lot of timeouts.
ducky007
#19 Post by ducky007 » Tue Oct 07, 2025 5:07 pm
Hi folks, I been searching the forums and have not found a solution to get my drive to accept
UHD discs. Found this thread and I thought I try here. Help :)
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: X
Firmware date: 2020-07-21
x10bulls
#20 Post by x10bulls » Mon Oct 13, 2025 10:19 pm
Can I please get help for a working firmware to rip UHD titles. Here's my drive info:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
#21 Post by Coopervid » Tue Oct 14, 2025 10:06 am
ducky007 wrote: Tue Oct 07, 2025 5:07 pm Hi folks, I been searching the forums and have not found a solution to get my drive to accept
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: X
PM sent.
#22 Post by Coopervid » Tue Oct 14, 2025 10:08 am
x10bulls wrote: Mon Oct 13, 2025 10:19 pm Can I please get help for a working firmware to rip UHD titles. Here's my drive info:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
PM sent.
evo_day
#23 Post by evo_day » Mon Oct 27, 2025 11:19 am
Coopervid wrote: Tue Oct 14, 2025 10:08 am
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
PM sent.
@Coopervid, wonder if you could help me with the same?
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: *****************
Highest AACS version: 82
#24 Post by Coopervid » Mon Oct 27, 2025 11:23 am
evo_day wrote: Mon Oct 27, 2025 11:19 am
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
PM sent.
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Sure. PM is coming.
GDNCHN!
#25 Post by GDNCHN! » Fri Apr 03, 2026 5:57 am
Coopervid wrote: Thu Aug 28, 2025 8:51 pm
GDNCHN! wrote: Thu Aug 21, 2025 1:54 pm Drive Information
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
The biggest difference between my drive and the common ones is that its firmware is "E116", compared to the often-seen ones with "E114" or "E115" firmware. But since the LibreDrive is enabled, I put an UHD disc inside. Surprisingly, after a while of reading, MakeMKV just simply told me that there is "No Disc" inside. That's awful. What should I do, or which firmware should I patch since its chip is not MT1959?
PM sent.
Could you send me that PM again? I haven't got time to see that. Thanks!
#26 Post by Coopervid » Fri Apr 03, 2026 7:09 pm
GDNCHN! wrote: Fri Apr 03, 2026 5:57 am
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
PM sent.
Sorry. Look elsewhere. Half a year after sending the firmware right away you lost youir window of opportunity. I just dislike slow people who ask for help and then disappear.
#27 Post by Billycar11 » Sat Apr 04, 2026 9:38 pm
Coopervid wrote: Fri Apr 03, 2026 7:09 pm
PM sent.
Sure email me that drive info section see below for email
noctem_aurelius
#28 Post by noctem_aurelius » Wed Sep 23, 2026 8:37 am
I bought an ASUS Drive too and it doesn't support the MediaTek Chipset Flashing as well. Would love some help. Couldn't get help from Billycar because the payment method isn't available to me. I heard to ask for Coopervid.
Drive Information:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Highest AACS version: 68
LibreDrive Information:
At the moment, UHD Blu-ray discs are not recognized by the drive.
Could you please let me know if this drive can be sidegraded for UHD support and, if so, send me the appropriate instructions/firmware?
#29 Post by Billycar11 » Sat Sep 26, 2026 1:42 pm
noctem_aurelius wrote: Wed Sep 23, 2026 8:37 am I bought an ASUS Drive too and it doesn't support the MediaTek Chipset Flashing as well. Would love some help. Couldn't get help from Billycar because the payment method isn't available to me.
Drive Information:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
sure email me that info and all others email me no need to post your info here publicly just reach out to me directly
see below for email
i have payment methods available for you all you had to do was tell me it was not available in your country
pgjohn
#30 Post by pgjohn » Sun Sep 27, 2026 10:22 am
Hi @Coopervid. Could I please get the info about the UHD enabling firmware? I have the same BW-16D1H-U with the 2020 Pioneer drive (2020-07-21, E116 version firmware).
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
