LibreDrive for Pioneer drives
DavidLai
#1681 Post by DavidLai » Tue Oct 07, 2025 3:39 am
MrPenguin wrote: Mon Oct 06, 2025 3:23 pm
DavidLai wrote: Mon Oct 06, 2025 2:55 pm So a 2-year-old firmware still hasn't gotten supported, that's sad to hear. I'm still holding out hope, though the hope is slim.
FWIW there is considerably more hope today than there was 2 years ago... ;)
OK, that's at least some good news. Looks like this journey is a long one.
mudisk
#1682 Post by mudisk » Wed Oct 08, 2025 4:04 am
It seems that the BDR-209M is still being sold in Japan under the I-O DATA brand (https://www.iodata.jp/product/storage/e ... /index.htm). They are readily in stock.
Out of curiosity I bought one of these. The manufacturing date is October 2024 and it was made in China. The drive itself has no I-O DATA branding - it looks exactly like any another BDR-209 I can find pictures of and the labels all say Pioneer. Here's the drive information:
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-209MIO
Revision: 1.54
Serial number: redacted
Firmware date: 2020-07-21
Firmware version: ID13
From what I understand this drive should actually be possible to flash, though I don't have access to a flasher. If anyone can help with that let me know.
Maybe I'm missing something but wouldn't this be a relatively big deal since you can buy them new? The only issue is that they are fairly expensive for being such old drives.
ducky007
#1683 Post by ducky007 » Wed Oct 08, 2025 3:01 pm
I need some help, I have tried UHD discs but they aren’t accepted, but it just returns no disc.
I saw that someone else hade already ask for help with ( firmware E116/ID71).
I tried the SDF tool but it returned that I have the wrong plattform.
Hoping that someone can help me to get this to work
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: X
Drive platform: RS8F00
Firmware version: E116/ID71
#1684 Post by Billycar11 » Wed Oct 08, 2025 4:26 pm
ducky007 wrote: Wed Oct 08, 2025 3:01 pm I need some help, I have tried UHD discs but they aren’t accepted, but it just returns no disc.
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: X
Sure email me that info
Zoyar
#1685 Post by Zoyar » Thu Oct 09, 2025 4:37 pm
Hello.
I bought the Asus BW-16D1H-U Pro ext. USB.
LibreDrive is enabled but i can't rip UHD disks.
Which firmware do i have to use? thanks
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Highest AACS version: 43
#1686 Post by Billycar11 » Fri Oct 10, 2025 6:00 am
Zoyar wrote: Thu Oct 09, 2025 4:37 pm Hello.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
email me the drive info section
slagathor
#1687 Post by slagathor » Sat Oct 11, 2025 5:54 am
Billycar11 wrote: Thu Sep 18, 2025 11:01 pm
slagathor wrote: Thu Sep 18, 2025 10:56 pm @billycar11 I did switch to Linux from Windows. Does the Linux version of MakeMKV not have access to HK downloads? I'd prefer not to have to use Windows if possible.
If it matters, I am using Arch Linux and installed according to these MakeMKV instructions. I've also tried using the AUR version of MakeMKV but get the same error regardless. I can play / rip Bluray just fine btw.
Anything I can do here to get this working?
You have to get your hk downloads working or make sure the docker passes through the drive fully
Both show similar issues
All that can work on Linux fine it just a matter of having it setup correctly
Okay so the drive worked fine in windows but I could not for the life of me get it working on Linux. Turns out switching the SATA port the drive was plugged into fixed it! Not sure why other port worked with Windows but just sharing this fix here in case anyone else is having the same issue.
#1688 Post by Coopervid » Sat Oct 11, 2025 9:43 am
mudisk wrote: Wed Oct 08, 2025 4:04 am It seems that the BDR-209M is still being sold in Japan under the I-O DATA brand (https://www.iodata.jp/product/storage/e ... /index.htm). They are readily in stock.
OS device name: E:
Revision: 1.54
PM sent. Thi 209 is actually a camouflaged 212.
knuxyl
#1689 Post by knuxyl » Sat Oct 11, 2025 3:46 pm
Pioneer external slim BDR-XS07U works, and rips significantly faster than my internal BU40N or internal BW-16D1HT. It's supposed to be a 4x drive but it's faster than my 8x drive, on USB 3.
I'd share my firmware but makemkv's sdftool doesn't work on linux (wish it did). I couldn't flash my BU40N and I can't dump my XS07U, it just hangs forever after loading sdf.conf.
I figured at least sharing that it works is helpful.
OS device name: /dev/sr1
Product: BD-RW BDR-XS07U
Revision: 1.01
Serial number: TLDL00XXXXXX Omit
Firmware date: 2020-09-03
Bus encryption flags: 13
Highest AACS version: 16
Drive platform: RS8E21
Firmware version: 1.01/ID05
mudisk
#1690 Post by mudisk » Sat Oct 11, 2025 6:19 pm
Coopervid wrote: Sat Oct 11, 2025 9:43 am PM sent. Thi 209 is actually a camouflaged 212.
Thanks Coopervid I can't reply to PMs (I think) but I'll give it a go tomorrow and let you guys know how it goes. If it works then it seems like you can still buy a 212 brand new today, with flashable firmware and a recent manufacturing date. I don't know what their long term plans are but they announced the drive this summer, after Pioneer had already closed up shop, and there's no indication that this is some sort of a limited run with whatever stock they have left.
#1691 Post by Coopervid » Sat Oct 11, 2025 7:22 pm
knuxyl wrote: Sat Oct 11, 2025 3:46 pm Pioneer external slim BDR-XS07U works, and rips significantly faster than my internal BU40N or internal BW-16D1HT. It's supposed to be a 4x drive but it's faster than my 8x drive, on USB 3.
Revision: 1.01
Boy!You are completely off. Post when you are sober again. Pioneers are 4x max. LGs are faster but might fail with hard to read diss.
austeros
#1692 Post by austeros » Sun Oct 12, 2025 2:31 am
Can this drive be flashed to UHD?
OS device name: E:
Product: BD-RW BDR-XD08
Revision: 1.02
Firmware date: 2022-12-27
Highest AACS version: 77
Drive platform: Pioneer RS9330
Firmware version: GENE
#1693 Post by MartyMcNuts » Sun Oct 12, 2025 8:54 am
austeros wrote: Sun Oct 12, 2025 2:31 am Can this drive be flashed to UHD?
OS device name: E:
Revision: 1.02
No, not currently as the firmware is post 11/2022. You have to wait for future support.
austeros
#1694 Post by austeros » Sun Oct 12, 2025 11:55 am
MartyMcNuts wrote: Sun Oct 12, 2025 8:54 am
OS device name: E:
Revision: 1.02
thank you
knuxyl
#1695 Post by knuxyl » Tue Oct 14, 2025 12:34 am
Coopervid wrote: Sat Oct 11, 2025 7:22 pm
Revision: 1.01
I am watching right now ripping a dvd with both the bu40 and the pioner and the pioner is ripping a lot faster. maybe it's a linux problem, but your condescending remarks are not welcome and you can piss off.
