NEW Single Drive Flasher - available worldwide!!
Re: UHD Enabled Drives (Australia, NZ & Singapore among others!) & DIY "Single Drive Flasher UI" available worldwide!!
Stock levels updated in first post.
davester
Hello, I am looking to acquire the "Single Drive Flasher UI (Windows)" from https://uhdenableddrives.com/?product=s ... ui-windows.
I have the following
Could you please advise on the type of drive and firmware that is optimal for UHD ripping? I also have other ripping software, including Tipard Blu-ray Converter and Dumbo Bluray Ripper.Drive Information:
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E115
Serial number: AFDL067907WL
Firmware date: 2019-03-07
LibreDrive Information:
Drive platform: RS8F00
Firmware version: E115/ID71
Your ASUS has a Pioneer drive inside. My flasher isn't compatible with Pioneer drives. Contact Billycar11 and he will be able to help you flash that drive.davester wrote: Fri Oct 17, 2025 6:04 am Hello, I am looking to acquire the "Single Drive Flasher UI (Windows)" from https://uhdenableddrives.com/?product=s ... ui-windows.
I have the followingCould you please advise on the type of drive and firmware that is optimal for UHD ripping? I also have other ripping software, including Tipard Blu-ray Converter and Dumbo Bluray Ripper.Drive Information:
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E115
