UHD copy failure
synthetic
UHD copy failure
Post by synthetic »
I recently purchased the MKV licence and a new LG drive and have done the steps to update the firmware and LibreDrive is now enabled. I have purchased two new 4K discs from JBHiFi. I have not been able to copy either of these as I get errors like this for both discs:
Failed to save title 3 to file D:/Video/The Lost World- Jurassic Park/The Lost World- Jurassic Park_t03.mkv
Encountered 1 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
0 titles saved, 1 failed
I have tried the standard blu ray discs, and they copied no problem using the same setup.
Does this indicate that the drive I purchased is faulty or am I doing something wrong?
I am not sure if more information is required, I cannot see how to download an error log.
Re: UHD copy failure
synthetic wrote: Sun Oct 05, 2025 6:40 am I recently purchased the MKV licence and a new LG drive and have done the steps to update the firmware and LibreDrive is now enabled. I have purchased two new 4K discs from JBHiFi. I have not been able to copy either of these as I get errors like this for both discs:
1. Clean the UHD dics. They often have an invisible film on them from the manufacturing process.
2. If using an external drive, ensure it is getting enough power. Use ports direct from the motherboard or an AC self-powered hub. Don't use case ports.
You can copy and paste the text from the log window so we can have a proper look. Also providing info on the drive model might also help.
synthetic
Post by synthetic »
Hello Marty,
Thank you. The drive is an internal LG BH16NS55 drive.
I have cleaned the disc and retried to copy and still get the same error:
MakeMKV v1.18.1 win(x64-release) started
The new version 1.18.2 is available for download at http://www.makemkv.com/download/
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Title #00055.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00054.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00053.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00164.mpls was added as title #0
Title #00084.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00057.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00077.mpls was added as title #1
File 00165.mpls was added as title #2
Title #00161.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00160.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00157.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00156.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #3
Title #00020.mpls has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00153.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00152.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00094.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00093.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00285.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory D:/Video/The Lost World- Jurassic Park
The source file '/BDMV/STREAM/00026.m2ts' is corrupt or invalid at offset 4873463808, attempting to work around
Hash check failed for file 00026.m2ts at offset 4873512960, file is corrupt.
The source file '/BDMV/STREAM/00026.m2ts' is corrupt or invalid at offset 4873488384, attempting to work around
The source file '/BDMV/STREAM/00026.m2ts' is corrupt or invalid at offset 4873488384-4873494528, attempting to work around
The source file '/BDMV/STREAM/00026.m2ts' is corrupt or invalid at offset 4873494528, attempting to work around
The source file '/BDMV/STREAM/00026.m2ts' is corrupt or invalid at offset 31187472384, attempting to work around
Hash check failed for file 00026.m2ts at offset 31187527680, file is corrupt.
The source file '/BDMV/STREAM/00026.m2ts' is corrupt or invalid at offset 31187472384-31187478528, attempting to work around
The source file '/BDMV/STREAM/00026.m2ts' is corrupt or invalid at offset 31187478528, attempting to work around
The source file '/BDMV/STREAM/00026.m2ts' is corrupt or invalid at offset 31187496960, attempting to work around
The source file '/BDMV/STREAM/00026.m2ts' is corrupt or invalid at offset 31187509248, attempting to work around
The source file '/BDMV/STREAM/00026.m2ts' is corrupt or invalid at offset 31194028032-31194034176, attempting to work around
The source file '/BDMV/STREAM/00026.m2ts' is corrupt or invalid at offset 31194034176, attempting to work around
The source file '/BDMV/STREAM/00026.m2ts' is corrupt or invalid at offset 31194034176-31194040320, attempting to work around
The source file '/BDMV/STREAM/00026.m2ts' is corrupt or invalid at offset 31194040320, attempting to work around
The source file '/BDMV/STREAM/00026.m2ts' is corrupt or invalid at offset 31194040320-31194046464, attempting to work around
The source file '/BDMV/STREAM/00026.m2ts' is corrupt or invalid at offset 31194046464, attempting to work around
The source file '/BDMV/STREAM/00026.m2ts' is corrupt or invalid at offset 31194058752, attempting to work around
The source file '/BDMV/STREAM/00026.m2ts' is corrupt or invalid at offset 31194058752-31194064896, attempting to work around
The source file '/BDMV/STREAM/00026.m2ts' is corrupt or invalid at offset 31194064896, attempting to work around
The source file '/BDMV/STREAM/00026.m2ts' is corrupt or invalid at offset 31194064896-31194071040, attempting to work around
The source file '/BDMV/STREAM/00026.m2ts' is corrupt or invalid at offset 31194071040, attempting to work around
Too many AV synchronization issues in file '/BDMV/STREAM/00026.m2ts' (title #-) , future messages will be printed only to log file
Hash check failed for file 00026.m2ts at offset 31194212352, file is corrupt.
The source file '/BDMV/STREAM/00026.m2ts' is corrupt or invalid at offset 31187613696, attempting to work around
The source file '/BDMV/STREAM/00026.m2ts' is corrupt or invalid at offset 31187613696-31187619840, attempting to work around
The source file '/BDMV/STREAM/00026.m2ts' is corrupt or invalid at offset 31187619840, attempting to work around
synthetic
Post by synthetic »
Hash check failed for file 00026.m2ts at offset 31208957952, file is corrupt.
Hash check failed for file 00026.m2ts at offset 31209154560, file is corrupt.
Too many hash check errors in file 00026.m2ts.
AV sync issue in stream 1 at 1:05:14.709 with duration of 21.333ms : audio gap - 2 missing frame(s)
Encountered 44 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
Product: BD-RE WH16NS60
Revision: 1.02
Serial number:
Highest AACS version: 75
Firmware version: 1.02
Disc Information
Label: JURASSICPARK2UHD_UPK2
Timestamp: 2018-03-29 12:00:45
Protection: AACS2.0/C v61
Data capacity: 58.53 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Errors like this
mean the optical drive was unable to correctly read a spot on the disc.
The disc might be dirty. The optics of your drive might be dirty. The disc might be faulty.
Cleaning the disc is the first and easiest step.
Replacing the disc is fairly easy although not the cheapest option.
Trying a different optical drive is often helpful. I have more than one optical drive and often, though not always, a disc that's troublesome in one drive works just fine in another drive.
Cleaning the optics of your drive is harder since with a WH16NS60 you'd have to open the drive case.
Getting another drive, especially a now-hard-to-get Pioneer, can also help.
