I have backed up the disc to an ISO file, and am using this to rip from.
I load it up with the GUI, and I see all titles there, but the alternate angles are not preselected. Ultimately, I can select them, and can proceed to rip them as separate files with the alternate sequences inserted.
However, when using the CLI, I used:
makemkvcon mkv iso:disc_1.iso all "disc_1"
I am aware I can use the GUI, and everything will be fine, but as part of my backup process, I wish to have the full ISO files so I have the disc archived, but if I lose the MKV files, I can simply run a script that will do everything necessary to rip the ISO file, and rename everything without me having to do it all manually. This is getting in the way of that, and is quite annoying.
