Cannot Read ISO File-mounted Disk
kvhui
Post by kvhui » Sun Feb 05, 2012 3:21 am
I just purchased a registration key but some strange:
Before purchasing, I was able to select a ISO image (I mounted it under Mac Lion) but operation failed - errors like "Shareware function ended" and "AnyDVD detected" were prompted.
After purchasing, I now cannot even select the ISO-mounted disk. Also, I did not use AnyDVD (I only used Macgo Blu-ray Player).
Edit - Sorry I actually used open file then selected the ISO file, instead of using the mounted drive. But the error of "AnyDVD detected" persists.
Please kindly help.
Thanks.
Kevin
Romansh
Re: Cannot Read ISO File-mounted Disk
Post by Romansh » Sun Feb 05, 2012 2:36 pm
That means the ISO image was ripped under Windows, with the AnyDVD ripper or while AnyDVD was running.
