BU40N can't rip DVDs but all Blurays
Cloudboom
#1 Post by Cloudboom » Sat Oct 04, 2025 11:02 pm
my BU40N is not able to rip any dvds. Even new ones that where never touched just fail in the opening process. Any ideas why this could happen?
Drive information
Product: BD-RE BU40N
Revision: 1.03
Serial number: xxxxxxxx
Highest AACS version: 25
Firmware version: 1.03
Re: BU40N can't rip DVDs but all Blurays
#2 Post by MartyMcNuts » Sun Oct 05, 2025 1:49 am
Cloudboom wrote: Sat Oct 04, 2025 11:02 pm Hello,
Drive information
Revision: 1.03
Dirty or dead red laser, perhaps? Can it read CD's? If so, the laser may need cleaning. If not, it's probably dead.
Cloudboom
#3 Post by Cloudboom » Sun Oct 05, 2025 10:03 am
Hey so for Blurays as mentioned its fine atm and i rip them.
The DVDs can be found but after clicking they die while the openeing process.
With CDs you mean like MP3? I also did not test if i can just play dvds but not rip them tbh.
Cloudboom
#4 Post by Cloudboom » Sun Oct 05, 2025 12:14 pm
Yerah it seems red ray is dead
#5 Post by MartyMcNuts » Sun Oct 05, 2025 11:44 pm
Cloudboom wrote: Sun Oct 05, 2025 12:14 pm Yerah it seems red ray is dead
Yeah, if it won't even read CD's or play DVD's at all, the red laser is probably no good. You could try cleaning the laser and see if that helps, otherwise get a new drive.
Cloudboom
#6 Post by Cloudboom » Tue Oct 07, 2025 2:18 pm
Yeah celaning didn't helped at all. I just got a new one for the red laser part (ASUS SDRW-08U9M).
It works out of the box but throws some region not matching errors before it finaly opens the conten't.
I searched through the forum but since it's not part of the drivers in the guide there is no patch for it or?
