In Time Bluray won't rip
I'm having the same issue with the "In Time" Bluray as happened with the "Contagion" Bluray. I'll try to provide the dump file later.
Re: In Time Bluray won't rip
Until you (or someone else with access to the disc) emails the BD+ dump to Mike nothing will happen.MrMKV wrote:I'm having the same issue with the "In Time" Bluray as happened with the "Contagion" Bluray. I'll try to provide the dump file later.
This is what I get:
DBG ASSERT: %`w=]qp.B5%tSK:F&b~R=nualpQr%@gG|57uwUCI/4 R*0D<[Eu&K_Njxk&M>(xZc"Wae aZc1X:Ikv{ at YTsRd.ZU2,]5@RI^y+PI:121264487
DEBUG: Code 3 at YTsRd.ZU2,]5@RI^y+PI:213134952
DEBUG: Code 0 at 2#>"<bKYVEPaR7YxV0he^:213134216
DEBUG: Code 0 at )fq4!RefZ;J!R;X/. a:213132031
- Contact:
To begin with, please post the full log ( or send to support@makemkv.com )
I tried with the new release, but got the same problem.mike admin wrote:To begin with, please post the full log ( or send to support@makemkv.com )
MakeMKV v1.7.1 win(x86-release) comenzado
Registro de depuraci?n habilitado. El registro se guardar? en C:\Users\Mondini/MakeMKV_log.txt
Utilizando modo de acceso directo
Cargado(s) 66 archivo(s) SVQ
Procesado c?digo BD+. Por favor espere, esto puede llevar varios minutos
Procesando c?digo BD+ usando el SVQ gen?rico de builtin/00003.svq
DEBUG: Code 0 at HVH5RAZLh"`'0(gH:29400531
DEBUG: Code 0 at HVH5RAZLh"`'0(gH:29398254
DEBUG: Code 0 at HVH5RAZLh"`'0(gH:213139690
Fallo al procesar el c?digo BD+ usando el SVQ gen?rico de builtin/00003.svq
Procesando c?digo BD+ usando el SVQ gen?rico de builtin/00002.svq
Archivo de volcado de BD+ grabado como C:\Users\Mondini/.MakeMKV/dump_In_Time_1BE2B0ADC8FC4EA1.tgz
Se proces? el c?digo BD+ pero no se obtuvieron FUTs. Probablemente ocurrir?n errores
El t?tulo #00720.mpls tiene una duraci?n de 35 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
Se agreg? el archivo 00800.mpls como t?tulo #0
El t?tulo #00020.mpls tiene una duraci?n de 84 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
El t?tulo 00850.mpls es id?ntico al t?tulo 00800.mpls y fue ignorado
Se agreg? el archivo 00210.mpls como t?tulo #1
Se agreg? el archivo 00211.mpls como t?tulo #2
Se agreg? el archivo 00311.mpls como t?tulo #3
El t?tulo #00310.mpls tiene una duraci?n de 22 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
Se agreg? el archivo 00319.mpls como t?tulo #4
Se agreg? el archivo 00300.mpls como t?tulo #5
El t?tulo #00011.m2ts tiene una duraci?n de 23 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
El t?tulo #00122.m2ts tiene una duraci?n de 11 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
El t?tulo #00123.m2ts tiene una duraci?n de 15 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
El t?tulo #00720.m2ts tiene una duraci?n de 17 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
Se agreg? el archivo 00901.m2ts como t?tulo #6
El t?tulo #00021.m2ts tiene una duraci?n de 42 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
Operaci?n completada con ?xito
Guardando 1 t?tulos en el directorio C:/Users/Mondini/Desktop/TEMP/RIPS
DBG ASSERT: H?jbakznr$rF1y>G6(-07l|13cu,4@#e2aV: #6rpf83W:}.=* O'1h?;tK{n3xpZGY8,[c5i#5r(OQl at ^'?J=Z9$[Jvwdc$=Cq6C:121264487
DEBUG: Code 3 at ^'?J=Z9$[Jvwdc$=Cq6C:213134952
DEBUG: Code 0 at l>-W#w;[tRVy`>TN4KHwD:213134216
DEBUG: Code 0 at *Y$(QzA=5l]i(lXH0D1:213132031
Same issue with THE BIG YEAR. This is what I get:
Archivo de volcado de BD+ grabado como C:\Users\Mondini/.MakeMKV/dump_The_Big_Year_6663954F0D504436.tgz
El t?tulo #00020.mpls tiene una duraci?n de 83 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
Se agreg? el archivo 00850.mpls como t?tulo #0
El t?tulo 00800.mpls es id?ntico al t?tulo 00850.mpls y fue ignorado
Se agreg? el archivo 00420.mpls como t?tulo #1
Se agreg? el archivo 00801.mpls como t?tulo #2
El t?tulo 00851.mpls es id?ntico al t?tulo 00801.mpls y fue ignorado
El t?tulo #00419.mpls tiene una duraci?n de 35 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
Se agreg? el archivo 00445.mpls como t?tulo #3
El t?tulo 00346.mpls es id?ntico al t?tulo 00445.mpls y fue ignorado
Se agreg? el archivo 00800.m2ts como t?tulo #4
Se agreg? el archivo 00819.m2ts como t?tulo #5
Se agreg? el archivo 00820.m2ts como t?tulo #6
El t?tulo #00822.m2ts tiene una duraci?n de 107 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
El t?tulo #00848.m2ts tiene una duraci?n de 5 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
El t?tulo #00883.m2ts tiene una duraci?n de 27 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
El t?tulo #00885.m2ts tiene una duraci?n de 30 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
El t?tulo #00887.m2ts tiene una duraci?n de 44 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
El t?tulo #00889.m2ts tiene una duraci?n de 60 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
El t?tulo #00891.m2ts tiene una duraci?n de 89 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
Se agreg? el archivo 00895.m2ts como t?tulo #7
Se agreg? el archivo 00897.m2ts como t?tulo #8
El t?tulo #00906.m2ts tiene una duraci?n de 48 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
El t?tulo #00909.m2ts tiene una duraci?n de 99 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
El t?tulo #00912.m2ts tiene una duraci?n de 59 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
El t?tulo #00915.m2ts tiene una duraci?n de 31 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
El t?tulo #00918.m2ts tiene una duraci?n de 59 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
El t?tulo #00921.m2ts tiene una duraci?n de 117 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
El t?tulo #00924.m2ts tiene una duraci?n de 31 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
El t?tulo #00927.m2ts tiene una duraci?n de 56 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
Se agreg? el archivo 00932.m2ts como t?tulo #9
Se agreg? el archivo 00935.m2ts como t?tulo #10
El t?tulo #00021.m2ts tiene una duraci?n de 37 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
El t?tulo #00022.m2ts tiene una duraci?n de 45 segundos, que es menor que el m?nimo de 120 segundos y fue ignorado
El archivo de origen '/BDMV/STREAM/00897.m2ts' es inv?lido o est? da?ado en la posici?n 37232640, intentando solucionar
DEBUG: Code 0 at ^'?J=Z9$[Jvwdc$=Cq6C:213133158
DEBUG: Code 5 at ^'?J=Z9$[Jvwdc$=Cq6C:213134952
Fallo al guardar el t?tulo 2 en el archivo C:/Users/Mondini/Desktop/TEMP/RIPS/t02_The_Big_Year.mkv
0 t?tulos guardados, 1 fallaron
setarip_old
Two more not-yet-officially-released 20th Century Fox blu-rays ;>}
- Contact:
Please send two produced dump files to support@makemkv.com
With these files we can generate SVQ files, please see http://www.makemkv.com/svq/ . Please note that we will not publish SVQ files before disc official release date.
Fat Cerberus
I just sent a dump for the U.S. blu-ray, released today.
Axehandler
Same issue.....
I don't seem to be generating an debug log file - and had to manually make a dump....
I was able to backup the disk to a folder.. (did NOT decrypt it) - same from disk or backup....
I turned on all logging...
MakeMKV v1.7.1 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Axehandler/MakeMKV_log.txt
Opening files on harddrive at D:/@BR Movies/backup/IN_TIME/
Loaded 29 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00003.svq
DEBUG: Code 0 at G[50!eTciZhv%E79:29400531
DEBUG: Code 0 at G[50!eTciZhv%E79:29398254
DEBUG: Code 0 at G[50!eTciZhv%E79:213139690
Failed to process BD+ code using generic SVQ from builtin/00003.svq
Processing BD+ code using generic SVQ from builtin/00002.svq
Saved BD+ dump file as C:\Users\Axehandler\.MakeMKV/dump_In_Time_1BE2B0ADC8FC4EA1.tgz
BD+ code processed but no FUTs were obtained, errors may follow
File 00020.mpls was added as title #0
File 00210.mpls was added as title #1
File 00211.mpls was added as title #2
File 00300.mpls was added as title #3
Title #00310.mpls has length of 22 seconds which is less than minimum title length of 60 seconds and was therefore skipped
File 00311.mpls was added as title #4
File 00319.mpls was added as title #5
Title #00720.mpls has length of 35 seconds which is less than minimum title length of 60 seconds and was therefore skipped
File 00800.mpls was added as title #6
Title 00850.mpls is equal to title 00800.mpls and was skipped
Title #00011.m2ts has length of 23 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00122.m2ts has length of 11 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00123.m2ts has length of 15 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00720.m2ts has length of 17 seconds which is less than minimum title length of 60 seconds and was therefore skipped
File 00901.m2ts was added as title #7
Saving 1 titles into directory D:/@BR Movies/In_Time
DBG ASSERT: A5%5~x^SWbR0b[41p@wIE[lPr(>X)=:5fj3|8N=Y*/dlTiw%$!$4]VX JaHVZO2Uv$klY}TW373gaFM0 at SZC{"PGC`'Am8PYiY2eD:121264487
DEBUG: Code 3 at SZC{"PGC`'Am8PYiY2eD:213134952
DEBUG: Code 0 at %{<&\Y:cX~;4Nz$`suTqp:213134216
DEBUG: Code 0 at zUY]tDXPhtp'U4CMGCg:213132031
Failed to save title 6 to file D:/@BR Movies/In_Time/t06_In_Time.mkv
0 titles saved, 1 failed
Also Mailed in the dump...
Axe
Axe
Any luck? Haven't had a response for a while. Seems like all new 20th Century Fox releases are giving this issue. The Rebound (unofficial release, but still same company) just added to the list.
hoffmanxtreme
MrMKV wrote:Any luck? Haven't had a response for a while. Seems like all new 20th Century Fox releases are giving this issue. The Rebound (unofficial release, but still same company) just added to the list.
Hello guys,
I also can't rip the movie "In TIme". MakeMKV seems to be a great program so far, but I'm guessing all new movies are going to be more difficult to rip? Protection too strong? If someone could please post a solution for a dummy(like me) to this I would be most grateful.
Edit: I'm very new to all this, I apologize, so please explain in dumb terms so I can follow along with you guys about getting this done.
Doesn't work for me either. Attempting rip on the retail version extended UPC #0-24543-78296-4-80 purchased at Best Buy. Anyone know if AnyDVD HD will work for this title? That has worked for me in the past in the very few cases where MakeMKV couldn't do the decrypt until the next version.
robpdotcom
Last I checked, the latest official version of AnyDVD didn't work with this movie, but the beta version did.
You are correct, thanks for that info. This 48 hour old beta version of AnyDVD HD works like a champ:robpdotcom wrote:Last I checked, the latest official version of AnyDVD didn't work with this movie, but the bet version did.
http://sandbox.slysoft.com/beta/SetupAnyDVD6918.exe
You can use this in conjunction with MakeMKV to bypass this temporary problem until MakeMKV is updated. I now have a perfect rip of In Time.
