mkv transfare
sid123
mkv transfare
Post by sid123 » Fri Feb 03, 2012 8:32 pm
hi when saving the ripped mkv file to my documents,i then try to send it to my verbatim 1 gb external hard drive but get a pop up saying file is to large. the file is only 6.5 gb is this because i am useing the trial beta version.
appreciate any help on this one please ....sid123
crowfax
Re: mkv transfare
Post by crowfax » Fri Feb 03, 2012 8:49 pm
sid123 wrote:hi when saving the ripped mkv file to my documents,i then try to send it to my verbatim 1 gb external hard drive but get a pop up saying file is to large. the file is only 6.5 gb is this because i am useing the trial beta version.
No it's because your drive is formatted to FAT32 and as such it won't let you copy files over that are bigger than 4gb.
sid123
Re: mkv transfare
Post by sid123 » Fri Feb 03, 2012 9:18 pm
thanks Crowfax is there a way rounds this because i'm thinking of getting the pch a 300 media player.
and was going to usb the verbatin from that,
i wan't to put a lot of films on this drive,any idea's on this one many thanks....sid123
crowfax
Re: mkv transfare
Post by crowfax » Fri Feb 03, 2012 9:29 pm
Yes, format the drive as NTFS.
ryanjk333
Re: mkv transfare
Post by ryanjk333 » Fri Feb 03, 2012 9:34 pm
Just take everything off of your external drive, format it to NTFS, and put your videos, etc. back on it. I own the PCH C-200 and I connect NTFS formatted hard drives to it via USB to play my media all the time.
As stated, the size limit is a limit of the FAT32 format, which must be what your hard drive is formatted in at the moment.
MakeMKV registered!
LG External 12x Super Multi Blue Lightscribe Blu-Ray Rewriter BE12LU30
Popcorn Hour C-200
sid123
Re: mkv transfare
Post by sid123 » Sat Feb 04, 2012 7:12 pm
many thanks Crowfax and Ryanjk333 will do that ....sid123
sid123
Re: mkv transfare
Post by sid123 » Sun Feb 05, 2012 7:25 pm
hi if i use the a300 or the c300 pch can i put a 3tb inside the pch, and usb another 3 or 4tb drive on the back of the pch.
and without useing the network can i just hdmi out of the pch into my onkyo 609 amplifier.and get 1080p and dts master audio to my t/v or projector with mkv files.is this possible many thanks....sid123
ryanjk333
Re: mkv transfare
Post by ryanjk333 » Sun Feb 05, 2012 8:55 pm
If you want to use a 3TB hard drive inside the PCH, check their compatibility list first to make sure the exact model of hard drive you want to use INSIDE the PCH is known to be compatible:
http://www.networkedmediatank.com/wiki/index.php/A-300_Compatibility_Lists
You should have no problem attaching as many additional USB hard drives as there are USB ports on the unit.
I also own the Onkyo TX-NR609. It's been a great receiver, and when I hook the PCH to it via HDMI, I can pass DTS-HD MA and TrueHD audio from my MKV files created with MakeMKV to it. The only problem I have is that some odd blu rays come with LPCM audio for the high definition audio and when creating MKVs of those movies with MakeMKV, the PCH refuses to play the audio. I'm told that MakeMKV will soon have a solution to this problem but in the meantime all movies with DTS-HD MA and TrueHD should work fine for you.
MakeMKV registered!
Popcorn Hour C-200
sid123
Re: mkv transfare
Post by sid123 » Mon Feb 06, 2012 8:22 pm
many thanks Ryanjk333 will do that. yes the onkyo 609 is a great amp for the money still feeling my way round it.
