MakeMKV skips first 10 minutes of ISO home videos
Wolfie1
Post by Wolfie1 »
I'd be grateful for any help with the following. I've successfully converted ca. 50 home video ISO file using MakeMKV with no issues. But for some reason there are 3 others, all 1 hour and a few minutes long, of which MKV converts only the last 53 minutes. I get the following log:
"Cells 1-37 were removed from title start
Title #1 was added (200 cell(s), 0:52:52)
Operation successfully completed".
This is the same for all 3 files. I can convert all 3 ISOs in their full length to MP4 or (re-encoded) MKV using Handbrake, but I'd like to keep the originals as MKV files if possible. I see someone posted a similar message a few years ago with the ""Cells 1-37 were removed from title start" issue, but I didn't understand the reply, which didn't look like it solved the issue.
Thanks in advance.
GL
