Get UHD Access From the E116 Version of ASUS BW-16D1H-U?
Re: Get UHD Access From the E116 Version of ASUS BW-16D1H-U?
#16 Post by Coopervid » Thu Sep 25, 2025 8:34 am
sugi1 wrote: Wed Sep 24, 2025 9:04 pm I seem to have the same problem. Any help is appreciated.
Drive info:
Loaded SDF.bin version 0x98
SDF.bin version: 0x0098
Drive Tool SDF present
Drive Specific SDF present
[Drive Specific SDF] Embedded Info Strings:
8000:LibreDrive Information
8013:Status
8105:Enabled
8001:Drive platform
:RS8F00
8015:Firmware name
:PIONEER BDR-212T
8002:Firmware type
8106:Original (unpatched)
8003:Firmware version
:E116/ID71
8005:DVD all regions
8100:Yes
8006:BD raw data read
8100:Yes
8007:BD raw metadata read
8100:Yes
8009:Unrestricted read speed
8100:Yes
[Drive Specific SDF] Embedded Status Message:
8099:Using LibreDrive mode (v%1 id=%2)
:01.0
:D0CE65A7F569
Identification SDF present
8013:Status
8001:Drive platform
:Pioneer RS8F00
:ID71
pioneer:SAT :8F00:ID71:    :ASUS    :BW-16D1H-U      E116: 20/07/21  :-
PM sent.
WALTunne
#17 Post by WALTunne » Wed Oct 01, 2025 9:06 pm
Hello guys, i don't know which firmware i have to write. Can someone help me ?
Drive info :
Informations lecteur
Nom du lecteur SE : F:
Fabricant : ASUS
Produit : BW-16D1H-U
Révision : E116
Numéro de série : DIDL120081WL
Date micrologiciel : 2020-07-21
Marqueurs d'encryptage bus : 1B
Drive platform: RS8F00
Firmware version: E116/ID71
#18 Post by Coopervid » Thu Oct 02, 2025 11:32 am
WALTunne wrote: Wed Oct 01, 2025 9:06 pm Hello guys, i don't know which firmware i have to write. Can someone help me ?
Drive info :
Fabricant : ASUS
Révision : E116
PM is comimng. The forum is terribly slow and I have a lot of timeouts.
ducky007
#19 Post by ducky007 » Tue Oct 07, 2025 5:07 pm
Hi folks, I been searching the forums and have not found a solution to get my drive to accept
UHD discs. Found this thread and I thought I try here. Help :)
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: X
Firmware date: 2020-07-21
x10bulls
#20 Post by x10bulls » Mon Oct 13, 2025 10:19 pm
Can I please get help for a working firmware to rip UHD titles. Here's my drive info:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
#21 Post by Coopervid » Tue Oct 14, 2025 10:06 am
ducky007 wrote: Tue Oct 07, 2025 5:07 pm Hi folks, I been searching the forums and have not found a solution to get my drive to accept
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: X
PM sent.
#22 Post by Coopervid » Tue Oct 14, 2025 10:08 am
x10bulls wrote: Mon Oct 13, 2025 10:19 pm Can I please get help for a working firmware to rip UHD titles. Here's my drive info:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
PM sent.
evo_day
#23 Post by evo_day » Mon Oct 27, 2025 11:19 am
Coopervid wrote: Tue Oct 14, 2025 10:08 am
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
PM sent.
@Coopervid, wonder if you could help me with the same?
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: *****************
Highest AACS version: 82
#24 Post by Coopervid » Mon Oct 27, 2025 11:23 am
evo_day wrote: Mon Oct 27, 2025 11:19 am
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
PM sent.
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Sure. PM is coming.
GDNCHN!
#25 Post by GDNCHN! » Fri Apr 03, 2026 5:57 am
Coopervid wrote: Thu Aug 28, 2025 8:51 pm
GDNCHN! wrote: Thu Aug 21, 2025 1:54 pm Drive Information
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
The biggest difference between my drive and the common ones is that its firmware is "E116", compared to the often-seen ones with "E114" or "E115" firmware. But since the LibreDrive is enabled, I put an UHD disc inside. Surprisingly, after a while of reading, MakeMKV just simply told me that there is "No Disc" inside. That's awful. What should I do, or which firmware should I patch since its chip is not MT1959?
PM sent.
Could you send me that PM again? I haven't got time to see that. Thanks!
#26 Post by Coopervid » Fri Apr 03, 2026 7:09 pm
GDNCHN! wrote: Fri Apr 03, 2026 5:57 am
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
PM sent.
Sorry. Look elsewhere. Half a year after sending the firmware right away you lost youir window of opportunity. I just dislike slow people who ask for help and then disappear.
#27 Post by Billycar11 » Sat Apr 04, 2026 9:38 pm
Coopervid wrote: Fri Apr 03, 2026 7:09 pm
PM sent.
Sure email me that drive info section see below for email
