Flashing Archgon MD-8107S-U3YC-UHD drive
Taddion
#1 Post by Taddion » Mon Aug 11, 2025 3:40 pm
Hello, I recently received an Archgon drive (model MD-8107S-U3YC-UHD) & I'm wondering where could I find a proper software & files for flashing?
This is the info I got:
Source
BD-RE HL-DT-ST BD-RE BU40N 1.02 MO1OBT15813
OS device name: K:
Product: BD-RE BU40N
Revision: 1.02
Serial number: MO1OBT15813
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Any help would be appreciated, thank you.
Re: Flashing Archgon MD-8107S-U3YC-UHD drive
#2 Post by dcoke22 » Tue Aug 12, 2025 1:20 am
The Ultimate UHD Drives Flashing Guide is kept up to date with all the instructions and links to the tools and files you need to flash your drive. It is pretty dense, so you might have to read it twice to fully understand what's in there.
Your drive is a BU40N. Assuming your drive meets the criteria to flash (listed at the top of the post), the guide says to flash a "BU40N on any Firmware directly to > BU40N 1.03MK".
If you're on Windows, the SDFtool GUI makes it fairly easy to do. You can find a link to that tool in the Guide.
Taddion
#3 Post by Taddion » Thu Aug 14, 2025 7:26 pm
Most helpful, thank you very much!
Taddion
#4 Post by Taddion » Tue Sep 30, 2025 8:19 pm
Hello, I have a problem with flashing archgon drive, while flashing on the previous drive went fine & it's working, I bought another one, the same, but I can't flash it. When I load bin file, & when I click start, nothing happens.
OS device name: E:
Revision: 1.02
Serial number: MO2OC591831
Any clues how to fix this?
#5 Post by dcoke22 » Tue Sep 30, 2025 9:00 pm
Does your drive have the controller chip described below?
PSA: New Archgon UHD drives do not allow flashing
#6 Post by MartyMcNuts » Tue Sep 30, 2025 11:43 pm
Taddion wrote: Tue Sep 30, 2025 8:19 pm Hello, I have a problem with flashing archgon drive, while flashing on the previous drive went fine & it's working, I bought another one, the same, but I can't flash it. When I load bin file, & when I click start, nothing happens.
OS device name: E:
Revision: 1.02
The new Archgons can't be flashed in the enclosure. You can take the drive out of the enclosure and connect it via mini sata? i think and flash it that way.
Taddion
#7 Post by Taddion » Wed Oct 01, 2025 7:10 pm
Well, someone already mentioned on the forum in a similar post, that the newer controllers are the problem. I've already had an older version of the same drive and simply swapped the enclosure & the flashing worked fine.
But still, thank you for the effort.
