leosantare
#61
Post
by leosantare » Tue Jul 29, 2025 5:58 am
leosantare wrote: ↑Fri Jul 25, 2025 5:06 am
Why do you use subtitle edit? For example, do you convert your subtitles to another format?
OCR'ed to SRT you can have Subtitle Edit easily remove text for the hearing impaired as explained in the
FAQ.
[/quote]
Thanks for letting me know. I may look into this. Although, I'm not sure if I want to open this can of worms!
leosantare
#62
Post
by leosantare » Tue Jul 29, 2025 6:05 am
leosantare wrote: ↑Tue Jul 29, 2025 5:58 am
FAQ.
[/quote]
I see the instructions here.
https://imgur.com/a/EosPAOr
If I were to do this, do I have to convert my PGS sub tracks to something else first?
DukeFleed
#63
Post
by DukeFleed » Tue Jul 29, 2025 10:45 am
leosantare wrote: ↑Tue Jul 29, 2025 5:46 am
If you end up getting the Dune HD Homatics Box R 4K Plus player, or one that supports PGS subtitles, would you then have a reason to use subtitle edit?
No, no reason.
leosantare
#64
Post
by leosantare » Thu Jul 31, 2025 4:56 am
Okay. Well thanks again for your help, I should be all set now.
The only other thing I may do is try to turn a SDH sub track into a non-SDH sub track with subtitle edit. Basically, remove all text for the hearing impaired. Although, I want to see if this involves having to convert a PGS track to another format first.
DukeFleed
#65
Post
by DukeFleed » Thu Jul 31, 2025 10:31 am
leosantare wrote: ↑Thu Jul 31, 2025 4:56 am
Yes, you need to convert the PGS track to subrip (.srt) first.
leosantare
#66
Post
by leosantare » Fri Aug 01, 2025 5:34 am
Okay, thanks for letting me know.
It looks like the first step is to extract the PGS subtitle track from the mkv using mkvtoolnix. Then, open the PGS track in Subtitle Edit and convert it to SRT using OCR technology. Next, configure and use the "remove text for the hearing impaired" feature within Subtitle Edit. Converting PGS tracks to text-based formats (like SRT) using OCR can sometimes introduce errors. Therefore, I would need to manually review each track and make corrections if needed. Finally, convert the track back to PGS and then put back in the mkv using mkvtoolnix.
Sounds like too much. Especially, since each track will need to be manually reviewed and corrected if needed.
Chetwood
#67
Post
by Chetwood » Sun Aug 03, 2025 3:56 pm
leosantare wrote: ↑Tue Jul 29, 2025 5:55 am
This is why I asked about changing the positioning that's "baked" in the mkv.
As said before, the BD subs are images, so items can have different positions on the screen and different colors (denoting the actor currently speaking), all of which will be lost when converting to text-based SRTs. It also depends on your player, with Kodi e.g. you can manually move the position on a per-movie basis. Also, Subtitle Edit can parse the mkv so you don't need to extract the PGS sub first. Still, it's OCR which takes time and can introduce errors.
leosantare
#68
Post
by leosantare » Thu Aug 07, 2025 5:04 am
Chetwood wrote: ↑Sun Aug 03, 2025 3:56 pm
Okay, thanks for letting me know. I use VLC as my player which allows you to change the position of the subs. However, I would not want to do this on a per movie basis. I would look to have the positioning exactly the same for all my mkv's using subtitle edit, if possible.
Thats good to know you don't have to extract the PGS track from the mkv, only convert it. Once you convert the PGS track to SRT, use the remove text for the hearing-impaired feature and set the positioning, do you convert back to PGS? I assume this is optional.
Chetwood
#69
Post
by Chetwood » Wed Aug 13, 2025 10:33 am
There's no need to go back to PGS since you've lost positioning and color info anyway. Stick with SRT then cause it's the most supported format.
leosantare
#70
Post
by leosantare » Mon Sep 29, 2025 4:58 am
I finally re-ripped all my discs, this time selecting all the subtitle tracks. I took my time, only doing 1-2 each day. I decided I'm not going to bother with converting SDH tracks into non-SDH tracks. It's just seems like way too much work having to manually review everything. Errors are bound to happen, and I would have to go through all the dialogue word by word correcting any mistakes. That could literally take me years.
I ended up having (42) movies with only main SDH tracks, and the other (30) having both tracks. As I said before, I really prefer non-SDH tracks but I also really don't like having a mix of the two. I could just use the non-SHD track for all my movies that offer it and then have the SDH tracks for movies that don't offer it. In my case, have (30) with non-SDH subs and (42) with SDH subs.
I can also just have all (72) with SDH subs which would keep things the same. What would you choose? I thought I would ask since I'm having a very hard time deciding.
#71
Post
by dcoke22 » Mon Sep 29, 2025 6:19 pm
I also prefer non-SDH subtitle tracks, but if a title only has an SDH track, then that's what I use. Having a mix of the two in my library doesn't bother me all that much.
flojo
#73
Post
by flojo » Tue Sep 30, 2025 4:11 pm
dcoke22 wrote: ↑Mon Sep 29, 2025 6:19 pm
How do you identify the SDH track? If you open the mkv file in mkvtoolnix, are you using the track name property (same place you see "Commentary by drector") or is there a boolean flag to identify it (similar to the default, enabled, etc. flags)?
#74
Post
by dcoke22 » Tue Sep 30, 2025 4:27 pm
flojo wrote: ↑Tue Sep 30, 2025 4:11 pm
I either watch a minute or two of the associated .m2ts file before creating a .mkv file and name the track "SDH Subtitles" in MakeMKV or watch a minute or two of the .mkv file and fix it up with mkvpropedit.
There is a 'commentary' boolean in Matroska v4, but I'm not sure how much support it has in the various players.
https://www.matroska.org/technical/elements.html
flojo
#75
Post
by flojo » Tue Sep 30, 2025 5:18 pm
dcoke22 wrote: ↑Tue Sep 30, 2025 4:27 pm
... watch a minute or two ...
The hardcore way. I guess that info isn't on the disc for makemkv to use.
Absolutely nobody uses that. If present, it identifies as "flag_commentary" with mkvmerge -J. There's also "flag_original", but nobody uses that either. I've looked in files from about 200 "release groups"... not a single instance of either. That said, there's actually a formal specification for it now that includes most (all?) of the "new" properties:
https://www.rfc-editor.org/rfc/rfc9559
