Hello everyone,
I hope you are all having a nice fall.
This Vanilla Sky bluray disc does have some minor scratches, but I have burned a lot worse. What logs do you need and how do I make the logs?
as of right now ( 9-14-2025) I have the newest version of MakeMKV 1.18.1 for windows 11
my windows 11 has all the updates as of right now ( just did all the updates on 9-13-2025 )
messages during the saving to MKV file phase
Saving 1 titles into directory D:/Video/Vanilla Sky
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '5610663936'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '\Device\CdRom1' at offset '5610663936'
DEBUG: Code 3221225653 at A%oe?*<o<t0n{T~IVR:213131502
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '5611057152'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '\Device\CdRom1' at offset '5611057152'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '5611450368'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '\Device\CdRom1' at offset '5611450368'
vanilla sky - bluray
Re: vanilla sky - bluray
It looks like the optical drive can't read that disc properly. If cleaning the disc doesn't help, try getting another copy.
phillip9
Thank you.dcoke22 wrote: Mon Sep 15, 2025 9:01 pm It looks like the optical drive can't read that disc properly. If cleaning the disc doesn't help, try getting another copy.
have a good week.
