Your Highness Blu-Ray won't rip
ghalepa
Post by ghalepa »
Have had no luck ripping Your Highness. The log info is as follows:
Debug log started at Wed Feb 1 05:49:06 2012 , written by MakeMKV v1.7.1 darwin(x86-release)
001005:0000 MakeMKV v1.7.1 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/greghale/MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL TSSTcorp CDDVDW SH-S222L SB02" opened in DASPI v1.3 mode.
002014:0000 Optical drive "DVD+R-DL PIONEER DVD-RW DVR-118L 1.02" opened in DASPI v1.3 mode.
002014:0000 Optical drive "BD-RE HL-DT-ST BD-RE WH10LS30 1.00" opened in DASPI v1.3 mode.
DAFD=ZeNpjYGDgYWBgcGDkZWVhBAIGNAAACgsAaA==
DCE=/c2jKxok3X5pzYOkeVjY1EB5gj3Mzn9zwakKgAfSwzJQ271g/Kxcwuusi3AqzGWe5oVkkHykWsrsEF8azsSzaAdS110+R0egPYmZf/NtAoUF/u+GsJ+1h3ehJViZ+ZvWkc3IAf2cR55oJI21bhHJvIWFIySuiiEM8w==
DISCID=3BAA8BC14B1F9B88115C20BAFA657D00D4BA7E46
003025:0000 Title #00013.mpls has length of 118 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00020.mpls has length of 172 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003307:0000 File 00801.mpls was added as title #0
003307:0000 File 00800.mpls was added as title #1
003025:0000 Title #00300.mpls has length of 127 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00303.mpls has length of 495 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00310.mpls has length of 913 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50057.m2ts has length of 23 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50058.m2ts has length of 23 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00084.m2ts has length of 59 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00085.m2ts has length of 59 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00061.m2ts has length of 23 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00062.m2ts has length of 14 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00078.m2ts has length of 59 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50199.m2ts has length of 88 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50200.m2ts has length of 83 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00301.m2ts has length of 75 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50278.m2ts has length of 72 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50283.m2ts has length of 93 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50284.m2ts has length of 37 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50286.m2ts has length of 36 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50288.m2ts has length of 49 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50290.m2ts has length of 320 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50292.m2ts has length of 60 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50294.m2ts has length of 196 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50296.m2ts has length of 64 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50298.m2ts has length of 30 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50300.m2ts has length of 132 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50302.m2ts has length of 783 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50304.m2ts has length of 92 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50306.m2ts has length of 404 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50308.m2ts has length of 20 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50310.m2ts has length of 31 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50312.m2ts has length of 252 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50314.m2ts has length of 44 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50316.m2ts has length of 183 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50318.m2ts has length of 58 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50320.m2ts has length of 30 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50322.m2ts has length of 123 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50324.m2ts has length of 753 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50326.m2ts has length of 93 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #50328.m2ts has length of 397 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00302.m2ts has length of 52 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00304.m2ts has length of 53 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00305.m2ts has length of 40 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00306.m2ts has length of 94 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00307.m2ts has length of 80 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00308.m2ts has length of 56 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00309.m2ts has length of 170 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00311.m2ts has length of 155 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00312.m2ts has length of 374 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00313.m2ts has length of 95 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00314.m2ts has length of 287 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00315.m2ts has length of 314 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003307:0000 File 00316.m2ts was added as title #2
003025:0000 Title #00317.m2ts has length of 243 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00318.m2ts has length of 152 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00319.m2ts has length of 177 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00320.m2ts has length of 31 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory /Volumes/4TBInternalRAID/BD Rips
AV sync issues in /Volumes/4TBInternalRAID/BD Rips/t01_Your_Highness.mkv
AV sync in 1 at 0:05:05.513 (1.125ms) : encountered overlapping frame, audio skew is +1.125ms
AV sync in 1 at 0:05:26.326 (8.875ms) : encountered overlapping frame, audio skew is +10ms
AV sync in 1 at 0:08:27.465 (2.041ms) : encountered overlapping frame, audio skew is +12.041ms
AV sync in 1 at 0:08:27.477 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +1.375ms
AV sync in 1 at 0:08:59.288 (5.875ms) : encountered overlapping frame, audio skew is +7.25ms
AV sync in 1 at 0:12:30.082 (0.75ms) : encountered overlapping frame, audio skew is +8ms
AV sync in 1 at 0:16:42.126 (9.875ms) : encountered overlapping frame, audio skew is +17.875ms
AV sync in 1 at 0:16:42.144 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +7.208ms
001003:0020 DEBUG: Code 1073741829 at *pm~N/v^\V`~p8]m:29393953
001003:0020 DEBUG: Code 2 at Au7(RxZ%-VF)Bv:8:121268719
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:6410' occurred while reading '/BDMV/STREAM/50291.m2ts' at offset '553512960'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:6410' occurred while reading '/BDMV/STREAM/50291.m2ts' at offset '555024384'
002003:0000 Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/50291.m2ts' at offset '555220992'
002003:0000 Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/50291.m2ts' at offset '560922624'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:6410' occurred while reading '/BDMV/STREAM/50291.m2ts' at offset '561119232'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:6410' occurred while reading '/BDMV/STREAM/50291.m2ts' at offset '561967104'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:6410' occurred while reading '/BDMV/STREAM/50291.m2ts' at offset '562163712'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:6410' occurred while reading '/BDMV/STREAM/50291.m2ts' at offset '567668736'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:6410' occurred while reading '/BDMV/STREAM/50291.m2ts' at offset '569376768'
001003:0020 DEBUG: Code 0 at fYOvuPAb.DGsyDr?J_yp:29394298
001003:0020 DEBUG: Code 0 at xp{9w7;k_9jFyA=mY\m{:121261681
001003:0020 DEBUG: Code 0 at fYOvuPAb.DGsyDr?J_yp:29394183
001003:0020 DEBUG: Code 278016 at fYOvuPAb.DGsyDr?J_yp:29393309
001003:0020 DEBUG: Code 0 at &-(ag$26FH]O}_BmHnA{@:213134216
005003:0000 Failed to save title 1 to file /Volumes/4TBInternalRAID/BD Rips/t01_Your_Highness.mkv
005004:0080 0 titles saved, 1 failed
crowfax
Re: Your Highness Blu-Ray won't rip
Post by crowfax »
Damaged disc or failing drive.
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
ghalepa
Post by ghalepa »
Thanks for the info. Would you mind telling me what it is in the dump that makes you say this?
crowfax
Post by crowfax »
Your drive can't read the disc.
Damaged disc, or failing drive.
ghalepa
Post by ghalepa »
Ah. Okay - the SCSI errors are the tip off. That makes sense. Thanks again.
