Trouble with The Big Year Blu-Ray
ghalepa
#1 Post by ghalepa » Sat Feb 04, 2012 5:39 am
There are two titles on this disc, and neither will rip. The log info for each title is below:
Title 1:
Saving 1 titles into directory /Volumes/4TBInternalRAID/BD Rips
AV synchronization issues were found in file '/Volumes/4TBInternalRAID/BD Rips/t00_The_Big_Year.mkv' (title #1)
AV sync issue in stream 1 at 0:02:11.756 with duration of 8.708ms : encountered overlapping frame, audio skew is +8.708ms
AV sync issue in stream 1 at 0:03:19.240 with duration of 3.916ms : encountered overlapping frame, audio skew is +12.625ms
AV sync issue in stream 1 at 0:03:19.253 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +1.958ms
The source file '/BDMV/STREAM/00850.m2ts' is corrupt or invalid at offset 59682816, attempting to work around
DEBUG: Code 0 at kz4G7hor2%*m:&rqXa>@:213133158
The source file '/BDMV/STREAM/00850.m2ts' is corrupt or invalid at offset 65968128, attempting to work around
DEBUG: Code 21 at kz4G7hor2%*m:&rqXa>@:121267155
DEBUG: Code 0 at &-(ag$26FH]O}_BmHnA{@:213134216
DEBUG: Code 0 at A2X`BB7z,3$@hS)#t~M:213132031
Failed to save title 0 to file /Volumes/4TBInternalRAID/BD Rips/t00_The_Big_Year.mkv
0 titles saved, 1 failed
Title 2:
AV synchronization issues were found in file '/Volumes/4TBInternalRAID/BD Rips/t01_The_Big_Year.mkv' (title #2)
AV sync issue in stream 1 at 0:03:05.226 with duration of 10.625ms : encountered overlapping frame, audio skew is +10.625ms
AV sync issue in stream 1 at 0:04:12.710 with duration of 3.916ms : encountered overlapping frame, audio skew is +14.541ms
AV sync issue in stream 1 at 0:04:12.725 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +3.875ms
DBG ASSERT: Zcaq/S}lNi6v[P+f54fGLLIUGp){'w|U2Tv]M?*SM%a&Z'#^55=$5J!Gtcy2<$Sp$'iQu$-7(No0,h'J at kz4G7hor2%*m:&rqXa>@:121264487
The source file '/BDMV/STREAM/00897.m2ts' is corrupt or invalid at offset 37232640, attempting to work around
DEBUG: Code 5 at kz4G7hor2%*m:&rqXa>@:213134952
Failed to save title 1 to file /Volumes/4TBInternalRAID/BD Rips/t01_The_Big_Year.mkv
crowfax
Re: Trouble with The Big Year Blu-Ray
#2 Post by crowfax » Sat Feb 04, 2012 5:42 am
Just like your other post, the answer is the same. Damaged disc or failing drive. Given you now have 3 discs with issues, you're either having an awful run of bad luck, our your drive is giving out.
MrMKV
#3 Post by MrMKV » Sat Feb 04, 2012 6:06 pm
crowfax wrote:Just like your other post, the answer is the same. Damaged disc or failing drive. Given you now have 3 discs with issues, you're either having an awful run of bad luck, our your drive is giving out.
I've had the same issues with the last 20th century Fox releases...In Time, The Big Year and The Rebound. Sent the dump files and haven't had a response for almost a week. No issues with my drive since I managed to succeed with 10 other titles.
crowfax
#4 Post by crowfax » Sat Feb 04, 2012 6:19 pm
His log files indicate very clearly that his drive can't read the discs, or that they can read the disc and the data is corrupt.
His issues are not copy protection related.
There is no copy protection that can cause this.
Please don't try to derail threads.
setarip_old
#5 Post by setarip_old » Sat Feb 04, 2012 6:40 pm
they can read the disc and the data is corrupt. His issues are not copy protection related. There is no copy protection that can cause this.
(Porgy and Bess) It ain't necessarily so. Corrupt/bad sectors, that allow for playback but NOT reading, have long been included in copy prevention schemes...
crowfax
#6 Post by crowfax » Sat Feb 04, 2012 10:02 pm
setarip_old wrote:Corrupt/bad sectors, that allow for playback but NOT reading, have long been included in copy prevention schemes...
is this one of those times?
Romansh
#7 Post by Romansh » Sun Feb 05, 2012 12:03 am
setarip_old wrote:(Porgy and Bess) It ain't necessarily so. Corrupt/bad sectors, that allow for playback but NOT reading, have long been included in copy prevention schemes...
You mean structural copy protection? That's found on DVDs but not Blu-ray, AFAIK - which is why e.g. MakeMKV's backup feature is BD-only, or why AnyDVD's Image Ripper is not recommended for use with DVDs but is fine for Blu-ray ripping…
setarip_old
#8 Post by setarip_old » Sun Feb 05, 2012 7:06 am
@Romansh
Hi!
My comment was a response to the general statement that did not refer specifically to Blu-ray discs (Admittedly a bit unclear on my part since the thread appears in the Blu-ray errors Sub-forum)...
#9 Post by mike admin » Sun Feb 05, 2012 6:01 pm
If you posted the full log, there would be less confusion as it contained the line about errors during BD+ processing. Now the SVQ file is updated, this disc should work.
