Can no longer rip UHD discs
AndyLandy
Post by AndyLandy »
I'm running MakeMKV 1.18.2 on both macOS and Linux, and have been successfully ripping UHD discs, but am unable to do so any more. The only thing that has changed are the USB enclosures that the drives are in. If I put the drives back in an old enclosure, they work. The new enclosures work fine for ripping regular 1080 Blu-rays, but not UHD. The drives themselves are BU-40N with v1.04 firmware and LibreDrive enabled. Is this a known issue? Is there a fix? I don't really understand why the USB-to-SATA interface would prevent UHD discs from being ripped.
The errors I'm seeing are:
MSG:3007,0,0,"Using direct disc access mode","Using direct disc access mode"
MSG:5085,0,0,"Loaded content hash table, will verify integrity of M2TS files.","Loaded content hash table, will verify integrity of M2TS files."
MSG:2004,0,4,"Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SG:dev_21:3'","Error '%1' occurred while issuing SCSI command %4 to device '%2:%3'","Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT","SG","dev_21:3","A30..0020..03F"
MSG:1003,16777248,3,"DEBUG: Code 0 at PwH=#GLZH Fj*4D?{:213130766","DEBUG: Code %1 at %2:%3","0","PwH=#GLZH Fj*4D?{","213130766"
MSG:1003,32,3,"DEBUG: Code 0 at pKR,,<Y4`?)Y\\ru%M^:213131709","DEBUG: Code %1 at %2:%3","0","pKR,,<Y4`?)Y\\ru%M^","213131709"
and later:
MSG:1003,32,3,"DEBUG: Code 4 at pKR,,<Y4`?)Y\\ru%M^:213130789","DEBUG: Code %1 at %2:%3","4","pKR,,<Y4`?)Y\\ru%M^","213130789"
MSG:3306,0,0,"Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive","Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive"
MSG:1003,32,3,"DEBUG: Code 0 at J9nz|TUj[9tsqH);:121267063","DEBUG: Code %1 at %2:%3","0","J9nzTUj[9tsqH);","121267063"
Re: Can no longer rip UHD discs
AndyLandy wrote:
Tue Sep 30, 2025 8:26 am
and later:
For Linux you should flash BU40N 1.00
