Unable to decrypt with v1.18.2 and am seeking assistance. Have sent the dump file to svq@makemkv.com too.
Also uploaded to my google drive:
https://drive.google.com/file/d/1AO0EA9 ... sp=sharing
AACS 82 - How To Train Your Dragon (2025)
Re: AACS 82 - How To Train Your Dragon (2025)
The latest KeyDB file already has a record for your disc: MKB_v82_How_to_Train_Your_Dragon_(2025)_FDF2 with discID 9A9149AB1E0D6816A3CC3CB2AD95AB1700B6C453KillerBus wrote: ↑Mon Sep 29, 2025 6:17 pmUnable to decrypt with v1.18.2 and am seeking assistance. Have sent the dump file to svq@makemkv.com too.
If you download and extract the latest KeyDB.cfg file to the MakeMKV data directory (where the dumps are) you should be able to rip it.
wo genau befinden sich die dumps? wie sehen die aus. Ich habe die key datei unter "C:\Program Files (x86)\MakeMKV" rein kopiert. aber es ändert sich nichts. muss man MKV irgendwie einstellen damit er die verwendet?
The dumps are in MakeMKV's data directory. You can see it in preferences but the default location should be C:\Users\username\.MakeMKV
You should also put the KeyDB.cfg file in this location.
Ok Danke. Frage, wenn ich eine UHD wie John Rambo habe, die nicht geht. Wie stelle ich die Tgz Datei hier zur Verfügung? Datei anhänge geht nicht. Kommt immer Meldung "Kontingent erschöpft)
Here's a recent BluRay from Japan that needs submitting.
https://www.blu-ray.com/movies/RRR-Behi ... ay/392011/
AACS Dump File: https://gofile.io/d/du8C78
You host the dump file somewhere such as googledrive, onedrive, mediafire etc then post a download link.
