HL-DT-ST BDDVDRW CU10N flashable?
ChaosEnergy
Post by ChaosEnergy » Sat Sep 27, 2025 6:33 pm
Laufwerksinformation
OS-Gerätename: \Device\CdRom0
Aktuelles Profil: DVD-ROM
Produzent: HL-DT-ST
Produkt: BDDVDRW CU10N
Revision: 1.00
Serienummer:
Firmware-Datum: 2113-10-30 10:43
Markierungen der Bus-Verschlüsselung: 1E
Does this mean the drive is flashable, maybe even able to read uhd?
(submitted dump like asked by the app)
Re: HL-DT-ST BDDVDRW CU10N flashable?
Post by Coopervid » Sat Sep 27, 2025 9:17 pm
ChaosEnergy wrote: Sat Sep 27, 2025 6:33 pm Laufwerksinformation
Produzent: HL-DT-ST
Revision: 1.00
Serienummer:
Most likely not. Pretty sure you will brick this drive trying. MT1959 is fulfilled but firmware date should be at least late 2015. They named the revision of MT1939 as MT1959 but only the hardware revisions of MT1959 from late 2015 are actually flashable for UHD.
ChaosEnergy
Post by ChaosEnergy » Sun Sep 28, 2025 7:50 pm
thanks for reply
so even stanbdard blu ray reading wont be possible
thought i have had luck ;)
Post by Coopervid » Sun Sep 28, 2025 8:14 pm
ChaosEnergy wrote: Sun Sep 28, 2025 7:50 pm thanks for reply
standard BluRays will work but without the help of libredrive.
