Pioneer BDR-UD03 UHD possibility
DreamAway
Re: Pioneer BDR-UD03 UHD possibility
#796 Post by DreamAway » Sat Sep 27, 2025 1:15 pm
Hi, I just bought a Verbatim 43890 with a Pioneer UD03 inside. Can someone help to set it up for UHD ripping if possible?
Laufwerksinformation
OS-Gerätename: /dev/sr1
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.11
Serienummer: ***
Firmware-Datum: 2018-11-28
Highest AACS version: 12
Drive platform: RS8511
Firmware version: 1.11
(I'm currently using Linux but also have access to Windows if needed)
#797 Post by Coopervid » Sun Sep 28, 2025 9:25 am
DreamAway wrote: Sat Sep 27, 2025 1:15 pm Hi, I just bought a Verbatim 43890 with a Pioneer UD03 inside. Can someone help to set it up for UHD ripping if possible?
Produzent: PIONEER
Revision: 1.11
Serienummer: ***
PM sent.
LroweMKV
#798 Post by LroweMKV » Wed Oct 01, 2025 9:07 am
Hello, I just discovered that I also have a Verbatim 43890 with a Pioneer UD03 inside that I previously used for Blu-Rays back in the day. Can someone help to set it up for UHD ripping as well?
OS-Gerätename: F:
Produzent: PIONEER
Revision: 1.11
Serienummer: SGDL243340WL
Highest AACS version: 68
#799 Post by Billycar11 » Thu Oct 02, 2025 12:31 am
LroweMKV wrote: Wed Oct 01, 2025 9:07 am Hello, I just discovered that I also have a Verbatim 43890 with a Pioneer UD03 inside that I previously used for Blu-Rays back in the day. Can someone help to set it up for UHD ripping as well?
OS-Gerätename: F:
Produzent: PIONEER
Revision: 1.11
Sure just email me that drive info see below for email
Matista217
#800 Post by Matista217 » Thu Oct 02, 2025 7:42 pm
Coopervid wrote: Mon Jun 16, 2025 8:29 am
Matista217 wrote: Mon Jun 16, 2025 5:57 am Tapping in! very excited to now DUAL WIELD UHD RIPPING
Manufacturer: PIONEER
Product: BD-RW BDRUD03AS
Revision: 1.00
Serial number: ----
Firmware date: 2014-04-01
Highest AACS version: 81
Drive platform: Pioneer RS8510
Firmware version: ID23
PM sent.
Sorry, but it looks like the DM expired before i could access it. Mind sending it over again?
#801 Post by Coopervid » Thu Oct 02, 2025 7:45 pm
Matista217 wrote: Thu Oct 02, 2025 7:42 pm
Revision: 1.00
Serial number: ----
PM sent.
Four months later. Are you nuts??? Contact Billy and pay your $25.
uzless
#802 Post by uzless » Mon Oct 06, 2025 2:02 am
Any chance I can obtain the scoop on how to update to the UHD possibility? Many thanks if yes.
Also anyone know how long it takes to copy a UHD disk? It takes me about 1.5 hours to copy a blu ray.
Cheers and thanks.
BD-RE Pioneer BD -RW BDR-UD03 1.10 RBDL140447WL
Natenbo64
#803 Post by Natenbo64 » Mon Oct 06, 2025 5:26 am
Hello. I'm new here. I recently bought a Verbatim 43890 at a Staples (ie. a Pioneer BD-RW, BDR-UD03). I checked on the regular BDs I have and those appear to play/rip fine enough on the writer, but I have been told that I could possibly rip UHDs from it. Here is the information on the writer in question:
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: ****
Firmware date: 2020-06-15
Firmware version: 1.14
#804 Post by Billycar11 » Mon Oct 06, 2025 1:21 pm
Natenbo64 wrote: Mon Oct 06, 2025 5:26 am Hello. I'm new here. I recently bought a Verbatim 43890 at a Staples (ie. a Pioneer BD-RW, BDR-UD03). I checked on the regular BDs I have and those appear to play/rip fine enough on the writer, but I have been told that I could possibly rip UHDs from it. Here is the information on the writer in question:
Revision: 1.14
Serial number: ****
uzless wrote: Mon Oct 06, 2025 2:02 am Hello,
Cheers and thanks.
sure just email me for the flasher to do UHD just send your drive info section from makemkv
uzless
#805 Post by uzless » Mon Oct 06, 2025 2:36 pm
Billycar11 wrote: Mon Oct 06, 2025 1:21 pm sure just email me for the flasher to do UHD just send your drive info section from makemkv
Thanks. Email sent. posting info here, too, if it's helpful.
Revision: 1.10
Serial number:
Firmware date: 2017-04-18
Highest AACS version: 75
Firmware version: 1.10
cewillcutt
#806 Post by cewillcutt » Sat Oct 11, 2025 7:37 pm
Hi there,
I'd love to be able to enable my Verbatim drive to be able to Rip 4k UHDs. I've performed other Firmware flashes with the SDFtool before (ASUS drives), but have some stubborn discs that the ASUS won't rip.
OS device name: G:
Revision: 1.14
Serial number: ...
Highest AACS version: 82
#807 Post by Coopervid » Sun Oct 12, 2025 9:34 am
cewillcutt wrote: Sat Oct 11, 2025 7:37 pm Hi there,
OS device name: G:
Revision: 1.14
Serial number: ...
PM sent.
Kurisu3K
#808 Post by Kurisu3K » Sun Oct 12, 2025 12:51 pm
Hi, I got a BDR-UD03 and would appreciate if I could get the firmware so i can flash it.
Here is the drive info from MakeMKV:
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.03
Serienummer: xxx
Firmware-Datum: 2015-05-14
Drive platform: RS8510
Firmware version: 1.03/ID19
#809 Post by Coopervid » Sun Oct 12, 2025 1:08 pm
Kurisu3K wrote: Sun Oct 12, 2025 12:51 pm Hi, I got a BDR-UD03 and would appreciate if I could get the firmware so i can flash it.
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.03
Serienummer: xxx
PM is coming.
WonderMage
#810 Post by WonderMage » Sun Oct 12, 2025 6:32 pm
Hi, I have a Pioneer BDR-UD03 from a verbatim 43890. May I please have the firmware for flashing for UHD discs. Thank you and all of the contributors for this ability to preserve our media.
OS device name: E:
Revision: 1.14
Serial number: ...
