AACS v82 submission - Saling To Philadelphia
ianfretwell
Post by ianfretwell »
Thanks...
Re: AACS v82 submission - Saling To Philadelphia
ianfretwell wrote:
Thu Sep 25, 2025 4:46 pm
Thanks...
What is the point in this?? Please don't create useless threads!! At the very least, try giving some actual useful information!!! You have provided nothing but the name of the movie. All of these types of threads/posts should at a minimum, contain the dump file name.
Did you email the tgz dump file to svq@makemkv.com??
Additionally, if you want to help the community, you can host the dump file somewhere and post a download link here so that someone can add a record for your disc to the public KeyDB database.
ianfretwell
Well when I submitted the post there was an attachment that isn't there now...so it would have been useful if something hadn't stripped that off...
It's attached here...again...lets see what happens this time....
Right so everytime I try to attach it the file shows with a yellow triangle - WTF does that mean? - obviously it doesn't like it but there's nothing to tell me why...only 123KB so it's not size...
suna_ch
Post by suna_ch »
Nice to meet you. (This is a Google translation, so the language may be a bit off.)
It seems like you used to be able to upload attachments directly to the message board, but that's no longer possible.
Currently, if you upload the dump file to your own Google Drive or a shared online storage service and post the link on the message board, they should be able to help.
You can find out where to upload it by looking at the links in other people's posts.
ianfretwell wrote:
Fri Sep 26, 2025 7:19 am
Do not try and attach files here. You should host it somewhere else then provide a download link.
I assume you emailed the dump file to svq@makemkv.com for processing? If not, please do so, otherwise it won't get added to MakeMKV's hashed keys database.
readingandy
Post by readingandy »
thanks for posting,
While yes, maybe a waste of threadspace, but it at least tells others like me who have problems with the same bluray that they aren't looking at a disk problem.
readingandy wrote:
Sat Sep 27, 2025 10:53 am
thanks for posting,
Well you could be. It all depends on what error you get in the log window.
Letsroll911
Post by Letsroll911 »
Hi
not sure if this is what your refering to,
MakeMKV v1.18.2 win(x64-release) started
""""This disc uses newer version of AACS protection."""" Please let us know about it by visiting http://www.makemkv.com/a/?i4rQ985qdMh5OC...
But unable to download into Make MKV for above reason..
mine also does not play in VLC, plays fine in bluray panasonic player in dolby Atmos
Letsroll911 wrote:
Sat Sep 27, 2025 9:00 pm
Hi
If it is a MKBv82 disc, the log window would have said a tgz dump file was created and provided a link to it's location. Click that link to open up the location in explorer and you should email that tgz dump file to svq@makemkv.com
readingandy
Re: AACS v82 submission - Sailing To Philadelphia
Thanks, initially you get
Using LibreDrive mode (v06.3 id=866A98CB9C4E)
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?y2p0D8pA33QPkx. .
and makemkv tries to continue so you never see the tgz message. You only get the tgz message if you cancel. (and not always does the cancel cancel!)
In cases where I've seen the message about tgz before (UHD disks) there was no message about AACS so the message about the tgz was more obvious. Not so in this case.
I did submit the tgz anyway.
ianfretwell
I also submitted the tgz file...last week.
Still not working for me - which just seems to be taking some time - reading through other examples they seem to be added 'next-day'. Is something still missing for this to be able to be done?
readingandy
Worked for me today (thanks Mike)
success on my 2nd try, the first had to do the all important download of the new key. Look for.....
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?GP+kvz6JPohVhk...
Downloading latest HK to C:\Users\tony/.MakeMKV ...
and then restart/try again.
All worth it for the instrumental of Silvertown Blues....
sn0wleo
Post by sn0wleo »
where did you get the new key ? i have the newest version of make mkv and cant open jurassic world rebirth
sn0wleo wrote:
Fri Oct 03, 2025 11:38 pm
What does Jurassic World Rebirth have to do with Sailing to Philidelphia??
Keys are different for different titles and often regions, also batches sometimes.
sn0wleo
Post by sn0wleo »
i thought the key works for more than one movie ^^
