PM sent.graffitiMSX wrote: Fri Sep 12, 2025 9:39 pm Hello, I have a Pioneer BDR-209MBK drive. I'm looking for help to make it UHD friendly with LibreDrive.
OS device name: E:
Current profile: BD-R SRM
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.54
Serial number:
Firmware date: 2022-05-31
Firmware version: ID04
Thank you.
PIONEER BDR-209 change the Firmware ?
Re: PIONEER BDR-209 change the Firmware ?
Mauldäsch
Is it possible for this drive? I can't find anything.
Thank you for aassistance.
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E115
Serial number:
Firmware date: 2019-03-07
Drive platform: RS8F00
Firmware version: E115/ID71
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E115
Serial number:
PM sent.Mauldäsch wrote: Sat Sep 27, 2025 9:52 am Is it possible for this drive? I can't find anything.
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E115
Serial number:
tt1270
hye, i've this pioneer drive, can someone help me to flash the firmware for 4K-UHD?
I wish that Coopervid will help me, one more time
Thanks a lot
Best regards
Informations lecteur
Nom du lecteur SE : D:
Fabricant : PIONEER
Produit : BD-RW BDR-209D
Révision : 1.34
Numéro de série :
Date micrologiciel : 2016-04-25
Marqueurs d'encryptage bus : 13
Version AACS la plus haute : 68
Drive platform: RS8600
Firmware version: 1.34/ID61
Aucun disque
Thanks a lot
Best regards
Fabricant : PIONEER
Révision : 1.34
Numéro de série :
Aucun disque
wildchild77
Looking to see if an older Pioneer drive I had can be upgraded fro UHD
MKV Drive Info Below
OS device name: E:
Product: BD-RW BDR-209D
Revision: 1.10
Serial number: xxxxxxxx
Firmware date: 2013-09-10
Bus encryption flags: 13
Highest AACS version: 77
Firmware version: 1.10/ID61
OS device name: E:
Revision: 1.10
PM sent.tt1270 wrote: Mon Sep 29, 2025 5:58 pm hye, i've this pioneer drive, can someone help me to flash the firmware for 4K-UHD?
Thanks a lot
Best regards
Fabricant : PIONEER
Révision : 1.34
Numéro de série :
Aucun disque
PM sent.wildchild77 wrote: Sat Oct 18, 2025 6:00 pm Looking to see if an older Pioneer drive I had can be upgraded fro UHD
OS device name: E:
Revision: 1.10
ulvac-mkv
I have three models that need more recent firmware:
BDR-209M_1.51
BDR-212V_1.02
BDR-UD03_1.14
Thanks in advance.
BDR-209M_1.51
BDR-212V_1.02
BDR-UD03_1.14
Thanks in advance.
Post the Makemkv info for each drive.ulvac-mkv wrote: Sun Oct 19, 2025 10:50 pm I have three models that need more recent firmware:
BDR-209M_1.51
BDR-212V_1.02
BDR-UD03_1.14
Thanks in advance.
ulvac-mkv
Apologies, here you go:
OS device name: T:
Revision: 1.51
Serial number: QEDL022380WL
Highest AACS version: 81
_________________________
OS device name: Z:
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: DADL025005WL
Firmware version: ID06
OS device name: F:
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: DADL518199WL
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
OS device name: T:
Revision: 1.51
OS device name: Z:
Revision: 1.02
OS device name: F:
Revision: 1.14
The drive platform for the 209 is missing (crucial!). Add this information and I will send the packages for all three.ulvac-mkv wrote: Tue Oct 21, 2025 2:43 pm Apologies, here you go:
OS device name: T:
Revision: 1.51
OS device name: Z:
Revision: 1.02
OS device name: F:
Revision: 1.14
ulvac-mkv
The 209's don't provide any LibreDrive platform info within MakeMKV. This was copied verbatim. Is there another way to retrieve it?
That's weird. I am going to send you the packages for the other 2 drives and instructions how to check the 209. It's crucial since there are 3 versions / possibilities and you need the right version to flasht the 209.ulvac-mkv wrote: Tue Oct 21, 2025 5:35 pm The 209's don't provide any LibreDrive platform info within MakeMKV. This was copied verbatim. Is there another way to retrieve it?
sounds
one more please, if you'd be so kind
Revision: 1.51
Serial number: SGDL0****6WL
Firmware date: 2018-05-08
Drive platform: RS8601
Firmware version: 1.51/ID61
sure email me that drive info see email belowsounds wrote: Thu Oct 23, 2025 7:55 pm one more please, if you'd be so kind
Revision: 1.51
