Hi.
Everytime I try to put a disc into my drive, the disc just spins a bunch and then the drive just spits it out. I've tried several blu-rays and DVDs and the result is the same. I've also tried on both Windows and MacOS with the same result.
Does anyone know if this a typical issue, and how to fix it?
Drive info:
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Drive platform: RS8A10
Firmware version: 1.14
Drive help - Keeps spitting out disc with no error message
Vinterbird
Re: Drive help - Keeps spitting out disc with no error message
The enclosure of these drives is very power hungry. Try a USB-C port on the mainboard or a powered USB hub.Vinterbird wrote: Tue Sep 23, 2025 1:46 pm Hi.
Drive info:
Revision: 1.14
Serial number:
Also - clean the laser lens with a cotton swab and alcohol.
miketex
Just downloaded 1.8.2 version and now the drive just spins the disc and then ejects it out. Prior to downloading the new version everything was workin g fine. What changed in the new version?
Nothing. And don't post the same question in multiple threads.miketex wrote: Fri Sep 26, 2025 4:24 pm Just downloaded 1.8.2 version and now the drive just spins the disc and then ejects it out. Prior to downloading the new version everything was workin g fine. What changed in the new version?
