Hi.
Everytime I try to put a disc into my drive, the disc just spins a bunch and then the drive just spits it out. I've tried several blu-rays and DVDs and the result is the same. I've also tried on both Windows and MacOS with the same result.
Does anyone know if this a typical issue, and how to fix it?
Drive info:
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Drive platform: RS8A10
Firmware version: 1.14
Drive help - Keeps spitting out disc with no error message
Vinterbird
Re: Drive help - Keeps spitting out disc with no error message
The enclosure of these drives is very power hungry. Try a USB-C port on the mainboard or a powered USB hub.Vinterbird wrote: Tue Sep 23, 2025 1:46 pm Hi.
Drive info:
Revision: 1.14
Serial number:
Also - clean the laser lens with a cotton swab and alcohol.
Just downloaded 1.8.2 version and now the drive just spins the disc and then ejects it out. Prior to downloading the new version everything was workin g fine. What changed in the new version?
Nothing. And don't post the same question in multiple threads.miketex wrote: Fri Sep 26, 2025 4:24 pm Just downloaded 1.8.2 version and now the drive just spins the disc and then ejects it out. Prior to downloading the new version everything was workin g fine. What changed in the new version?
