please help, i can't rip it with MakeMKV "This disc uses newer version of AACS protection. The volume key is unknown for this disc - video can't be decrypted. Failed to open disc".
https://www.mediafire.com/file/s8xvle2e ... 2.tgz/file
AACS v82 submission - Aimyon Tour 2024-25
Re: AACS v82 submission - Aimyon Tour 2024-25
Is your disk different from the other three already posted on this disk?
i think it's the same. I downloaded the KEYDB and put it on MakeMKV folder, but still can't rip the disc. What should i do now ? I did something wrong ?
A key for your disc has now been added to the latest KeyDB file.loxng wrote: ↑Thu Sep 25, 2025 4:04 pmplease help, i can't rip it with MakeMKV "This disc uses newer version of AACS protection. The volume key is unknown for this disc - video can't be decrypted. Failed to open disc".
i'm so sorry, my drive is a pioneer drive, so my submission file is unusable. I also emailed to svq@makemkv.com but only the DISC 1, do i need to upload the DISC 2 ? I'm newbie, thank for your help.MartyMcNuts wrote: ↑Thu Sep 25, 2025 11:50 pmA key for your disc has now been added to the latest KeyDB file.loxng wrote: ↑Thu Sep 25, 2025 4:04 pmplease help, i can't rip it with MakeMKV "This disc uses newer version of AACS protection. The volume key is unknown for this disc - video can't be decrypted. Failed to open disc".
You should email the dump generated for each disc.loxng wrote: ↑Fri Sep 26, 2025 1:58 ami'm so sorry, my drive is a pioneer drive, so my submission file is unusable. I also emailed to svq@makemkv.com but only the DISC 1, do i need to upload the DISC 2 ? I'm newbie, thank for your help.MartyMcNuts wrote: ↑Thu Sep 25, 2025 11:50 pmA key for your disc has now been added to the latest KeyDB file.loxng wrote: ↑Thu Sep 25, 2025 4:04 pmplease help, i can't rip it with MakeMKV "This disc uses newer version of AACS protection. The volume key is unknown for this disc - video can't be decrypted. Failed to open disc".
Also, dumps for AACS 1 (standard blu-ray) discs from most Pioneer drives can still be used, just not for UHD discs. I have added the key for the disc you provided a dump for.
Thank you so much Marty, the latest keydb.cfg works. My 2 discs are fully ripped now.
