Ultimate UHD Drives Flashing Guide Updated New Pioneer Flashing 2026
Ernesto13
Hi,Could you help with this, I have an BU40N drive that shows up in MakeMkV with this drive information:
OS device name: E:
Product: BD-RE BU40N
Revision: PA05
Serial number:
Firmware date: 2120-06-11
Bus encryption flags: 1F
Highest AACS version: 62
is it possable to flash the drive?
I'm trying to flash the unit and I get error code 0x82052400.
OS device name: E:
Revision: PA05
Serial number:
Are you flashing it with BU40N 1.03-MK?Ernesto13 wrote: Wed Sep 24, 2025 12:00 am Hi,Could you help with this, I have an BU40N drive that shows up in MakeMkV with this drive information:
OS device name: E:
Revision: PA05
Serial number:
Ernesto13
YesMartyMcNuts wrote: Wed Sep 24, 2025 1:30 amAre you flashing it with BU40N 1.03-MK?Ernesto13 wrote: Wed Sep 24, 2025 12:00 am Hi,Could you help with this, I have an BU40N drive that shows up in MakeMkV with this drive information:
OS device name: E:
Revision: PA05
Serial number:
pse1122pse
Hello, I'm trying to rip some UHD Blu-rays and I'm stuck on a persistent issue with my drive.
My goal is to flash my LG BP60NB10 drive to enable LibreDrive and rip UHD discs.
My Setup:
Drive Model: HL-DT-ST BD-RE BP60NB10
Firmware Version: 1.02 (Original)
Operating System: macOS
Tool: makemkvcon via Terminal
The Problem:
I have successfully flashed my drive multiple times. Each time, the terminal output shows Done successfully, confirming that the flashing process has completed.
However, when I check the drive information in MakeMKV, it still reports Firmware support: No and Firmware type: Original. The drive consistently fails to enter LibreDrive mode.
What I have tried so far:
Multiple Firmware Files: I have tried flashing with different firmware files, including those labeled as UHD-friendly and MK firmware from the forums.
Disconnect/Reconnect: After each successful flash, I have completely unplugged the drive from my Mac and plugged it back in.
Drive Identifier: I have verified the correct drive identifier using makemkvcon f -l before each flashing attempt.
Dump File Submission: I submitted a dump file to the forum, but was told it was useless because LibreDrive was not activated.
I am puzzled as to why my drive's firmware status remains "Original" despite the successful flashes. Am I missing a crucial step for macOS? Is there a specific firmware file for this drive model that I should be using? Or could this be a hardware-related issue?
makemkv info
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIK0CO99J1922
Firmware date: 2121-07-08 15:56
Highest AACS version: 82
Harware support: Yes
Firmware version: 1.02
Please excuse me for using a translation tool.
Any help would be greatly appreciated. Thank you.
My Setup:
The Problem:
makemkv info
Revision: 1.02
Full command line used? Does it include 'enc'?
If using command line are you including 'enc'?Ernesto13 wrote: Wed Sep 24, 2025 3:24 amYesMartyMcNuts wrote: Wed Sep 24, 2025 1:30 amAre you flashing it with BU40N 1.03-MK?Ernesto13 wrote: Wed Sep 24, 2025 12:00 am Hi,Could you help with this, I have an BU40N drive that shows up in MakeMkV with this drive information:
OS device name: E:
Revision: PA05
Serial number:
SlippyFist
Hey,
Thanks for putting this together. I need to flash my drive so i can rip some UHDs but i'm a bit confused about which firmware step i need to follow
here is my drive info from makemkv:
so i have a WP50NB40 with SVC code NB52, and im a tad bit confused about which downgrade path i need to take
OS device name: E:
Product: BD-RE WP50NB40
Revision: 1.03
Serial number: SIM22214I5041
Firmware date: 2121-07-08 16:09
Highest AACS version: 81
Drive platform: MT1959is that first line for NB50 SVC code only so i need the second (annoying) path?Billycar11 wrote: Mon May 27, 2019 5:20 am WP/BP50NB40 to > BP50NB40-NB50-1.03MK then to > BP60NB10 1.02MK or 1.00MK
NB52 to > BP50NB40-NB50-1.03MK with enc > BP50NB40-NB50-1.03MK with bootloader/full flash > BP60NB10 1.00_HBD from Marty download/file.php?id=2143
second line.SlippyFist wrote: Wed Sep 24, 2025 11:55 pm Hey,
so i have a WP50NB40 with SVC code NB52, and im a tad bit confused about which downgrade path i need to takeCode: Select all
Drive Information OS device name: E: Manufacturer: HL-DT-ST Product: BD-RE WP50NB40 Revision: 1.03 Serial number: SIM22214I5041 Firmware date: 2121-07-08 16:09 Bus encryption flags: 17 Highest AACS version: 81 LibreDrive Information Status: Possible, not yet enabled Drive platform: MT1959
pse1122pse
I have tried again with the 'enc' flag as you suggested.
I used the following command:
./makemkvcon f -d '/IOBDServices/AFC9B139' -f /private/tmp/sdf.bin rawflash main enc -i /private/tmp/HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
The terminal showed Done successfully once again.
Revision: 1.02
Serial number:
remove main and just leave encpse1122pse wrote: Thu Sep 25, 2025 12:19 pmI have tried again with the 'enc' flag as you suggested.
Revision: 1.02
Serial number:
pse1122pse
thxBillycar11 wrote: Thu Sep 25, 2025 1:35 pmremove main and just leave encpse1122pse wrote: Thu Sep 25, 2025 12:19 pmI have tried again with the 'enc' flag as you suggested.
Revision: 1.02
Serial number:
SlippyFist
is it possible to use the SDFtool flasher instead of the command line?MartyMcNuts wrote: Thu Sep 25, 2025 2:32 amsecond line.SlippyFist wrote: Wed Sep 24, 2025 11:55 pm Hey,
the SDF thread has this in it:
For the moment, to flash the BP50NB40 SVC:NB52, using the latest SDFtool Flasher, follw the steps below:
1. Flash the drive to BP50NB40 (NB50) 1.03-MK.
Now for the crossflash:
2. Select the RECOVERY option and in the pop up, select the BP50NB40 (NB50) 1.03-MK firmware that you just flashed.
3. Select the BP60NB10 1.00-MK or BU40N 1.00 firmware in the normal drop box.
4. Click START-
There are no differences between the BP50NB40 and WP50NB40.SlippyFist wrote: Sun Sep 28, 2025 7:17 pmis it possible to use the SDFtool flasher instead of the command line?MartyMcNuts wrote: Thu Sep 25, 2025 2:32 amsecond line.SlippyFist wrote: Wed Sep 24, 2025 11:55 pm Hey,
what is the difference between the WP40NB50 and the BP40NB50? I can't for the life of me find what is different between them. It seems like they use the same firmware upgrade path regardless of which one you get, but i want to make sure i'm not conflating 2 separate things.Code: Select all
For the moment, to flash the BP50NB40 SVC:NB52, using the latest SDFtool Flasher, follw the steps below: 1. Flash the drive to BP50NB40 (NB50) 1.03-MK. Now for the crossflash: 2. Select the RECOVERY option and in the pop up, select the BP50NB40 (NB50) 1.03-MK firmware that you just flashed. 3. Select the BP60NB10 1.00-MK or BU40N 1.00 firmware in the normal drop box. 4. Click START
Yes you can use SDFTool Flasher if you are using 64 bit Windows 10 or 11. I recommend using the BU40N 1.00 firmware as it is compatible with all good ripping software. Just follow the instructions exactly and watch the gif a few times if needed.
f.zst
Hi guys,
Is one of these new Asus external drives UHD friendly? Can you use these to rip UHDs?
Asus BW-16D1H-U Pro
Asus BW-16D1X-U
Asus SBW-06D2X-U
Asus BW-16D1H-U Pro
Asus BW-16D1X-U
Asus SBW-06D2X-U
SlippyFist
[edit] you can delete this post [/edit]
