KeyDB.cfg configuration help
kingpeep
Post by kingpeep »
The last few UHD discs I have tried to make copies of on MakeMKV have resulted in the following errors:
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '9842061312'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '9842061312'
I stumbled onto a post by SamuriHL using his KeyDB Helper too. With the tool, I was able to syncrhonize and validate that the disc ID I have in my drive is located in the keydb.cg. I copied that newly syncrhonized keydb.cfg from Appdata/roaming/aacs to users/makemkv folder. But I am still getting errors when trying to make a copy of the disc on MakeMkv. I am also seeing in the log that the drive posts:
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Downloading latest HK to C:\Users\notha/.MakeMKV ...
Using Java runtime from C:\Program Files\Java\jre1.8.0_461\bin\java.exe
Which indicates its using its built in hash table not the keydb.cfg. Am i doing something wrong, I know for sure that my key for this disc is in my keydb.cfg so I'm not sure why I cannot perform a rip
Re: KeyDB.cfg configuration help
Post by SamuriHL »
Are you sure your drive is libredrive enabled? Post the makemkv info for your drive.
keydb_helper
Post by keydb_helper »
kingpeep wrote:
Fri Sep 26, 2025 3:11 am
Your disc drive is having trouble reading the disc.
The public keydb can help to resolve decryption errors due to missing keys but it will not assist with read errors.
Public KeyDB Disc Submissions
  • LG/Buffalo/Asus drives only (Pioneer drives are not supported)
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
kingpeep
Post by kingpeep »
Yes Libre drive is enabled. Here is MakeMKV info
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: XXXXXXXXX
Highest AACS version: 77
Firmware version: 1.02
It is not a decryption problem. It is a disc reading problem. The drive is struggling to read it and may also be running low on power. Try cleaning the disc before attempting to read it again. This often resolves read issues. See how you go.
mladams922
Post by mladams922 »
Can you tell me if this issue was resolved? I'm running into the same problem and I'm not sure if it's my drive or my disk.
