Discs won't stop loading.
ThrowawaySteve6514
Post by ThrowawaySteve6514 »
Hello.
Windows 11 user here.
I'm currently trying to rip 4 dvds but none of them work. Everytime I put them in and open MakeMKV it just gets stuck at "Disc Is Loading"
I have tried all dvd structure removal methods (CellWalk -Trim & -Full) but none of them do anything. I've tried downgrading my MakeMKV to 1.17.7 also to no avail.
All 4 dvds work perfectly in my normal dvd player but not on my USB Blu-Ray drive. I would normally suspect the drive, however every single other disk I've given it has worked flawlessly, From Blu-Rays to DVDs.
Don't know if anyone has any tips or tricks that can help me.
Here's my drive info.
OS device name: E:
Product: BD-RE BU40N
Revision: 1.03
Serial number: SIK07P3HA5021
Highest AACS version: 81
Firmware version: 1.03
Re: Discs won't stop loading.
Are you using a permanent key? Or are you turning back the clock on the expired beta key?
ThrowawaySteve6514
I'm turning back the clock.
shonenbat
Post by shonenbat »
I faced the exact same problem under Linux (Mint 22.1).
I wanted to use the trial (beta) key, but it's no longer valid (nearly all menu items stay grayed, including the "freeware" ones).
For that reason, I had no option but turning back the clock
I'm willing to buy the software, but I'd like to make sure it can run on my setup (ASUS_BW-16D1HT_3.02_211711151716_my_serial).
Will buying a license make this problem go away?
In case it doesn't, is there a refund policy?
BuffaloSlack
Post by BuffaloSlack »
If this is the Linux version it could be the endless scanning bug on versions > 1.17.7, see that subforum lots of threads about it.
16442496
Post by 16442496 »
BuffaloSlack wrote:
Thu Sep 25, 2025 6:31 pm
It says Windows 11 and "OS device name: E:"
Debian
MakeMKV 1.17.6 (Registered)
Pioneer BD (Unsupported, Non-Libre)
DVD to MKV only.
BuffaloSlack
16442496 wrote:
Fri Sep 26, 2025 2:20 am
I was replying to this poster who had the same issue but on Linux Mint.
shonenbat wrote:
Thu Sep 25, 2025 1:30 pm
shonenbat
Post by shonenbat »
Thanks, you were right, downgrading to 1.17.7 solved the problem under linux for me
