PM sent.sugi1 wrote: Wed Sep 24, 2025 9:04 pm I seem to have the same problem. Any help is appreciated.
Drive info:Code: Select all
Loaded SDF.bin version 0x98 SDF.bin version: 0x0098 Drive Tool SDF present Drive Specific SDF present [Drive Specific SDF] Embedded Info Strings: 8000:LibreDrive Information 8013:Status 8105:Enabled 8001:Drive platform :RS8F00 8015:Firmware name :PIONEER BDR-212T 8002:Firmware type 8106:Original (unpatched) 8003:Firmware version :E116/ID71 8005:DVD all regions 8100:Yes 8006:BD raw data read 8100:Yes 8007:BD raw metadata read 8100:Yes 8009:Unrestricted read speed 8100:Yes [Drive Specific SDF] Embedded Status Message: 8099:Using LibreDrive mode (v%1 id=%2) :01.0 :D0CE65A7F569 Identification SDF present [Identification SDF] Embedded Info Strings: 8000:LibreDrive Information 8013:Status 8102:Possible, not yet enabled 8001:Drive platform :Pioneer RS8F00 8003:Firmware version :ID71 [Identification SDF] Drive autodetect string: pioneer:SAT :8F00:ID71: :ASUS :BW-16D1H-U E116: 20/07/21 :-
Get UHD Access From the E116 Version of ASUS BW-16D1H-U?
Re: Get UHD Access From the E116 Version of ASUS BW-16D1H-U?
WALTunne
Hello guys, i don't know which firmware i have to write. Can someone help me ?
Drive info :
Informations lecteur
Nom du lecteur SE : F:
Fabricant : ASUS
Produit : BW-16D1H-U
Révision : E116
Numéro de série : DIDL120081WL
Date micrologiciel : 2020-07-21
Marqueurs d'encryptage bus : 1B
Drive platform: RS8F00
Firmware version: E116/ID71
Drive info :
Fabricant : ASUS
Révision : E116
PM is comimng. The forum is terribly slow and I have a lot of timeouts.WALTunne wrote: Wed Oct 01, 2025 9:06 pm Hello guys, i don't know which firmware i have to write. Can someone help me ?
Drive info :
Fabricant : ASUS
Révision : E116
ducky007
Hi folks, I been searching the forums and have not found a solution to get my drive to accept
UHD discs. Found this thread and I thought I try here. Help
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: X
Firmware date: 2020-07-21
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: X
x10bulls
Can I please get help for a working firmware to rip UHD titles. Here's my drive info:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
PM sent.ducky007 wrote: Tue Oct 07, 2025 5:07 pm Hi folks, I been searching the forums and have not found a solution to get my drive to accept
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: X
PM sent.x10bulls wrote: Mon Oct 13, 2025 10:19 pm Can I please get help for a working firmware to rip UHD titles. Here's my drive info:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
evo_day
@Coopervid, wonder if you could help me with the same?Coopervid wrote: Tue Oct 14, 2025 10:08 amPM sent.x10bulls wrote: Mon Oct 13, 2025 10:19 pm Can I please get help for a working firmware to rip UHD titles. Here's my drive info:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: *****************
Highest AACS version: 82
Sure. PM is coming.evo_day wrote: Mon Oct 27, 2025 11:19 am@Coopervid, wonder if you could help me with the same?Coopervid wrote: Tue Oct 14, 2025 10:08 amPM sent.x10bulls wrote: Mon Oct 13, 2025 10:19 pm Can I please get help for a working firmware to rip UHD titles. Here's my drive info:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
GDNCHN!
Could you send me that PM again? I haven't got time to see that. Thanks!Coopervid wrote: Thu Aug 28, 2025 8:51 pmPM sent.GDNCHN! wrote: Thu Aug 21, 2025 1:54 pm Drive Information
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
The biggest difference between my drive and the common ones is that its firmware is "E116", compared to the often-seen ones with "E114" or "E115" firmware. But since the LibreDrive is enabled, I put an UHD disc inside. Surprisingly, after a while of reading, MakeMKV just simply told me that there is "No Disc" inside. That's awful. What should I do, or which firmware should I patch since its chip is not MT1959?
Sorry. Look elsewhere. Half a year after sending the firmware right away you lost youir window of opportunity. I just dislike slow people who ask for help and then disappear.GDNCHN! wrote: Fri Apr 03, 2026 5:57 amCould you send me that PM again? I haven't got time to see that. Thanks!Coopervid wrote: Thu Aug 28, 2025 8:51 pmPM sent.GDNCHN! wrote: Thu Aug 21, 2025 1:54 pm Drive Information
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Sure email me that drive info section see below for emailCoopervid wrote: Fri Apr 03, 2026 7:09 pmSorry. Look elsewhere. Half a year after sending the firmware right away you lost youir window of opportunity. I just dislike slow people who ask for help and then disappear.
noctem_aurelius
I bought an ASUS Drive too and it doesn't support the MediaTek Chipset Flashing as well. Would love some help. Couldn't get help from Billycar because the payment method isn't available to me. I heard to ask for Coopervid.
Drive Information:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Highest AACS version: 68
LibreDrive Information:
At the moment, UHD Blu-ray discs are not recognized by the drive.
Could you please let me know if this drive can be sidegraded for UHD support and, if so, send me the appropriate instructions/firmware?
Drive Information:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
sure email me that info and all others email me no need to post your info here publicly just reach out to me directlynoctem_aurelius wrote: Wed Sep 23, 2026 8:37 am I bought an ASUS Drive too and it doesn't support the MediaTek Chipset Flashing as well. Would love some help. Couldn't get help from Billycar because the payment method isn't available to me.
Drive Information:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
see below for email
i have payment methods available for you all you had to do was tell me it was not available in your country
pgjohn
Hi @Coopervid. Could I please get the info about the UHD enabling firmware? I have the same BW-16D1H-U with the 2020 Pioneer drive (2020-07-21, E116 version firmware).
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
