@RESET
Thanks. How to use Resolve's scene cut detection in your scripts?
LG OLED65G1RLA / Samsung HW-Q990D / Sony UBP-X800M2 / Ugoos AM6B+ (CE with CPM Build)
The script defaults to using internal/external scene cuts or madvr to generate them, so you will have to remove HDR10plus(2-2) to force madvr.
You could also use 6-2 to create the scene cuts. Rename the generated RPU the same as the mkv and run 3-1
@RESET_9999
What do you think about the Kodi app on android tv? I just installed the app on my Sony a95l and it seems to play all the Dolby Vision 4K remuxes smoothly. Might be a good option for those that can't get the Ugoos.
I dont know, never had a Sony TV
Not necessarily a sony. Any android tv?
It's not going to support the FEL layer. So as long as that's not a concern, it'll probably "work" fine. Not really any different than the SHIELD.
There's H265 in the title. Isn't that encoding?RESET_9999 wrote: ↑Mon Sep 15, 2025 11:01 amif it's a remux, it should be fine...geofox784 wrote: ↑Mon Sep 15, 2025 1:51 amMay be a dumb question, but I've done a fair amount of research and still don't 100% understand.
In the Dolby Vision Stuff google sheet I see chart "ENCODER GROUPS TO AVOID BECAUSE THEY DONT ENCODE DV FEL PROPERLY"
I have a AM6B+ so I can playback DV Profile 7. I wanted to confirm that I understand encoding correctly. If the group that created an mkv left the file as a Profile 7 release instead of baking the FEL / encoding it into Profile 8, is no encoding actually occurring when the MKV is created from the original bluray disk files? Wouldn't this be a lossless packaging of the data directly into an MKV format?
For example, if a release is titled "███.2025.2160p.UHD.BluRay.REMUX.DV.P7.HDR.ENG.TrueHD.Atmos.7.1.H265-BEN.THE.MEN", does it matter that the release group is in the "avoid" list?
Mediainfo shows "HDR format : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.06, BL+EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible"
That list is only for the encodes and that guy ben the men encodes are ridiculously bad: https://slow.pics/c/Yp0F0UWf
H.265 usually indicates a remux or WEB-DL, while x265 typically refers to an encode, but not all release groups follow this naming convention.
Also if it doesn't specifically say 'remux' or 'untouched' it's usually an encode and you can double check the bitrate if they post it in the release, typically encodes usually gonna be ~24mbps or lower and remuxes like ~60+mbps or higher most of the time and also if it's a DV7 file then you can be pretty sure it's a remuxRESET_9999 wrote: ↑Fri Sep 26, 2025 10:59 amH.265 usually indicates a remux or WEB-DL, while x265 typically refers to an encode, but not all release groups follow this naming convention.
It's gonna say 'remux' most of the time though so just look for that
Hello! Just wondering if anyone could help me understand why this file isn't playing on LG CX internal player. Generated Dolby Vision with 3-1 option and converted audio to EAC3 with the tool as well, then muxed together in Tsmuxer. File seems fine in VLC player on PC, and the video only file seems to play fine as well in the LG CX internal player. But the final version isn't playing audio or video.
General
Complete name : E:\Movies\Barry.Lyndon.1975.DV.CM4.0Generated.ts
Format : MPEG-TS
File size : 69.9 GiB
Duration : 3 h 5 min
Overall bit rate mode : Variable
Overall bit rate : 54.0 Mb/s
Maximum Overall bit rate : 128 Mb/s
Frame rate : 23.976 FPS
Video
Menu ID : 1 (0x1)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, Profile 8.1, dvhe.08.06, BL+RPU, extended metadata compression, HDR10 compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible
Codec ID : 36
Bit rate : 50.3 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.253
Stream size : 65.1 GiB (93%)
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Audio
Menu ID : 1 (0x1)
Format : E-AC-3
Format/Info : Enhanced AC-3
Commercial name : Dolby Digital Plus
Codec ID : 135
Duration : 14 s 656 ms
Bit rate mode : Constant
Bit rate : 1 024 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 1.79 MiB (0%)
Language : English
Service kind : Complete Main
Dialog Normalization : -31 dB
dialnorm_Average : -31 dB
dialnorm_Minimum : -31 dB
dialnorm_Maximum : -31 dB
I find PVR/TV playback has severe audio sync issues with the CPM build.RESET_9999 wrote: ↑Tue Aug 26, 2025 5:46 pmGet the ugoos, all the other devices drop frames with FEL playback. CPM A14 has perfect playback and doesn't really need any update so we are good forever...
CPM was well into supporting more multi channel PCM formats that the current 2.0,3.1,5.1,7.1 limitation and improving audio synch when just disappeared 3 months ago. Hopefully CPM returns as A14 was a few features and bug fixes away form being great.
I have a rip from a 4K disc of mine which the Dolby Vision layers brightness pulses constantly (Its horrible) but a backup of the same disc using the same hardware works well. Does anyone know if this is likely a MakeMKV bug or UGoos AM6B software issue? The disc is slightly unusual in that it is Dolby Vision MEL with V4.0 Metadata.
@RESET9999
How do you like the G5 so far with the latest firmware update, compared to the C2 you own?
I'm still on the old firmware, before they messed up the DV black levels, so everything looks fine on my end. I actually prefer it a lot over the C2, mainly for the better colors, but also for how it handles bright content. The dithering scanlines in DV can be a bit annoying, but they show up rarely(mostly I poorly graded content), and I doubt anyone watching outside of a dark room would even notice them. The dithering noise itself isn’t very visible unless there’s a lot of green or cyan in dark scenes (under about 2 nits).deadchip12 wrote: ↑Tue Oct 07, 2025 8:54 am@RESET9999
The undefeatable sharpening fix in the latest firmware is definitely tempting but I don't want to ruin everything else just for that.
How does the latest firmware mess up the DV black level? I read forums posts and thought only hdr10 still had problems.RESET_9999 wrote: ↑Tue Oct 07, 2025 11:24 amI'm still on the old firmware, before they messed up the DV black levels, so everything looks fine on my end. I actually prefer it a lot over the C2, mainly for the better colors, but also for how it handles bright content. The dithering scanlines in DV can be a bit annoying, but they show up rarely(mostly I poorly graded content), and I doubt anyone watching outside of a dark room would even notice them. The dithering noise itself isn’t very visible unless there’s a lot of green or cyan in dark scenes (under about 2 nits).deadchip12 wrote: ↑Tue Oct 07, 2025 8:54 am@RESET9999
