want2beunique
#1
Post
by want2beunique » Sun Sep 21, 2025 12:00 am
This is my first time posting so please forgive any mistakes....
I'm getting the following errors when attempting to back up my Purple Rain Blu-ray disk (below). I have also attached the *-tree and *-disk text files. It is an older external Blu-ray player (connected via USB). I have no issues with many more contemporary disks to I'm thinking the issue is with this specific disk and not the player, but I could be mistaken.
The disk has been cleaned using a DVD cleaner and plays fine in VLC Player and a stand-alone Blu-ray player.
Thank you for any help you can provide!
Saving 1 titles into directory D:/Videos/Ripped
Failed to save title 1 to file D:/Videos/Ripped/Purple Rain_t01.mkv
0 titles saved, 1 failed
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00042.m2ts' at offset '17332174848'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '17332174848'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '17332174848'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00042.m2ts' at offset '17332174848'
Encountered 47 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
- PURPLE RAIN-disc.txt
- (20.13 KiB) Downloaded 210 times
#2
Post
by dcoke22 » Mon Sep 22, 2025 3:57 am
Have you tried power cycling your drive and restarting your computer? It seems like LibreDrive or some decryption component of MakeMKV didn't load properly.
want2beunique
#3
Post
by want2beunique » Tue Sep 23, 2025 2:54 am
Yes, the computer and drive have been restarted several times. No change in the results….
Thanks for taking a look!
#4
Post
by MartyMcNuts » Tue Sep 23, 2025 5:04 am
want2beunique wrote: Sun Sep 21, 2025 12:00 am
Think there might be something wrong with your disc.
** NEW Single Drive Flasher ** available worldwide!
https://payhip.com/b/MyeJ9
want2beunique
#5
Post
by want2beunique » Thu Sep 25, 2025 2:37 am
MartyMcNuts wrote: Tue Sep 23, 2025 5:04 am
I don't disagree. Just hoping there might be another resolvable issue. Like I said, plays fine in VLC and Blu-Ray players. Although, I have to say, after watching it so much recently, I might be good throwing the disk out....
Thank you for taking a look.
#6
Post
by MartyMcNuts » Thu Sep 25, 2025 4:13 am
want2beunique wrote: Thu Sep 25, 2025 2:37 am
Unless you want to try another ripping software and see if it works?
