Pioneer bdr 209 and Pioneer bdr 209m
pmccarenko
Re: Pioneer bdr 209 and Pioneer bdr 209m
#91 Post by pmccarenko » Wed Sep 24, 2025 4:35 pm
Thank you very much. Firmware flashed successfully, but i can not backup any UHD Disc. For example:
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-S11
Revision: 1.53
Serial number:
Firmware date: 2020-08-03
Highest AACS version: 82
Drive platform: RS8800
Firmware name: PIONEER BDR-211
Firmware version: 1.53/ID43
Disc Information
Label: The Good The Bad And The Ugly
Timestamp: 2025-06-19 18:22:24
Protection: AACS2.0/C v82
Data capacity: 92.84 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
MakeMKV v1.18.1 win(x64-release) started
Downloading latest SDF to C:\Users\MediaUser/.MakeMKV ...
Automatic SDF downloading is disabled or failed.
Using LibreDrive mode (v01.0 id=341479DBE353)
Backing up disc into folder "C:/BD/The Good The Bad And The Ugly"
Downloading latest HK to C:\Users\MediaUser/.MakeMKV ...
Saved AACS dump file as C:\Users\MediaUser/.MakeMKV/MKB20_v82_The_Good_The_Bad_And_The_Ugly_53EC.tgz
Backup failed
#92 Post by MartyMcNuts » Wed Sep 24, 2025 9:55 pm
pmccarenko wrote: Wed Sep 24, 2025 4:35 pm Thank you very much. Firmware flashed successfully, but i can not backup any UHD Disc. For example:
OS device name: F:
Revision: 1.53
Serial number:
Disc Information
Number of layers: 3
Backup failed
This is your issue. MakeMKV needs Internet access to download the hashed keys. Ensure you have allowed internet access in preferences and that your system is not geo blocking Russia as that's where the keys are hosted. Usually, running MakeMKV through a VPN helps with this.
phauturok
#93 Post by phauturok » Wed Sep 24, 2025 11:31 pm
Coopervid wrote: Wed Sep 24, 2025 2:23 pm
phauturok wrote: Tue Sep 23, 2025 6:27 am Hi - is it possible to get this drive to read UHD. Thank you in advance.
Product: BD-RW BDR-209D
Revision: 1.10
Serial number:
Firmware date: 2013-09-10
Bus encryption flags: 13
Highest AACS version: 77
Drive platform: RS8600
Firmware version: 1.10/ID61
PM sent.
Thank you - flashed without dramas. :D
pmccarenko
#94 Post by pmccarenko » Wed Sep 24, 2025 11:53 pm
MartyMcNuts wrote: Wed Sep 24, 2025 9:55 pm
OS device name: F:
Revision: 1.53
Serial number:
Disc Information
Number of layers: 3
Backup failed
Thank you very much for your advise. I have allowed internet access in preferences, but Russia may be blocked. May be you can advise me VPN for work with Russia?
#95 Post by MartyMcNuts » Thu Sep 25, 2025 2:30 am
pmccarenko wrote: Wed Sep 24, 2025 11:53 pm
OS device name: F:
Revision: 1.53
Serial number:
Disc Information
Number of layers: 3
Backup failed
Use whatever VPN you want. Just select a country that works. You may need to try a couple.
phauturok
#96 Post by phauturok » Thu Sep 25, 2025 6:00 pm
phauturok wrote: Wed Sep 24, 2025 11:31 pm
Revision: 1.10
Serial number:
PM sent.
Donation sent - Pioneer in a Flash!
pmccarenko
#97 Post by pmccarenko » Tue Sep 30, 2025 1:12 pm
MartyMcNuts wrote: Thu Sep 25, 2025 2:30 am
All done. All works Well. Donation sent by my daughter Anastasiia. Thank you very much!
AvidUser101
#98 Post by AvidUser101 » Mon Oct 06, 2025 1:10 am
Hi, is it possible to flash this drive?
Revision: 1.34
Serial number:
Firmware date: 2016-04-25
Highest AACS version: 66
Firmware version: 1.34/ID61
Swill37
#99 Post by Swill37 » Fri Oct 10, 2025 9:26 pm
Hi, I'm hoping this drive is possible to flash for UHD:
OS device name: E:
Product: BD-RW BDR-209M
Revision: 1.30
Serial number:
Firmware date: 2014-12-05
Highest AACS version: 81
Firmware version: 1.30
Please and Thanks!
#100 Post by Coopervid » Sat Oct 11, 2025 10:14 am
AvidUser101 wrote: Mon Oct 06, 2025 1:10 am Hi, is it possible to flash this drive?
Revision: 1.34
Serial number:
PM sent.
#101 Post by Coopervid » Sat Oct 11, 2025 10:17 am
Swill37 wrote: Fri Oct 10, 2025 9:26 pm Hi, I'm hoping this drive is possible to flash for UHD:
OS device name: E:
Revision: 1.30
Serial number:
Please and Thanks!
PM sent.
lediable
#102 Post by lediable » Sat Oct 11, 2025 7:46 pm
Does anyone know how reliable the BDR-209DBK drives on eBay that come from China tend to be? Considering how difficult it is to source one in the US I didn't know if it is worth the gamble, but I want to come up with some solution since my 6-month old LG WH14NS40 seems to have a lot of issues standard bluray discs (although I've had good luck with UHD discs).
Some of them are as little as $60 for a supposedly "new" drive, like this example:
https://www.ebay.com/itm/167751376420
Here's an older unit but listed by a seller with a pretty good rating (based off a lot of reviews):
https://www.ebay.com/itm/134602374771
Another option I would consider is this Pioneer BDR-S09XLB since it sounds like it is possible to update for UHD ripping:
https://www.ebay.com/itm/205415512797
Thanks for thoughts - and HUGE thanks to the folks who've put in work getting UHD ripping to work
Mercy
#103 Post by Mercy » Mon Oct 13, 2025 2:09 pm
Hi I was wondering if it was possible to flash this drive?
OS device name: /dev/sr0
Revision: 1.34
Serial number: QADL148886WL
#104 Post by Coopervid » Mon Oct 13, 2025 3:09 pm
Mercy wrote: Mon Oct 13, 2025 2:09 pm Hi I was wondering if it was possible to flash this drive?
Revision: 1.34
PM is coming.
Piranha26
Want to crossflash my BDR-209M with S11 FW
#105 Post by Piranha26 » Tue Oct 14, 2025 9:01 pm
Hi guys,
I'm a DVDFab user.
I want to crossflash my existing Pioneer BDR-209M to a BDR-S11JBK to make it UHD capable/friendly. I found a post where someone of you said he would own 4 drives and all of them have been crossflashed to a BDR-S11 successfully. My question is how to do that? I can't find the neccessary bin file anywhere on the internet. Could someone please help or provide the neccessary file to me?
My drive is Libre enabled (please check the attached Info file of my drive)
Is it possible to flash with SDFtool flasher or do I need BDR flash?
Someone here says one would need 2 files. A kernel file and another one...
https://forum.cdrinfo.pl/showpost.php?p ... tcount=780
So I'm a bit confused. Can someone please assist?
Piranha26
