I'm submitting a dump file for a Blu-ray disc that uses a newer AACS version not currently supported by MakeMKV.
MakeMKV version: 1.18.1
Disc title: Unknown
Dump file name: MKB_v82_EMPB_5031_3_EEBC.tgz
The disc failed to open and showed a message about a newer AACS version. Please let me know if you need any more information.
Thank you!
MKB v82 - Unknown disc - Dump submission
Re: MKB v82 - Unknown disc - Dump submission
If you want to help the community and have a key added to the public KeyDB, you need to host the dump somewhere and provide a download link here.alice wrote: Wed Sep 24, 2025 3:30 am Hello,
Disc title: Unknown
Thank you!
Thanks for the reply!
Here’s the download link for the dump file:
https://drive.google.com/file/d/1BZlm2U ... sp=sharing
Let me know if you need anything else.
This is a BD disc, not a UHD disc, yet you posted in the UHD disc section!alice wrote: Thu Sep 25, 2025 1:23 pm Thanks for the reply!
Did you email the dump to svq@makemkv.com? If not, please do so, otherwise it won't get added to MakeMKV's hashed keys database.
Also, a record for your disc is already in the public KeyDB file. If you donwload it and put it in your MakeMKV data directory (where the dumps are found) you should be able to rip it.
Thanks a lot for the clarification and the detailed explanation!
I’ll make sure to send dumps via email next time, and I’ll also try using the latest KeyDB.cfg file as you suggested.
Really appreciate your help!
